The "Official" Yamaha RX-A860, RX-A760 and RX-A660 AVENTAGE AVR Thread - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #1 of 89 Old 01-28-2017, 08:24 AM - Thread Starter
AirCeej's Avatar
Quoted: 13 Post(s)
These receivers definitely deserve their own thread, so here we go!
_______________________________________________
Yamaha USA RX-A'60 Release Announcement
USA Product Pages (incl. manuals, firmware, guides, etc.)
hollandjw likes this.
AirCeej is offline
post #2 of 89 Old 02-01-2017, 06:14 PM
Quoted: 17 Post(s)
Liked: 2
I agree on the need for this thread as I have the 860 and previously looked at the 1060/2060/3060 thread. Two Questions:
1. How or what settings does one need to enable that allows full use of lower range of subwoofer out? I've read that the default is min 30hz and I have a sub that goes down to 15hz.
2. If you use two subs is there anything special one needs to do or consider prior to letting YPAO work its magic?
hollandjw is offline
post #3 of 89 Old 02-01-2017, 06:29 PM
gp-se's Avatar
Quoted: 76 Post(s)
Liked: 56
The Yamaha will play lower than 30hz, however YPAO can only apply equalization down to 31hz. Also I would run YPAO two three times, one with each sub so you can match the levels, then the last time with both on.
gp-se is offline
post #4 of 89 Old 02-02-2017, 03:02 AM
jdsmoothie's Avatar
Quoted: 13410 Post(s)
Liked: 6226
1. As noted in the post above, the AVR can process below 30Hz, rather simply the YPAO mic doesn't go below 30Hz, so you would need to purchase a better quality mic as well as use a software program to create a curve below 30Hz (eg. REW with one of the two suggested mics for use on the REW page linked below).
https://www.roomeqwizard.com/
2. The process noted in the post above is your best option, as the dual Sub level/delay feature is only offered on the A2060 and A3060.
jdsmoothie is online now
post #5 of 89 Old 02-04-2017, 08:43 AM
eatman3's Avatar
bluetooth transmit
i just ordered the rx-a660 yesterday. I could only afford the entry model but I am very excited. mainly it was the only home theater receiver that offered bluetooth transmit built in around $500. i am a tech newbee and any basic advice is greatly appreciated. thanks
Lozin likes this.
eatman3 is offline
post #6 of 89 Old 02-04-2017, 09:24 AM
Lozin's Avatar
Quoted: 200 Post(s)
Liked: 86
You will love it.
Lozin is offline
post #7 of 89 Old 02-04-2017, 10:59 AM - Thread Starter
AirCeej's Avatar
Quoted: 13 Post(s)
Agreed especially if it performs close to the '860; and among other things the ability to manually adjust the EQ is a bonus.
AirCeej is offline
post #8 of 89 Old 02-04-2017, 11:54 AM
kikkenit2's Avatar
Quoted: 823 Post(s)
Liked: 305
The a660 has a much smaller power supply and doesn't have near the
same manual eq skills as the a760 and above.
kikkenit2 is offline
post #9 of 89 Old 02-04-2017, 12:35 PM - Thread Starter
AirCeej's Avatar
Quoted: 13 Post(s)
Thus contributing factors to the A660's price point, with the manual EQ among it's obvious bonuses.
AirCeej is offline
post #10 of 89 Old 03-05-2017, 04:23 PM
Liked: 1
I just bought an RX-A760, hooked it up to 2x Definitive Technologies BP6B floor towers, a Definitive Technology C/L/R 2002 for the center and a Yamaha sub. Connected a PS4 Pro and a DirectTV Genie box (collectively "Components") using new high-speed HDMI cables. I did the YPAO setup 3 times.
The sound quality from both Components is terrible. Live TV from the Genie box and DVDs/games/Netflix from the PS4 sound suppressed. I have to crank the volume to -25 to make dialog audible, but any music or sound effects are overwhelmingly loud. I have tried adjusting all of the different sound settings, but to no avail. I even reset back to factory settings and setup all over again. No soup for me.
Using Bluetooth, I streamed Spotify to the receiver to see if the same thing happened with a different input source, but the sound was incredible. At -45 the sound was enough to comfortably fill my living-room and at 25 the windows were shaking (sounded awesome, btw).
Has anyone else run into this? Any ideas for setting changes? Thanks.
MeanMachine likes this.
egreene1974 is offline
post #11 of 89 Old 03-06-2017, 08:42 AM
Liked: 1
Rx-a860?
Hello All,
Any Atmos / DTSX users here? What are your level settings for all speakers?
6month is offline
post #12 of 89 Old 03-07-2017, 01:27 PM
VoodooGTS's Avatar
Quoted: 40 Post(s)
Liked: 3
Originally Posted by 6month View Post
Hello All,
I am. Using NHT Dolby Atmos up firing speakers. When I ran the YPAO it had set them to +4.5
@6month how is your setup and what did you set your Atmos speakers to?
6month likes this.
VoodooGTS is offline
post #13 of 89 Old 03-21-2017, 12:45 PM
Liked: 4
Question HDCP Audio Dropouts
Has anyone encountered audio dropouts with the 760BL? I have an LG B6 and I'm getting a 1 second dropout every now and again via ARC back to my 760. I also had this issue with an RX-V581 a few weeks ago (which caused me to return it) and didn't have this problem with a Denon X1300. Seems like it's probably a software issue? I'm on the latest Yamaha firmware and opened a support ticket to see if they can help. Already tried a half dozen different HDMI cables just to be safe.
variableresults is offline
post #14 of 89 Old 03-21-2017, 02:25 PM
Super Moderator
teachsac's Avatar
Quoted: 740 Post(s)
Liked: 1211
Posts deleted and any follow up post quoting the original.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #15 of 89 Old 03-21-2017, 02:40 PM
jasonsong's Avatar
Quoted: 428 Post(s)
Liked: 162
I have similar problem on my Samsung TV when watching Netflix. Optical is not affected. I think it's the TV.
jasonsong is offline
post #16 of 89 Old 03-21-2017, 06:46 PM
ChromeJob's Avatar
Quoted: 1022 Post(s)
Liked: 481
Send a message via Yahoo to ChromeJob Send a message via Skype™ to ChromeJob
I had problems with Netflix particularly on my Samsung ES6150 TV. There are threads about this all over the HT forums. Not clear if it's the Samsung TV, or the app running in their Smart Apps. What I know is that the Netflix stream would be Dolby Digital +, but my receiver would only get Dolby Digital from the TV. Same over optical SPDIF. But if I selected a 2-channel stereo soundtrack, no problems. Somewhere in the transcoding was messed up.
I tried streaming the exact same movie, same scenes on my Panasonic BD player (HDMI connection) and Chromecast (HDMI again) and no such problems. And the audio stream to the AVR was Dolby Digital +.
I gave in and started using the Chromecast, and later an Apple TV 4gen. Haven't touched the Samsung TV smart apps in over a year. My next tv won't have those bells and whistles.
So, in your case, what content are you watching, what's the TV supposed to be supplying, and what does your 760 indicate it's receiving?
“Phil? Phil Connors?!”
Are ya new here? Please read FAQs and forum stickies. Like posts that help you. Don't ask a question and then disappear.
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen.
ChromeJob is online now
post #17 of 89 Old 03-22-2017, 12:04 PM
Liked: 4
My B6 is sending DD+ and it appears that's what's being received by the 760, both over ARC and Optical (the latter which is issue-free and is what I'm using currently). From a streaming point of view I would prefer to use the B6's smart features, especially given there are no streaming devices currently (that I'm aware of) that support Dolby Vision in Netflix.
post #18 of 89 Old 03-22-2017, 05:19 PM
Liked: 4
Quick update, I called LG trying to remove the TV as the source of the issue, but they didn't really accept any responsibility. I did convince them to send the issue on to their engineering department. Not going to hold my breath, though.
ChromeJob likes this.
post #19 of 89 Old 03-23-2017, 12:04 AM
jdsmoothie's Avatar
Liked: 6226
Optical cannot pass DD+, rather only DD.
mdbrown and ChromeJob like this.
post #20 of 89 Old 03-29-2017, 10:42 PM
ChromeJob's Avatar
Liked: 481
FYI:
I noticed something new in the AV Controller app this week. Previously, when you selected the Surround Decoder switch in the DSP popout menu, you selected that mode. That was it. You were stuck with the decoder last set with the remote or using the On Screen menu.
NOW when you select Surround Decoder, the switch changes to display the decoder selected: Dolby ProLogic, DPL(x)(Movie, Music, Game), DTS NEO:6 (Cinema, Music), etc. As you press the switch, the Decoder will cycle through modes the available in your AVR, depending upon the content being played. This new functionality is compatible with 2011 or newer AVRs.
Update available in the iOS App Store and Google Play Apps as of May 27.
(cross-posted to other major AVR models — I hope that's not spamming)
post #21 of 89 Old 04-04-2017, 12:16 PM
rarechaga's Avatar
Suggestions on Setup
I just installed a rx-a860, with wall mounted fronts (2 x JBL Arena 8IW) and center (JBL Arena 55IW), and ceiling mounted side and backs (4 x JBL Arena 8IC) and an old JBL 12" sub that I have had forever. I am not an expert and realize that the speaker placement (in-ceiling) is not ideal, but it is what best fits the space. Most of my viewing is through Comcast's Xfinity box or Netflix via my Sony XBR 850D.
What settings should I set up for the best surround setup that would be good for most of my viewing, any suggestions?
rarechaga is offline
post #22 of 89 Old 04-04-2017, 01:15 PM
roland6465's Avatar
Quoted: 36 Post(s)
Liked: 46
Run YPAO with the mic at the main listening position to establish a baseline, then tweak levels to your own taste. I keep mine in "Straight" mode for everything DD and dts, and "Pure Direct" for lossless music and movie soundtracks in Dolby TrueHD and dts-MA.
roland6465 is offline
post #23 of 89 Old 04-04-2017, 03:35 PM
rarechaga's Avatar
Thumbs up
Thank you! Sounds reasonable to use straight, but then I wonder if I sacrifice anything. Confirmation that it is OK to do it helps. I have used Onkyo and Pioneer in the past, but this is definitely my favorite!
post #24 of 89 Old 04-05-2017, 07:28 AM
animeking's Avatar
Quoted: 65 Post(s)
Are there any differences between this series and the RX-Vx81 or TSR-x810 series besides the aluminum, 5th foot and price tag? Software or usage differences?
I just picked up a A660.
animeking is offline
post #25 of 89 Old 04-05-2017, 09:15 AM
ChromeJob's Avatar
Liked: 481
My understanding is that any difference between the RX-V581 and TSR-5810, for example, are nil — they are model numbers for different retailers.
There are slight differences between the RX-V and RX-A series, another recent thread post discussed this…
post #26 of 89 Old 04-06-2017, 02:10 AM
jdsmoothie's Avatar
Liked: 6226
The "A" series uses better quality components and adds an additional 3rd year of warranty.
post #27 of 89 Old 04-08-2017, 06:44 AM
Liked: 1
I have an A660 and noticed the streaming sources in Musiccast only list Pandora and Spotify. I thought Napster, Sirius, etc. were supposed to work with it as well. Is it different for each device (i.e. a2060 has those but not the a660)? My firmware is updated so don't think that's an issue. Separately, doesn't look like Amazon Prime Music works with it (well only through bluetooth) but curious if anything has been mentioned about adding that service.
nchan50 is offline
post #28 of 89 Old 04-14-2017, 01:40 PM
Liked: 0
Hiiii
Please can any one help me.....
its been a week trying to buy a reciver and till now keep changing my mind and keep reading more and more and cant decide yet
I am betwen Yamaha and Denon and dono what should i pick .. I have 4 Polk TSI 200 speakers and a 4k Samsung tv..
here where i live in Brasil found the folowing models :
Yamaha Rx-v681 same price as Denon x2300 ( 850 $ )
Yamaha Rx-v781 same price as Denon x3300 ( 1100 $ )
And Yamaha Rx-a860 Aventage little more than Denon x3300 ( 1200 $ )
so any help plz
Faruk Abou Rafeh is offline
post #29 of 89 Old 04-17-2017, 08:45 PM
greg0ire's Avatar
I just purchased the a660, but it seems to be difficult for me. My Onkyo would display when it was playing the digital surround modes. Does this Yamaha do that as well? Also, my PS3 doesn't seem to acknowledge the rear speakers. I have a 5.1 setup. Thanks!
greg0ire is offline
post #30 of 89 Old 04-17-2017, 09:04 PM
bobknavs's Avatar
Quoted: 453 Post(s)
Liked: 372
Sure. P 47 in the downloadable manual.
(Press the INFO button to step through the displays. Stop when you get to Audio Decoder.)
bobknavs is offline
