Is this subwoofer and receiver combo compatible? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old Today, 05:37 AM - Thread Starter
Quoted: 20 Post(s)
Liked: 0
https://europe.yamaha.com/en/product...l#product-tabs
http://usa.yamaha.com/products/audio.../rx/rx-v681_u/
My current subwoofer has only a LFE port on the back and my receiver has one subwoofer pre output. All I need is to connect them together for it to work. But this newer combo I'm looking at has multiple subwoofer connections. Can someone please tell me if they're compatible, and if so, how should they be connected?
P.S I'll be connecting the speakers directly to the receiver, not the sub.
ammarmalik is offline
post #2 of 3 Old Today, 07:46 AM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
They'll work just fine, basically connect like your previous setup. User manuals will give you tips as to which input/output is optimal.
crn3371 is online now
post #3 of 3 Old Today, 08:55 AM
afrogt's Avatar
Quoted: 1061 Post(s)
Liked: 763
Yes, it'll work fine. just connect it to the LFE Input 3 which is circled in blue.
Name:	Yamaha SW300 back.JPG
Afro GT
afrogt is online now
