Can I connect the antenna coaxial cable to receiver instead of TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-21-2016, 04:47 AM - Thread Starter
skunker's Avatar
My A/V Receiver: DENON AVR-2112CI 7.1 Integrated Network A/V Surround Receiver
My HDTV: Samsung Plasma
Is it possible to make the HD antenna coaxial cable connection to the receiver rather than the TV? I mistakenly wired my coaxial to the floor where my receiver is instead of the middle of the wall for the TV mount. I put drywall up already.
Wondering what my options are....or will I need to fish the cable back to the TV?
skunker is offline
post #2 of 3 Old 06-21-2016, 05:24 AM
garciab's Avatar
Quoted: 103 Post(s)
Liked: 48
If you want your tv to receiver OTA TV signals, then the cable needs to connect to the tv. They sell f connector couplers if you need one. Or just buy a wall plate with the f connector and remove it to use as a coupler. If you want your AVR to receive FM signals (GASP!), you can buy a splitter or a TV FM trap so that one cable can feed both the TV and the AVR.
bg
garciab is offline
post #3 of 3 Old 06-22-2016, 05:20 AM
Wayne A. Pflughaupt's Avatar
Quoted: 57 Post(s)
Liked: 44
Basically, the antenna coax needs to go to a TV tuner. Typically that’s TV itself. There are some stand-alone tuners out there, but they’re pretty rare.
One option that would let you keep the coax cable where it is would be an antenna-based TIVO. They make stand-alone DVRs with OTA tuners that can also handle streaming functions. Basically everything a smart TV does, with the addition of a DVR.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
