The "OFFICIAL" 2016 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ
2016 Denon AVR models ---> S510BT/S720W/S920W/X1300W/X2300W/X3300W/X4300H/X6300H
The D+M Group USA (Denon/Marantz) has released information on the new 2016 Denon models. The X6300H will be the highest model released for 2016 while the 2015 Denon X7200WA will remain the "flagship" D+M AVR and has its own thread (actually 2 of them, (1) X7200WA Owners thread, and (2) Denon 2014 Atmos Owner's thread).
What's new or to be added via firmware update for the 2016 models?
- Dual band 802.11n Wifi (5Ghz added to previously only single band 2.4Ghz)
- Bluetooth Class 1 (X4300H/X6300H only) - increased from 33ft to 98ft/30m
- Auto Lip sync delay (increased from 200ms to 500ms adjustment)
- RC Source Select (allows changing of an HDMI standby pass through source while the AVR is in Standby mode - 2015 and older models require powering on the AVR to change the pass through source)
- Playback of high resolution audio files (DSD 5.6 Mhz - increased from 2.8 Mhz) via USB and network
- DTS:X / DTS Neural:X (via firmware update on X3300W and lower models (Sep 2016) and installed at the factory on the X4300H/X6300H)
- Video Mode - new "Bypass" setting (S920W/X2300W only as a result of the Video Conversion setting being removed)
- Audyssey MultEQ Editor phone iOS/Android app ($20) - using the included Audyssey mic, provides the ability to customize target curves, save them, and stream back to the AVR (April 2017)
- The "H" series models (X4300H/X6300H only) include a HEOS module which will allow streaming the currently dozen music services using the HEOS iOS/Android app to the "H" model as well as allow streaming 2CH sources to one or more HEOS wireless speakers placed around the home
- Auto Update (X4300H/X6300H only) - (default - OFF), allows for firmware updates while the unit is in Standby
- SAVE & LOAD via USB (X4300H/X6300H only) - firmware updated April 2017, (Setup - General - Save & Load; config.avr)
- Auro 3D (X6300H only) - able to use the Surround Back L on board amp to power the VOG/Top Surround speaker instead of using Subwoofer pre-out 2 to an external amp
- Dolby Vision + HLG - capability added via firmware update Sep 2017
- Auto Low Latency Mode (ALLM) (added via firmware update June 2018)
- Airplay 2 (X4300H/X6300H only) - firmware updated August 2018
What was dropped from the 2015 models?
S920W/X2300W
- Analog --> HDMI conversion .
X4300H/X6300H
- Front Wide speakers (in fact all major brands dropped Front Wide speakers on their 2016 models )
- Web Control (ie. can no longer access the AVR via its IP address)
- vTuner - must use TuneIn (on board or using HEOS app) for internet radio which doesn't allow the user to manually add new stations as is the case with vTuner
- iPod/iPhone connectivity via USB
- Video Select (iPod/USB)
- Spotify using a FREE Spotify account via the HEOS app
See post 7 for additional specific 2016 vs. 2015 model differences
- All "S" series models have a 2 year warranty if purchased new/open-box from an authorized dealer
- All "X" series models have a 3 year warranty (2 years in Canada) if purchased new/open-box from an authorized dealer
- All refurbished models have a 1 year warranty if purchased from an authorized refurb dealer
Denon model web page info and Owner manual links
- S510BT - MSRP $279, 5.2 CH, 70W, HDMI In/Out (5/1) - (cont'd from 2015 so not considered a 2016 model)
This is a 5CH AVR which was first released in 2015 and will continue for 2016 as the entry level model which features Bluetooth, but is not a networking model. Firmware updates would be installed via the USB jack. It includes a mic for a basic (ie. non-Audyssey) single position speaker/sub calibration. It can display the GUI over 2D/3D video on HDMI1 and HDMI2 and pass through 4k/60Hz video from HDMI3/HDMI4/HDMI5 but cannot display the GUI/volume/info over 4k video.. It does not feature: HDMI(ARC), HDMI Control, Audyssey, speaker posts (uses spring clips) or Component Video inputs/output.
http://usa.denon.com/us/product/hometheater/avreceiversht/avrs510bt
http://manuals.denon.com/AVRS510BT/NA/EN/index.php
- S720W - MSRP $479, 7.2 CH, 75W, HDMI In/Out (6.1) - avail April
Upgrading from the S510BT adds HDCP 2.2 on all HDMI inputs/outputs and 1 more HDMI input and two more audio channels for a 7CH model and the lowest model to feature Audyssey MultEQ (6 mic positions), networking, HDMI Control, HDMI(ARC), DSD via USB/network source, Atmos 5.2.2, DTS:X (via firmware update summer 2016) and uses speaker posts. Firmware updates are installed via a network connection or USB. It can display the GUI over 2D/3D video from all HDMI inputs, but not over 4k video. It features 5.1 + Zone 2 capability using the Surround Back speaker posts for Zone 2. There are no Zone 2 pre-outs. No noticeable difference in power, however, audio quality should be improved after running Audyssey.
http://usa.denon.com/us/product/hometheater/avreceiversht/avrs720W
http://manuals.denon.com/AVRS720W/NA/EN/index.php
Press release on the S720W and S920W ---> https://usa.denon.com/us/news/news
- S920W - MSRP $579, 7.2CH, 90W, HDMI In/Out (8/2, main/main outputs) - avail April
Upgrading from the S720W adds 2 more HDMI inputs, 1 more main zone monitor output (eg. when using a TV and PJ), 2 component video inputs / 1 output, 4k/30Hz upscaling, on board Web Control (able to use laptop/tablet for setup/control), and SAVE/LOAD of configuration file which can be restored if doing a factory reset. No noticeable difference in either power or audio quality. Although unable to display the GUI on 4k video, able to display the volume bar/Info on 4k video (except Dolby Vision) but only at 24/30Hz, not at 60Hz and only when Video Mode is not set to "Bypass".
http://usa.denon.com/us/product/hometheater/avreceiversht/avrs920W
http://manuals.denon.com/AVRS920W/NA/EN/index.php
- X1300W - MSRP $599, 7.2CH, 80W, HDMI In/Out (6/1) - avail May
This model offers the same features as the S720W but adds: improved audio quality using the higher Audyssey MultEQ XT (8 mic positions), Zone 2 pre-outs, Crestron/Control 4 interface, and also as the lowest "X" series model adds 1 more year of warranty (total 3 years). Unable to display the GUI/volume/info on 4k video.
http://usa.denon.com/us/product/hometheater/avreceiversht/avrX1300W
http://manuals.denon.com/AVRX1300W/NA/EN/index.php
Press release on the new X1300W and X2300W ---> http://www.ecoustics.com/products/denon-avr-x1300w-avr-x2300w-av-receivers/
- X2300W - MSRP $799, 7.2CH, 95W, HDMI In/Out (8/2, main/main outputs) - avail May
This model is similar to the S920W in features but adds: improved audio quality using the higher Audyssey MultEQ XT, Zone 2 pre-outs, RS-232, Crestron/Control 4 interface, ISF (Day/Night) calibration settings (to be set by an ISF calibrator) and 1 more year of warranty (total 3 years). Although unable to display the GUI on 4k video, able to display the volume bar/Info on 4k video (except Dolby Vision) but only at 24/30Hz, not at 60Hz and only when Video Mode is not set to "Bypass".
http://usa.denon.com/us/product/hometheater/avreceiversht/avrX2300W
http://manuals.denon.com/AVRX2300W/NA/EN/index.php
- X3300W - MSRP $999, 7.2CH, 105W, HDMI In/Out (8/2, main/Zone 2 outputs) - avail July
Upgrading from the X2300W adds: Zone 2 custom settings (bass, treble, HPF, stereo/mono), 12v trigger (1), DSD over HDMI, Zone 2 HDMI Monitor output, HDMI/digital PCM 2.0 audio to Zone 2 speaker posts/pre-outs, , 4k/60Hz upscaling, and the lowest model with 7.2 main zone pre-outs. No noticeable difference in power, but much better audio quality using the more advanced Audyssey MultEQ XT32 and Sub EQ HT (dual sub level/delay). Although unable to display the GUI on 4k video, able to display the volume bar/Info on 4k video (except Dolby Vision) but only at 24/30Hz, not at 60Hz.
http://usa.denon.com/us/product/hometheater/avreceiversht/avrx3300w
http://manuals.denon.com/AVRX3300W/NA/EN/index.php
- X4300H - MSRP ($1499), 9.2CH, 125W, HDMI In/Out (8/3, main/main/Zone 2 outputs) avail Sep
Upgrading from the X3300W adds: 2 additional on board amps (with capability to expand to 11 using an external 2CH amp), a second main zone HDMI monitor output, 11.2 main zone pre-outs, Zone 3, a 2nd 12v trigger, front panel display of speaker inputs (or outputs), PHONO input, 32 bit DAC, metal front panel with 2 line display, Custom 2 CH settings (using FL/FR or dedicated Front B)(LARGE/SMALL; crossover settings, sub – on/off, distance, level), on board Denon HEOS module (allows streaming of HEOS app music services to the AVR as well as streaming PCM 2.0 source from the AVR to HEOS wireless speakers set up around the home), one internal cooling fan, and Auro 3D capable (via firmware upgrade - $199USD). Although unable to display the GUI on 4k video, able to display the volume bar/Info on 4k video (except Dolby Vision) but only at 24/30Hz, not at 60Hz.
https://usa.denon.com/us/product/hometheater/receivers/avrx4300h
http://manuals.denon.com/AVRX4300H/NA/EN/index.php
Expanding the X4300H from 9CH (ie. 5.2.4 or 7.2.2) to 11CH (ie. 7.2.4) --> https://www.avsforum.com/forum/90-r...-avr-owner-s-thread-faq-289.html#post54654062
- X6300H - MSRP ($2199), 11.2CH, 140W, HDMI In/Out (8/3, main/main/Zone 2 outputs) avail Sep
Upgrading from the X4300H adds: 2 additional on board amps (but no additional expansion beyond 11CH), uses more robust amps, HD Radio, mfr'd in Japan, gold plated connectors, Dialog Enhancer, two internal cooling fans, and if the Auro 3D upgrade ($199USD) is installed, ability to use the Surround Back L speaker post for powered VOG/Top Surround instead of Sub pre-out 2. Although unable to display the GUI on 4k video, able to display the volume bar/Info on 4k video (except Dolby Vision) but only at 24/30Hz, not at 60Hz.
https://usa.denon.com/us/product/hometheater/receivers/avrx6300h
http://manuals.denon.com/AVRX6300H/NA/EN/index.php
Welcome to the Official 2016 Denon AVR-S/X models thread (S510BT/S720W/S920W/X1300W/X2300W/X3300W/X4300H/X6300H).
If this is your first visit to this thread, and you want to ask a question about one of the 2016 Denon AVR models, either one that you own or one that you are thinking of buying, please provide the following information to allow for better responses to your questions:
(a) Identify the model number in question (eg. X2300W), as there are 8 different models (S and X series) discussed in this thread. Also if you have not posted in several days since your initial post, please post the model # again so we don't have to back track to learn which model you are referencing.
(b) Identify what you've done so far to troubleshoot the issue and what the front panel is displaying if an audio issue, (also take a few minutes to review the Troubleshooting section provided in post ##3 as your question may already be answered there),
(c) Unless you indicate what settings have been changed, the assumption will be that all settings are on the factory defaults (ie. usually "Auto"),
(d) If the advice given seems to simplistic or obvious, don't shoot the advice giver as we have no idea of the level of your technical understanding,
(e) If there is no response to your post, it either means no one knows the answer or it has simply been overlooked so please repost if you still haven't resolved your issue,
(f) If you post a question in this thread and are given advice and either it or some other advice (eg. Denon phone support, Denon "Ask a Question" email support) resolves your issue, have the common courtesy to post back what solution resolved your issue so others can learn from it as well,
(g) If the issue is not user error or not just a misunderstanding on how the AVR works, please call Denon support so the issue is registered,
(h) When responding to another post that is providing assistance to you, please press the "Quote" button in the lower right corner of that other poster's response so that response is also listed with your new post to provide some context, and,
(i) If you don't live in either the USA or Canada, please either indicate your country location in your profile or your post as some Denon models from other regions in the world differ in configuration from their USA/Canada counterparts otherwise responses made will be regarding the USA/Canada models.
S920W/X2300W
X4300H/X6300H
