Beyond 7.1.4... Multi-AVR set-up for Immersive Audio - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 224Likes
post #1081 of 1099 Old 10-05-2017, 09:57 AM
rfb6435's Avatar
Quoted: 143 Post(s)
Liked: 58
Note that I suggest turning off Dynamic Volume and Dynamic Range when using scAtmos....
With those enabled I got a lot of extra noise/hiss on the speakers. When I turned it off it is now silent.
I think it must be related to using analog inputs with the dynamic volume and dynamic range features.
I also noticed that my AVRs had the dialogue set to +2.5db by default (or from Audyssey). I need to play around with that to see if it should be turned back to zero or if it is already combined with the center speaker levels to create the correct SPL to match the L/R.
-Rich
Quad Marantz AVR 15 speaker 9.2.6 Atmos/DTS:X with Dual sr7010's + Dual scAtmos nr1403's
Marantz MM8003 8x150W/ch External Amplified (L/C/R/SL/SR/SBL/SBR)
HTD L3 Tower L/R, Center, Dual 12" Subs, HTD L2 Tower SL/SR, Bookshelf SBL/SBR, HTD Middy WL/WR
HTD In Ceiling 6.5" Angled FH/RH, 8" TM
Epson 5030UB 1080p 3D Projector with Monoprice 106" Multi-Format Screen.
rfb6435 is offline
post #1082 of 1099 Old 10-05-2017, 10:15 AM
batpig's Avatar
Quoted: 3729 Post(s)
Liked: 3607
The "dialogue level" setting on D+M receivers is just a "pass through" to the center channel level. So it's just allowing you to tweak the center channel volume from the Audio menu vs. having to dig into the speaker setup zone and run the test tones.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #1083 of 1099 Old 10-05-2017, 10:46 AM
rfb6435's Avatar
Quoted: 143 Post(s)
Liked: 58
Should the audyssey setup provide equal levels to the L/C/R including the dialogue offset? If so then I guess the center speaker level should be -2.5db in the speaker setup due to the dialogue offset of +2.5db?
If so then I will probably just leave it alone.
The strange thing with scAtmos is that the atmos AVR only sets the levels for L/R during its setup so double checking the C requires and SPL meter (I have one but so fare have only checked it by ear).
-Rich
rfb6435 is offline
post #1084 of 1099 Old 10-05-2017, 12:05 PM
batpig's Avatar
Liked: 3607
The levels for the LCR are whatever they need to be, they don't have to be equal. Especially if the speakers aren't identical.
No, you're not understanding, the dialogue level is NOT an offset, it's a direct "pass through" to the center speaker level. It's the same thing, just a different (shortcut) way of getting there.
Setup Guide and FAQ
batpig is offline
post #1085 of 1099 Old 10-05-2017, 01:47 PM
rfb6435's Avatar
Quoted: 143 Post(s)
Liked: 58
Ok I get it...
It is exactly the same setting as the Center channel level. Now that I re-read your post it makes sense.
Changing one affects the other and they both adjust the same setting just through a different menu like you said. N
Kind of a nitpick but dialogue seems like a bad name given that more than dialogue comes from the center channel. I guess the name makes sense for a novice user (not that a novice user would even change it).
-Rich
rfb6435 is offline
post #1086 of 1099 Old 10-13-2017, 09:12 AM
Liked: 1
Thumbs up 11.2.8 Dolby Atmos Layout
I have been following this thread for some time now, really informative and impressive rigs.
I'm considering expanding my Dolby Atmos 7.2.4 speaker layout to 11.2.8.
I'm planning to use two AVRs:
Denon X6300H, it supports 11.2 channels, this receiver can do 7.2.4 without adding another amp.
Denon X6200W would add wide speakers support, 4 heights (FHR, HFL, THR, THL) and side surrounds.
Here's the layout (Layout in this images is 9.2.8 but I'm planning to add two speakers between Side and Rear speakers):
AVRs speaker connections:
Red Speakers: X6300H (7.2.4)
Blue Speakers: X6200W (7.x.4 with external amp)
Room layout:
Does this sound feasible? Is there something I'm missing?
I would like to get some feedback on my idea. Thank you guys!
(I'm kinda limited by my broken english)
chroman is offline
post #1087 of 1099 Old 10-13-2017, 09:23 AM
Nalleh's Avatar
Quoted: 1255 Post(s)
Liked: 673
That is kind of what i am doing. With two 11.1 ATMOS Avr’s, 11.1.8 is the maximum you can do. I’d say go for it
Triple Atmos Receivers
Atmos 13.1.8/DTS:X 9.1.8/AURO 3D 12.1
My setup:
http://www.avsforum.com/forum/29-wha...l#post41323201
Nalleh is offline
post #1088 of 1099 Old 10-13-2017, 10:01 AM
Liked: 1
Oh man, this is all possible because of YOU! thank you so much
(I am a great fan of your crazy setup)
I'll keep you guys posted on this journey
Nalleh likes this.
chroman is offline
post #1089 of 1099 Old 10-13-2017, 10:15 AM
Marc Alexander's Avatar
Quoted: 2707 Post(s)
Liked: 2547
Don't you need two AVRs which support WIDES/Special Wides to achieve 11.8 FrankenAtmos(FAtmos?)?
Marc Alexander is online now
post #1090 of 1099 Old 10-13-2017, 10:17 AM
Josh Z's Avatar
Quoted: 2476 Post(s)
Liked: 1628
The problem you run into is that these two receivers don't know about each other. When decoding the height layer of the soundstage, one AVR sends all of the height information to the Top Front and Top Rear speakers, while the other AVR sends the same info to the Front Height and Rear Height speakers, leading to duplication of sounds and potentially some imaging or object movement issues. You will never have an instance where, say, a helicopter pans from Front Height to Top Front to Top Rear to Rear Height, which would be the ideal goal. Instead, FH and TF are basically identically to each other, as are TR and RH.
If that's what you want to do, it would be simpler to just use one AVR and create arrays by wiring the Top Front and Front Height speakers to each other in series, then the same for the Top Rear and Rear Height.
Likewise on the ground level, the X6200 would create Wide channels for you, but (if it's configured for 7.1.4) the X6300 believes you only have 7 speakers there and will take all the audio intended for Wides and split it between the front mains and Surrounds. More duplication.
You could get accurate Wide channels by configuring the X6300 for 9.1.2 and simply not connecting any height speakers to it. That receiver would consolidate the entire height layer into 2 channels which are not actually connected to speakers. Then configure the X6200 for 7.1.4 and only connect height speakers to it. This gives you a total of 9.1.4, with all sounds going to an accurate placement. However, it will not give you the 8 height channels you want, just 4.
How are you planning to decode audio to get to those speakers? Are they just cloned from either the Surrounds or Surround Backs, or will you be adding two additional AVRs to matrix new channels between the Surrounds and Surround Backs?
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #1091 of 1099 Old 10-13-2017, 11:37 AM
Nalleh's Avatar
Liked: 673
Yes, to get my full Pure Wides+Special Wides, you need one to do 9.1.2(pure wides) and one on top of that with 5.1.4+wides(special wides)., but with two AVR’s, this gets you furthest.
So in this example, the one doing 7.1.4 doesn’t need wides.
Just yet another way of expanding 7.1.4.
My setup:
Nalleh is offline
post #1092 of 1099 Old 10-13-2017, 01:47 PM
Liked: 2547
Ahh... I see. I need to read your thread and look at your diagram again. I got distracted by your awesome sub build!
I added WIDES and I have been playing around with rendered WIDES (no REARS) vs matrixed/summed in the Lyngdorf MP-50. I need to pay attention to how the surround rendering differs. Any test material you recommend?
Now I am wondering if ScAtmos HEIGHTS can work with RoomPerfect so I can render 9.3.2 in the Lyngdorf. I am a true believer in WIDES now!
post #1093 of 1099 Old 10-14-2017, 11:46 AM
Liked: 2547
I am going to implement my own version of ScAtmos, I'll call it RAtmos.
My speaker layout is 9.1.6. and my SSP is the Lyngdorf MP-50. The MP-50 allows for a 9.1.6 layout but is rendering 7.1.4 and matrix/summing WIDES and TOP MIDDLES. I am happy with the TOP MIDDLE matrixing in all the scenarios I have tested. However, I want to be able to switch between matrixed WIDES and rendered.
To achieve rendered wides and not fully lose REAR SURROUNDS here is my plan: I am going to run 5.1+WIDES on the floor level. I am going to add a single Outlaw 950 back into the mix to provide the ability extract a mono REAR using DLPII (I believe MUSIC will gave me an ability to dial in the REARS without worrying about RoomPerfect affecting the ability to extract a perfect center image).
I will then be able to switch between 7.1.4 w/matrixed WIDES & TOP MIDS and 8.1.4 w/rendered WIDES & matrixed TOP MIDS via remote.
Please let me know your thoughts guys, as well as any other ideas.
If someone implements RAtmos for the REARS and ScAtmos for TOP MIDS (8.1.6) they could call it ScRAtmos. 🤡
maikeldepotter likes this.
post #1094 of 1099 Old 10-15-2017, 07:59 AM
brazensol's Avatar
Quoted: 215 Post(s)
Liked: 72
Rumor has it ScAtmos sounds like crap...
brazensol is online now
post #1095 of 1099 Old 10-15-2017, 01:50 PM
asarose247's Avatar
Quoted: 839 Post(s)
Liked: 644
Wasilla - - - that's the punch line . . .
So, It's rumored, 2 Corinthians walk into a bar . .
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #1096 of 1099 Old 10-16-2017, 11:02 AM
Nalleh's Avatar
Liked: 673
That should work Clever idea actually, as long as you do not sit dead center on front of that mono rear. It would work in my room
Marc Alexander likes this.
My setup:
Nalleh is offline
post #1097 of 1099 Old 10-16-2017, 11:37 AM
maikeldepotter's Avatar
Quoted: 1124 Post(s)
Liked: 342
I predict that for Atmos the 8.1.4 configuration (5.1.4+wides+'extraced rear') will become your favorite, as it features the 'special wides' which are enriched with arrayed side surround info for a true 'cinemascopic' sound (a special present from the Atmos decoder for those that choose to live without rears )
A good idea and understanding lies at the base of every successful project.
maikeldepotter is online now
post #1098 of 1099 Old 10-16-2017, 12:19 PM
Liked: 2547
I'm connecting two rear surrounds reminiscent of THX/EX/ES REARS. I've got the REARS connected to the Zone 2 output on the Outlaw so I can easily switch between ScrAtmos (Aux1 input, Y-split from C output) and standard 7.1.4 (Aux 2 input).
Unfortunately, the MP-50 requires WIDES and TOP MIDS to be assigned to the [4] Auxiliary outputs as well as L/R front/rear subs. I'm hoping I can get Lyngdorf to allow more assignment flexibility so I can connect stereo subs to the REAR outputs, allowing 8.3.6 (really 7¾.3.4½).
My carpet is being ripped out at the moment (replacing with wood). I just need to tidy up the wiring. [I added an Earthquake Cinenova Grande 7 (it is humongous!) last w/e and rearranged my racks]. I hope to get RoomPerfect run (w/Outlaw in stereo) and start listening tonight.
@Roger Dressler I haven't forgotten about measuring the Lyngdorf matrixing relative SPL levels. I've just been preoccupied with these WIDES! Too bad I can't afford the Altitude16, but I think this setup will be amazing.
post #1099 of 1099 Old 10-16-2017, 03:04 PM
Liked: 2547
via Imgflip Meme Generator
oldsteve, brazensol and mrtickleuk like this.
