Denon X2200W Audyssey Calibration Issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-23-2016, 06:06 AM - Thread Starter
Liked: 0
As the title suggests, I've recently purchased a Denon X2200W receiver. All connections were made (only running L, C & R for now) and the unit was powered up.
I proceeded through the initial setup and arrived at the Audyssey speaker calibration phase. I moved the microphone around as per normal and everything seemed to be going fine until "Analyzing Room Data".
It took 45 minutes to reach 5%. So I factory reset the receiver and tried it all again. Same thing occurred. Finally, I reset the unit, ran all of the initial setup and then let it run overnight. It currently stands at 52%.
Given how commonplace the search terms are for this issue, I can find only one other individual who seems to have experienced a similar issue but their post did not receive an answer.
I would appreciate any insight or thoughts you folks might have to get this sorted.
keilwerthsax is offline
post #2 of 6 Old 02-23-2016, 06:16 AM
jdsmoothie's Avatar
Quoted: 15033 Post(s)
Liked: 7250
If a microprocessor reset doesn't resolve the issue (see post 5 in the Denon 2015 AVR Owner's thread linked below), then exchange it for another unit.
The "OFFICIAL" 2015 Denon "S-series" / "X-series" AVR Owner's thread + FAQ (HDCP 2.2)
Was this a "new" unit or "refurbished" unit?
jdsmoothie is online now
post #3 of 6 Old 02-23-2016, 06:28 AM - Thread Starter
Liked: 0
It was factory refurbished. I purchased it from Amazon.
I'm not sure if waiting to see what happens over the next few hours is worth it or if I should just have the thing replaced soonest.
post #4 of 6 Old 02-23-2016, 06:40 AM
Squirrel!'s Avatar
Quoted: 592 Post(s)
Liked: 336
Do a microprocessor reset before you try replacing it. Especially being a refurb. Do it 5x in a row then try Audyssey again.
Main: Mitsubishi 73736 DLP|OTA|fireTV|Sony BDP-S1100|Denon AVR-4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|2 - DIY Class G 540w 12" Subs|2 Aura Bass Shakers|APC H15|Harmony 720|TP-Link Archer C7|Linksys SE2500|50+ OTA Channels
MBR: Vizio VF550M|OTA|fireTVstick 2|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Phantom|Dayton Audio SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Belkin Bridge|Harmony 550
Squirrel! is offline
post #5 of 6 Old 02-23-2016, 06:47 AM - Thread Starter
Liked: 0
I've gone a head and ordered a replacement from Amazon. I've tried resetting a number of times to no avail.
post #6 of 6 Old 05-01-2016, 02:31 PM
Caspian's Avatar
Same issue, AVR-X2200W stuck at 0% analyzing Audyssey input
I did the factory reset and it still hung up at 0%
I updated firmware then ran Audyssey again. This time it processed almost instantly and everything seems to be working fine.
Best.
LD
Caspian is offline
analyzing room data , audyssey auto setup;denon , audyssey multieq xt , calibration , denon 2200w
