Any issues with not using some channels on an amp? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By JThiessen
post #1 of 6 Old 12-15-2015, 07:05 PM - Thread Starter
JThiessen's Avatar
Quoted: 29 Post(s)
I have found myself in the situation where I have 3 Emotiva Amps, with 12 channels of amplification. I have 15 speaker locations pre-wired in the walls (allowing for multiple set up options).
At this point, I only have 9 speakers available.
I've got all 12 channels wired to a wall mounted patch panel, but only 9 of them have a speaker at the outlets.
Is this ok to run like this? Should I completely disconnect unused channels at the amp to avoid any possible ground out risks? (BTW, all the wall outlets are Speakons). Or should I not even have them connected from the PRE?
Thanks in advance - this is my first use of a Pre/Pro system.
JThiessen is offline
post #2 of 6 Old 12-15-2015, 07:11 PM
Montucky's Avatar
Quoted: 429 Post(s)
Liked: 288
I believe you should be fine. If I'm not mistaken, it takes the speakers themselves actually being connected to complete the circuit. Thus, if you don't have the speakers hooked up, then the amp behaves as if nothing is hooked up to it at all. The beauty of using less speakers than you have available channels is that (at least with traditional AVRs), all that additional juice is automatically rerouted to the channels being used. For example, using a 5.1 channel system as a 2 or 3 channel setup will yield you more power per channel.
Montucky is offline
post #3 of 6 Old 12-15-2015, 07:43 PM - Thread Starter
JThiessen's Avatar
Quoted: 29 Post(s)
Thanks - that's what I thought.
now to get a ColdSnack....
Montucky likes this.
post #4 of 6 Old 12-16-2015, 06:18 AM
Montucky's Avatar
Quoted: 429 Post(s)
Liked: 288
Haha. That's awesome. You a local?
Montucky is offline
post #5 of 6 Old 12-29-2015, 05:19 PM - Thread Starter
JThiessen's Avatar
Quoted: 29 Post(s)
Born and raised in Eastern MT (Lambert/Sidney area). Lived in Seattle now for 25 years
post #6 of 6 Old 12-30-2015, 06:04 AM
DonH50's Avatar
Quoted: 2205 Post(s)
Liked: 1804
I would double-check with the amplifier manufacturer. The biggest risk is the long cables without loads causing the amplifier to oscillate. They could also act as antennae for RFI. Most amplifiers are designed to be stable into an open circuit, but you may want to disconnect the wires at the amp until you are ready to use them. In the past I have placed fairly high-value resistors across unused amplifier outputs just to be safe (e.g. 100 ohm 10 W) and grounded their inputs with shorting caps. Most amps don't need them, but did it out of caution because I did not want to be the one explaining to a customer why their amp blew up when it wasn't doing anything...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
