onkyo tx-nr1030 + ps4 pro + HTPC - issue only one hdcp 2.2 port ? Workarounds? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Unread Yesterday, 10:32 PM - Thread Starter
markm75's Avatar
Quoted: 146 Post(s)
I think the answer to this is rather obvious but, it seems that the onkyo receiver the 1030, only has one single HDCP 2.2 port, that of hdmi 3..
This presents an issue with multiple 4K sources.. the ps4 pro needs the hdcp 2.2 to enable 4k mode for the netflix app and down the road actually in november there will be the Xbox scorpio which is 4k as well.
To me the only solution is to buy a $55 amazon HDMI splitter that is 4k and hdcp 2.2 compliant and has a remote.. sending that output to the receiver on hdmi 3.
Is this accurate or is there perhaps some workaround to make something like the ps4 pro work with 4k mode for certain apps?
Thanks in advance
My TF+TR Atmos Setup
Tech, the Universe, and Everything:  http://tech-stew.com
Just Plane Crazy: http://flight-stew.com
markm75 is online now
post #2 of 4 Unread Today, 02:28 AM
littlefoott's Avatar
Quoted: 224 Post(s)
Liked: 107
if 5.1 audio is acceptable from the ps4
optical from the ps4 to the onkyo
Audyssey is a great start, but not always a great finish.
Marantz SR-5010
Def Tech ST-8060 towers, CS-8040 center, SR-8040 surrounds, Pro Monitor 1000 heights
SVS PB-2000
65" LG UG8700
Harmony 1000
littlefoott is online now
post #3 of 4 Unread Today, 02:31 AM
Quoted: 224 Post(s)
Liked: 107
or ps4 direct to tv and tv via optical or arc to the onkyo
Marantz SR-5010
SVS PB-2000
65" LG UG8700
Harmony 1000
post #4 of 4 Unread Today, 08:40 AM - Thread Starter
markm75's Avatar
Quoted: 146 Post(s)
I believe I have already used up the opticals on another few devices, unsure.
Using optical would eliminate the PCM ability, though with the ps4 i mainly use dolby digital as it sounds better. I'd also have the x1 in the mix too when it goes 4k this fall with scorpio, so i think for sure i wouldnt have enough optical. I'd have to do arc. I do dts-hd and master audio for bluray as well, which i dont think works over ARC.. though mainly on the PC not the other two.
I have that 5 port switch coming, hopefully it works well enough in the interim.. it still seems crazy they only put 1 hdcp 2.2 port on this unit which originally was a $1500 or more item.
