How to reset the remote for Pioneer VSX-930K - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By M Code
post #1 of 3 Old 11-16-2016, 09:58 PM - Thread Starter
Liked: 0
Hi Members,
I have Pioneer 930k AVR.My remote is not working after some changes in settings.So I need your help for reset to remote.
Thanks in advance.
nag bbv is offline
post #2 of 3 Old 11-16-2016, 10:32 PM
M Code's Avatar
Quoted: 679 Post(s)
Liked: 399
Here U go..
Page 95 of the Operation Manual.
Resetting the remote control settings
Use this procedure to reset all the remote control’s settings to the factory default.
When preset codes are set,all the signals learned in the input function buttons are cleared.This function is
convenient when you want to reset some but not all of input function buttons.
1. Press and hold RCU SETUP, then press ‘0’ for three seconds.
Release the button after the LED flashes once. The LED continues to flash.
2. Hold down the ENTER button for five seconds.
If the LED lights for one second, the erasing has been successfully completed.
Default preset codes
BD 2255
DVD 2197
HDMI 2144
TV 0305
CD 5000
SAT/CBL 6329
TV (INPUT) 0305
ALL 2034
Just my $0.02...
nag bbv likes this.
M Code is online now
post #3 of 3 Old 11-16-2016, 10:49 PM - Thread Starter
Liked: 0
Originally Posted by M Code View Post
Here U go..
BD 2255
DVD 2197
HDMI 2144
TV 0305
CD 5000
SAT/CBL 6329
TV (INPUT) 0305
ALL 2034
Just my $0.02...
Thank you.But I am already tried this one but no use.After 1 & 2 steps am I press the preset codes?
nag bbv is offline
