Do they make good quality receivers anymore, or is everything just cheap plastic and cut corners all the way? My last two Denon's failed me. Prior to that I bought Yamaha and they started to fail. There has to be something else out there, right? I have a feeling all these receivers are made in the same place (China) and just re-labeled when they get in the stores. I currently have an Denon AVR-X4000 that just went out of warranty and so did the sub woofer outputs. This model has the Platinum Audyssey set which is acting strangely too. I remember when I first got the receiver and setting up the speakers with the MIC it would chirp 3 times on the same channel, then get louder, then chirp 3 times again, get louder and then chirp again. It would chirp 9 times on all the speakers I have, and now it only chirps once (3 times), so it's never really measuring anything. Maybe it's just falling apart. Can anyone recommend a good QUALITY receiver without all the bells and whistles. What I like about this receiver is I can control via the web and has on screen on any resolution. I'm hoping other receiver can do the same. I think I've just had it with crap **** out there.
