MultEQ Editor: New App for Denon & Marantz AV Receivers & Pre/Pros - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 551Likes
post #451 of 906 Old 05-03-2017, 04:20 PM
Marc Alexander's Avatar
Quoted: 1967 Post(s)
Liked: 1688
It is a bit puzzling that the crossover selections are inconsistent since the mobile app is simply acting as a control interface. I believe the AVR actually performing REQ filter calculations whether the app is used or not.
Perhaps an upcoming revision will address this in the way Audyssey Pro does. Audyssey Pro reveals the crossover recommendations and allows you to make changes BEFORE the REQ filters are calculated and applied. It even lists the alternate choices in order of Audyssey's recommendations in the pull-downs.
The difference with Pro though is that the Audyssey REQ filters are calculated by the PC and uploaded to the AVR/AVP AFAIK.
BGLeduc and sevenz like this.
Marc Alexander is online now
post #452 of 906 Old 05-03-2017, 10:03 PM
sevenz's Avatar
Quoted: 74 Post(s)
Liked: 51
Originally Posted by Brian Day View Post
I did receive a reply from Chris at Audyssey via Twitter who states that Audyssey doesn't set the crossover - the AVR does. However, if the calibration is being done outside the AVR (by the app), then who or what does set the crossovers?
Ya that's weird... hope they resolve this in the coming fix
Perhaps an upcoming revision will address this in the way Audyssey Pro does..
Precisely. Hope so too
sevenz is offline
post #453 of 906 Old 05-04-2017, 09:12 AM
goonstopher's Avatar
Quoted: 317 Post(s)
Liked: 62
Originally Posted by bmcn View Post
Today I listened to music with midrange comp off and vocals were too bright, so it's back to the curve with a 400 Hz cutoff. Have yet to listen to Rolloff 2; might try that tomorrow but expectations it will tame the harsh vocals are low. App has been very stable. Hope to soon read Mark's findings.
It eq is stopped at 400 then mid-range comp will always be off I think. I think eq cutoff will overrule the mrc setting
goonstopher is offline
post #454 of 906 Old 05-04-2017, 12:59 PM
bmcn's Avatar
Quoted: 1699 Post(s)
Liked: 2528
Agreed. Very happy listening to music with the 400 Hz cutoff curve, so i didn't bother w/HF rolloff 2.
bmcn is offline
post #455 of 906 Old 05-04-2017, 01:19 PM
Point Source
beastaudio's Avatar
Quoted: 3912 Post(s)
Liked: 3214
Originally Posted by 310Turbo View Post
Lol good to know, it was about 3am and I was just so jazzed about getting it working together. Didn't even think to check what MV I was at.
If you came from a model that was 2 years or older ago, this is a new change they implemented in the past few years. Where previously you entered the test tone menu it automatically defaulted to 0.0 dBref. Now you have to manually turn it up yourself. It threw me off the first time as well, but once I figured out what was going on, I actually like the idea.
Originally Posted by turrmoil View Post
Second that thought... its a shame to be honest. I think this is Marantz way of saying you spent 4K means you can spend more on the version next year!!
I also bought this in jan this year based on info from a reputed dealer that this feature will be supported. But alas...
Nope, it was never said that the app would be available on the 8802 unfortunately. The reputable dealer notwithstanding. The 8802 still has audyssey pro capability, which they did away with to make room for the new app in the newest models from D+M.
Originally Posted by HTNUT1975 View Post
I've noticed midrange comp to be good with a loud action movie (e.g., saving private Ryan) with loud volume levels. Otherwise, I always have it on flat. But if there's a lot of higher pitched machine gun sounds, that can get too distracting (grating) at higher volumes. Interestingly, I recently watched an episode of home theater geeks. Scott Wilkinson was interviewing Paul Hayes of Pro Audio, who was talking about his preferred curve for home theater. He didn't believe that in the specific context of home theater, flat always sounded better or accurate. His recommendation seemed to mimic a lot of what the audyssey tweakers have mimicked (small increase down low, small roll off up high).
This has been proven time and again that a truly flat (audyssey) response curve is actually the least preferred in blind testing. Our ears don't perceive sound on a flat FR either so this should be no surprise.
FS: BossoBass A-14K amplifier
beastaudio is offline
post #456 of 906 Old 05-04-2017, 05:00 PM
In.vincible's Avatar
Quoted: 220 Post(s)
Liked: 92
Yeah, I don't like flat, either. It's too bright for me, but everyone has their preference.
In.vincible is offline
post #457 of 906 Old 05-05-2017, 10:51 PM
IBJamon's Avatar
Quoted: 59 Post(s)
Liked: 26
How's that review coming along?
IBJamon is offline
post #458 of 906 Old 05-06-2017, 09:58 AM
Methodical_1's Avatar
Quoted: 376 Post(s)
Liked: 187
App should be fine with the Note 4.
App requires IOS8 w/Apple which I believe can run on the iPhone 4s (but not well IME). I would recommend iPhone 5 at a minimum.
The app didn't work with the Note 4 when the app first came out and showed as not compatible; I tried to download the app when it came out and it was a no go with the Note 4. So, based on your response, they updated the app so that it now works with the Note 4, correct.
HT Configuration: 7.2.4 l Panasonic Plasma (65") l Denon X4300H l Polk LSiM 707s l Polk LSiM 706c l Polk FXi-30 (x4) l Infinity ERS-610 (x4)-Atmos l SVS PB-2000 l Polk PSW 505 (temp) l Monolith 7 amp l Behringer A500 (2x) l Behringer FBQ3102 EQ l Oppo BD-93 l Denon CD player l Denon DP-300F TT l Cassette Deck.
Subwoofer Trim and Audyssey EQ setup guide
Methodical_1 is offline
post #459 of 906 Old 05-06-2017, 10:16 AM
AVRams's Avatar
Quoted: 22 Post(s)
Im also curious about the review ☺
AVRams is offline
post #460 of 906 Old 05-06-2017, 12:06 PM
Liked: 1688
No, my response was an ASSumption. I do not know of any update to fix an issue with the Note 4.
post #461 of 906 Old 05-06-2017, 12:10 PM
muzz's Avatar
Quoted: 748 Post(s)
Liked: 502
If the Note 4 is at least 2gb, HAMMER THEM about it working.
I think they did a different Phone within 24hrs.
Maybe should check again.
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #462 of 906 Old 05-06-2017, 02:58 PM
drh3b's Avatar
Quoted: 219 Post(s)
Liked: 223
I believe @imagic is concurrently reviewing several products right now, plus he's had a lot of requests for specific things. I'm sure he's enjoying himself, but he's probably taking a ton of notes, and it will probably take a while to sort everything out into reviews.
Denon AVR-4520CI
Emotiva XPA Gen3 3 channel
Klipsch RP 280f LR, 260f SR, RC-62 II, RF-82 II SB, RB-61 II wide, RC-10 height
SVS SB12-NSD x4
OPPO UDP-203
TiVo Roamio, sometimes buzzy Samsung Plasma
drh3b is offline
post #463 of 906 Old 05-06-2017, 07:34 PM
ahblaza's Avatar
Quoted: 1666 Post(s)
Liked: 1762
Can someone link the FAQ section of the App, thanks I haven't downloaded it yet as I'm waiting on a iPhone upgrade 7?
ahblaza is offline
post #464 of 906 Old 05-07-2017, 10:47 PM
marco1975's Avatar
Quoted: 64 Post(s)
Liked: 50
Just thought would like to share my result, see how the Audyssey App. is acting differently and inaccurate compairing to the old Audyssey using the AVR.
in the subwoofer graph: (Blue Curve-Audyssey App.) (Red Curve- old Audyssey. AVR.)
Crossovers: first picture (AVR. old Audyssey) Second picture (App. Audyssey)
Both calibration are from exactly the same spot/location
Hopefully if there is some body from Audyssey onboard that maybe can explain why this differents result, specially with the crossover.
ID:	2124201   Click image for larger version
ID:	2124209   Click image for larger version
marco1975 is online now
post #465 of 906 Old 05-07-2017, 11:19 PM
marco1975's Avatar
Quoted: 64 Post(s)
Liked: 50
i think it work this way , the App. receive the measurments reading data from the AVR. but all the calculations for theEQ filters are done within the app. and then send back to the AVR. infact Audyssey are not activated in the AVR. before u send the measurments data from your mobile App. both the App. and the AVR. Version measure quite differently (see the photos i have posted)
post #466 of 906 Old 05-08-2017, 06:59 AM
Liked: 1688
Cool. Then chances are good that in a future revision they will allow the x-overs to be set within the app before calculations.
post #467 of 906 Old 05-08-2017, 09:41 AM
nathan_h's Avatar
Quoted: 1180 Post(s)
Liked: 773
On the one hand, you guys are depressing me because I thought this was going to a good tool for my system and make my upgrade path obvious.
On the other hand, you guys have just saved me $1000 (which is what I would have to spend, after selling my current 6010, to get what I'd want) so my bank account is happy.
BGLeduc likes this.
Check out my current theater & gear.
Listen to the best movie review podcast, the /filmcast.
Don't suffer through Gamma D on your JVC. Optimize HDR Tone Mapping using Arve's tool & Masciola's test patterns instead (hints.)
nathan_h is online now
post #468 of 906 Old 05-08-2017, 12:44 PM
marco1975's Avatar
Quoted: 64 Post(s)
Liked: 50
for now and as its ,i would say u doing the right thing! i sold my Denon 7200WA , and then bought the Marantz 7011, just because i was looking forward to calibrate and further tweak my system with this App. have tried it and its not worth it.
iam back using the old Audyssey, and i have just re-calibrated my system.
post #469 of 906 Old 05-08-2017, 12:54 PM
marco1975's Avatar
Quoted: 64 Post(s)
Liked: 50
That would be a nice bonus, still this App. needs some others fixes beside that.
Notes how the App. (Blue Curve) dealing with the peak i have around 32HZ? and why the rolloff at 20HZ? beside that the App. is allways setting the subwoofer level 5+ hotter than the old audyssey. also i have notes that the system over all sounds its much more louder than the old audyssey.
post #470 of 906 Old 05-08-2017, 01:27 PM
rec head's Avatar
Quoted: 121 Post(s)
Liked: 94
marco1975, Can you please explain how you did your comparison?
rec head is offline
post #471 of 906 Old 05-08-2017, 01:42 PM
Frank D's Avatar
Quoted: 316 Post(s)
Liked: 83
Interesting. Wondering if that is an intended effect. The effect would definitely not be flat. Our hearing starts to diminish below 20z (we can feel it but normally one needs much more power to make a difference).
What model/make/size of sub are you using?
Frank D is offline
post #472 of 906 Old 05-08-2017, 02:32 PM
marco1975's Avatar
Quoted: 64 Post(s)
Liked: 50
u are right about our hearing start to diminish below 20HZ , but then what they should do is try to compensate for that by boosting (if your system is up to the task) and not putting a rolloff, or just leave it as its. just like the AVR. Audyssey Version do (see red curve)
i have 2 x SVS SB13 Ultra and they can play comfortably all the way down to around 12HZ in my room.
post #473 of 906 Old 05-08-2017, 03:09 PM
marco1975's Avatar
Quoted: 64 Post(s)
Liked: 50
Sure, first calibration was done with the Audyssey App. using all 8 position, during the calibration i was marking each mic. position.
and then second calibration was done using the AVR. Old Audyssey, and i was placing the mic. in exactly the same spot/point for all 8 postion from the first calibtation.
i hope that have answered your question, please let me know if i forgot something.
post #474 of 906 Old 05-08-2017, 04:29 PM
d4g
d4g's Avatar
Quoted: 29 Post(s)
Liked: 24
I actually like what the app is doing yes there is still work to be done like the crossover issue my center main and atmos speakers full range but my dipoles are coming in as 150 instead of the usual 80-110. I feel the center speaker vocals are clearer than the MKII with Audyssey pro.
d4g is offline
post #475 of 906 Old 05-08-2017, 04:29 PM
d4g
d4g's Avatar
Quoted: 29 Post(s)
Liked: 24
But I did not use the stander we mic positions I used the closer mic grouping.
d4g is offline
post #476 of 906 Old 05-08-2017, 04:42 PM
Frank D's Avatar
Quoted: 316 Post(s)
Liked: 83
You would think however boosting the below 20 hz will steal the sub amp of much power that can be used more efficiently for the higher sub frequency range. The app is boosting the 25 to 35 hz range and sacrificing the below 20 hz range. Looking at your charts this looks very clear. Maybe they did this thinking that many users may not have capable subs for the under 20 Hz region (ie avoid port noise, and sub bottoming out etc.) when volumes are raised. But someone with capable subs should not have to be punished.
Or it could just be that the App program needs to be fixed. The crossovers themselves look really off using the App.
Can you not just boost the curve in the App for the below 20 hz range and lower the 25 Hz to 35 hz range to compensate?
Frank D is offline
post #477 of 906 Old 05-08-2017, 05:53 PM
rec head's Avatar
Quoted: 121 Post(s)
Liked: 94
Yes that is what I wanted to know. Did you just leave your REW mic in place? If I do comparisons I will only use the first mic position. Then I can leave both mics exactly where they are. But I just need the app to run without crashing.
rec head is offline
post #478 of 906 Old 05-08-2017, 06:22 PM
d4g
d4g's Avatar
Quoted: 29 Post(s)
Liked: 24
App is stable on iPhone 6s plus
d4g is offline
post #479 of 906 Old 05-09-2017, 09:26 AM
marco1975's Avatar
Quoted: 64 Post(s)
Liked: 50
Iam not saying that they should boost belw 20HZ per se , but don,t put a rolloff either , u have said it your self why should someone with capable subs get punished for it.
by the way , the boost u seeing in the graph around 25-35HZ that has nothong to do with the app. boosting or anything like that, its just the natural bass response in my room , actaully i have 2 peaks there , huge one at 33HZ and another small one at around 26HZ. its just the app are not realy doing great job at ironing those peaks like the old Audyssey do.
the curve editor in the app. is useless for this kind of work , i mean when u have to work with very small range. because boosting at 20HZ will mostly also boost 30HZ as well not effective belw 20HZ, and lowering 30HZ will also lower 20HZ anyway i could do this with an external EQ. and i have tried it , but then again what is the point when its messing up the crossover for my speakers big time.
post #480 of 906 Old 05-09-2017, 09:34 AM
marco1975's Avatar
Quoted: 64 Post(s)
Liked: 50
what i did exactly was that , after the first calibration , i put the tripod in the first position(main listening position) removed the Audyssey mic. from the tripod and then mount my Umik-1 mic. took a reading with Rew, and did the same thing with the second cailbration.
Audyssey , Denon , Marantz , multeq editor app
