No audio from TV well for 10 seconds - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-14-2017, 09:56 AM - Thread Starter
stevethebrain's Avatar
Quoted: 106 Post(s)
Liked: 25
When I turn the TV on the TVs volumne comes on for 10 seconds then mutes itself.
The Samsung TV is set to internal speaker.
I have the Yamaha 465RX AVR connected to the HTPC/DVR/TV all w/ HDMI cables
Then there’s a optical cable out of AVR directely into TV.
When I switch from TV to either HTPC or DVR the audio plays fine (as it always has for 5 years) though the AVR.
Just no audio from TV.
I recentely messed around w/ the Yamaha setting (don't rememeber changing anything) and now have a red HDMI passthough dot comes on when the whole Sys. Is shutdown.
this is when the new problem audio started
Please advice STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 8 Old 02-14-2017, 10:05 AM
Liked: 0
what's a TV well?
adam64 is offline
post #3 of 8 Old 02-14-2017, 06:18 PM - Thread Starter
Quoted: 106 Post(s)
Liked: 25
Originally Posted by adam64 View Post
what's a TV well?
woops forgot the comma
here you go
what's a TV, well?
thanks for well thanks for the advice well you actually have no advice so well unthanks.
post #4 of 8 Old 02-14-2017, 06:32 PM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
It confused me too. I also asked what's a TV well?
My guess you have problem with the optical cable, have you tried replacing it? Seems all the HDMI devices work fine.
Afro GT
afrogt is online now
post #5 of 8 Old 02-14-2017, 06:56 PM
littlefoott's Avatar
Quoted: 164 Post(s)
Liked: 69
set it to external unless you are using it as a center
Audyssey is a great start, but not always a great finish.
Marantz SR-5010
Def Tech ST-8060 towers, CS-8040 center, SR-8040 surrounds, Pro Monitor 1000 heights
SVS PB-2000
65" LG UG8700
Harmony 1000
littlefoott is online now
post #6 of 8 Old Today, 06:06 AM - Thread Starter
Quoted: 106 Post(s)
Liked: 25
how can I test the optical cable?
I removed the optical cable from the AVR observed red laser light coming from AVR when I removed cable from the back of TV it wasn't quite as bright.
maybe I need to use a chem-wipe ( a treated tissuse paper used to clean fiber optic telephony terminations that leaves on scrachs or debre) like I don't want to throw parts at a config. problem.
still no TV audio.
STB
TV is now set to external now I don't even get the 10 seconds of TV audio.
STB
post #7 of 8 Old Today, 09:34 AM
DonH50's Avatar
Quoted: 1804 Post(s)
Liked: 1340
Please advice STB
Seems to me something was changed after all... Check the Yamaha settings again, and make sure AnyNET is turned off on the TV.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #8 of 8 Unread Today, 02:02 PM
Quoted: 164 Post(s)
Liked: 69
when all else fails, find the reset procedure for your avr
http://faq.yamaha.com/us/en/article/...k__u/4408/7625
Marantz SR-5010
SVS PB-2000
65" LG UG8700
Harmony 1000
