Marantz SR5008 setup question using subwoofer for music - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-17-2017, 08:09 AM - Thread Starter
Quoted: 26 Post(s)
Liked: 8
I have a Marantz SR5008 that I use for 95% home theater, but I do like to listen to music from time to time. When I choose 2-channel audio for music, the sub is not active. Is there a setting that I can basically have 2.1 for stereo?
Klipsch RB-61 (Fronts)
Klipsch RC-52 (Center)
Klipsch RS-42 (Surrounds)
SVS PC12 Plus
Marantz SR5008
Mitsubishi 73842
rickyinman is offline
post #2 of 4 Old 02-17-2017, 08:33 AM
Selden Ball's Avatar
Quoted: 3428 Post(s)
Liked: 1699
Exactly what do you do to choose 2-channel audio? There are several different ways to do that and the "fix" is different for each.
However, double check to make sure that your front speakers are set to Small. That enables bass management, so that low frequencies are redirected to the subwoofer.
Alternatively, if you select Direct or Pure Direct, then you'll have to also select "LFE+MAIN" so that low frequencies are copied to the subwoofer. (Note that this results in "double bass" since it does not remove those low frequencies from the main speaker channels.)
Selden
Selden Ball is online now
post #3 of 4 Old 02-17-2017, 08:36 AM
jmh547's Avatar
Quoted: 117 Post(s)
Liked: 45
Yes there is. I used it all the time. There is a "music" button at the bottom of the remote. Hold it down and a menu with several music modes comes up. Give them a try.
Sent from my SM-G920V using Tapatalk
jmh547 is offline
post #4 of 4 Old 02-17-2017, 10:24 AM - Thread Starter
Quoted: 26 Post(s)
Liked: 8
Thank you!! That is exactly what I needed. I thought I had tried this before and got 2 channel audio, but I got 2.1 this time.
SVS PC12 Plus
Marantz SR5008
Mitsubishi 73842
