Sub $300 recover suggestions. - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Knucklehead90
  • 1 Post By Ortizer
  • 1 Post By Kini62
post #1 of 13 Old 02-08-2017, 03:16 PM - Thread Starter
Liked: 0
Good day guys,
I was wondering if you guys could suggest a new Receiver.
I just recently picked up a 65" Samsung 8000 Tv and figured it may be time to replace my receiver.
I plan to use the Samsung to do the HDMI switching so don't need many.
My current receiver is Harmon Karden AVR 146. I would like to keep in under $300 but I do want something that I will notice a difference, otherwise, it's not worth the upgrade, I would also like it to support CEC.
This is geared more towards movies and tv shows than music.
I have to look when I get home but it's been a while, Speakers are Polkaudio Bookshelf speakers, center and base box for 5.1
any suggestion would be greatly appreciated
tfraley is offline
post #2 of 13 Old 02-08-2017, 03:26 PM
Knucklehead90's Avatar
Quoted: 490 Post(s)
Liked: 422
May as well keep what you have till it dies. Electronics make the least amount of difference - speakers the most. With that budget you probably won't find too many speakers that would be worth upgrading to either.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 13 Old 02-08-2017, 04:35 PM
NuDLP's Avatar
Quoted: 99 Post(s)
Liked: 53
Originally Posted by tfraley View Post
Good day guys,
Depending on the size of the room, I have had great success in small to medium sized rooms with the Marantz slimline receivers. They are small, compact, inexpensive and sound fantastic for what they are. I have picked them up used for under $250 in like-new condition on Audiogon and other sites and can't believe what you get for he money with them. For watching TV and movies they are solid.
Living Room - Monitor Audio Gold 100, Monitor Audio CP-IW460X center, Monitor Audio CP-CT380IDC, SVS-SB2000 X 2, Samsung UN55F9000, Oppo BDP-93, Playstation 4, NAD M15HD2, NAD M27
Dedicated Theater in Process - KEF XQ20, KEF XQ50C Center, KEF Ci200QR, NAD M15Hd2, NAD M25, Sony Playstation 3, Samsung DLP TV - (future projector), Subs TBD -
NuDLP is offline
post #4 of 13 Old 02-08-2017, 05:57 PM
Quoted: 71 Post(s)
Liked: 5
I just ordered an onkyo tx-nr656 off accessories4less.com for 300 + shipping today. They had the TX-NR555 and a couple Denons for a little less as well.
Sent from my XT1254 using Tapatalk
Ortizer is offline
post #5 of 13 Old 02-09-2017, 10:21 AM - Thread Starter
Liked: 0
Thanks for all the feedback guys, seems a bit mixed
Do you guys think it's worth an upgrade, will there be a noticeable difference in movies.
My Harmon Karden AVR 146 was great for its time but is old now. Are there any features I would benefit more in newer receivers like Atmos or other decoding options?
As for speakers, I'm not planning to upgrade them anytime soon, I know my center is a PolkAudio CS10 the other's are the bookshelf of the same class. I am in a big room prob 15'x10' and sit about 12' from the tv but volume is perfect with the current setup don't think I need more and not even pumping things totally up.
I just want the best possible sound from my movies, be able to decode all the new relevant stuff since I'm going 4k hdr now without going backward in sound quality.
Is it worth the upgrade? Should I just wait?
What features should I be looking at on current receivers?
What do you suggest in the <= $300 mark
tfraley is offline
post #6 of 13 Old 02-09-2017, 01:30 PM
Kini62's Avatar
Quoted: 1669 Post(s)
Liked: 1500
Unless you add atmos speakers to your setup you don't need an AVR that decodes it.
Also, it seems you're either using ARC from your TV or the optical out from your disc player or whatever source you're using- in which case both only supports dolby digital/DTS and not the uncompressed DTS Master or Dolby True HD.
In order to get the newest audio codecs you need to run HDMI into a new AVR and use that as a means of controlling your inputs/outputs.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #7 of 13 Old 02-09-2017, 01:49 PM
Quoted: 490 Post(s)
Liked: 422
Here's what is available in your budget range. Those are all refurbished units. I omitted Onkyo and Pioneer (same company) due to lousy quality. I'd rate the AVR's from first to worst: Yamaha - Denon - Marantz.
tfraley likes this.
post #8 of 13 Old 02-09-2017, 01:57 PM
Ted Sheckler's Avatar
Quoted: 333 Post(s)
Liked: 286
Tried a few but go back to Yamaha.
📺 Sony (XBR-55X930D)
📻 Yamaha (RX-V475)
🎶 SVS (PRIME)
🔊 SVS (PB-1000)
SVS (PC12-NSD)
🎮 PS4□Xbox One 2.5TB
Ted Sheckler is offline
post #9 of 13 Old 02-09-2017, 03:06 PM - Thread Starter
Liked: 0
Thank you very educational.
I was unaware you need atmos speakers to for it.
Yes, I was running optical for everything prior to this 4k update due to the fact my current receiver didn't decode hover HDMI just did pass through.
With the new TV (Samsung 8000) I have all HDMI going to it and optical out from it to the receiver. Until I get a new one.
Thank you for clearing all this up, I haven't dealt with this stuff in years. So I will want the AVR to do the HDMI switching and not leave it to the TV... Gottcha
So then I need to make sure the receiver support 4k hdr and current codecs is there anything else I need to keep an eye out for?
tfraley is offline
post #10 of 13 Old 02-09-2017, 03:29 PM
Kini62's Avatar
Liked: 1500
If you are planning on having more than one 4k device such as a UHD blueray player, 4k capable Roku and/or another 4K streaming device make sure the AVR has enough 4K capable inputs. Some of the less expensive ones only have one or two HDMI ports that fully supports 4K.
Get the latest spec HDMI cables to minimize handshake issues. Get them from Monoprice or Bluejeans cables from Amazon. Don't pay a lot for HDMI cables.
Def Tech SC8000
Kini62 is offline
post #11 of 13 Old 02-09-2017, 03:39 PM
Quoted: 71 Post(s)
Liked: 5
On accessories4less you want to filter on hdcp 2.2. That's what you want to see. Onkyo in particular only puts 3 or 4 hdcp 2.2 ports, though I think the rest will pass 4k that doesn't use that spec.
I think Denon may do that too. Yamaha receivers I looked at did it on all ports, but only had 4 ports at that price point.
tfraley likes this.
Ortizer is offline
post #12 of 13 Old 02-10-2017, 01:01 PM - Thread Starter
Liked: 0
Thanks for all you helps guys.
Think I'm going to hit up Fry's on the way home from work tonight and pick up a Yamaha RX-V381BL -it's listed there for $279.99 no tax and have a $80 gift card. (Only reason I'm leaning on picking it up there)
So for $200 out the door it seems like a good deal.
Anyone hear of any issues with this model?
Any other suggestions or insight is welcome, Please educate me if I'm missing something.
tfraley is offline
post #13 of 13 Old 02-10-2017, 01:33 PM
Kini62's Avatar
Liked: 1500
No issues. A very nice AVR for that price.
tfraley likes this.
Def Tech SC8000
Kini62 is offline
