Pro amp wattage claims? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-01-2016, 09:35 AM - Thread Starter
Brian S's Avatar
Question Pro amp wattage claims?
So I'm considering purchasing a new Pro amp to power my IB and sealed Tempest subs. I'm thinking about using one channel for the IB and the other for the sealed Tempest. I've been looking at the new Crown XLS series 2 amps. However I now these days the wattage ratings are usually a bit inflated for marketing purposes. Is there any way to decipher what the real world output is on these amps so as to make a better decision on which model to pick?
Brian S is online now
post #2 of 6 Old 02-01-2016, 10:41 AM
DonH50's Avatar
Quoted: 1259 Post(s)
Liked: 814
They are two-channel professional amps. I have not found their wattage ratings to be inflated but YMMV. A doubling in power is not much increase in perceived loudness so not sure I'd be too concerned anyway...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #3 of 6 Old 02-01-2016, 10:58 AM
JHAz's Avatar
Quoted: 281 Post(s)
Liked: 236
+1 What Don said.
JHAz is offline
post #4 of 6 Old 02-01-2016, 11:29 AM
M Code's Avatar
Quoted: 440 Post(s)
Liked: 261
We use/install Crown amplifiers in our pro-audio systems, they are great amplifiers good sounding and reliable....
Just my $0.02...
M Code is online now
post #5 of 6 Old 02-01-2016, 11:35 AM
lovinthehd's Avatar
Quoted: 3503 Post(s)
Liked: 3487
Its how the watts are marketed and the specific spec involved, not that they're inflated particularly. Will most pro amps automatically proclaim a 20Hz-20kHz rating at .01 THD into 8 ohm for the home "audiophile"? No, they're more likely to be a total bridged capability at the lowest impedance it can drive measured at 1kHz at maybe .5 to 1% THD as throwing that number out there is more impressive. Big deal.
That said, the XLS amps are just fine Here's the data sheet http://www.crownaudio.com/media/wysi..._datasheet.pdf
lovinthehd is online now
post #6 of 6 Old Today, 04:03 PM - Thread Starter
Brian S's Avatar
So I just scored this at a pawn shop. Hope it fits the bill?
