MultEQ Editor: New App for Denon & Marantz AV Receivers & Pre/Pros - AVS Forum | Home Theater Discussions And Reviews
 576Likes
post #1 of 945 Old 04-05-2017, 08:56 AM - Thread Starter
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 5874 Post(s)
Liked: 10288
Denon and Marantz officially launched the MultEQ Editor app for iOS and Android today for $20. Owners of numerous AV receivers from the two companies will gain this feature, which will also be included in select (as in most) 2017 models as well. Click the link to read more: http://www.avsforum.com/denon-marant...eq-editor-app/
mtbdudex, Reddig and zibaji like this.
Mark Henninger (aka Imagic)
imagic is online now
post #2 of 945 Old 04-05-2017, 09:26 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 764
This app definitely ups the game for Audyssey vs other room correction options.
My work friend has a Marantz SR 6011, his room is just being finished this week, speaker layout is 5.2.4., DIY soundgroup all around 1099's up front, Fusion-8's rears, and Volt-10 for the top. One 18" ported sub to start, then he will add a 2nd one this fall.
We will use this app to help fine tune the acoustics, along with REW and treatments.
mtbdudex is offline
post #3 of 945 Old 04-05-2017, 09:28 AM
tjcinnamon's Avatar
Quoted: 1071 Post(s)
Liked: 255
Would 7010 be classified as 2016?
bommai likes this.
Marantz 7010 for 7.2.4
2 x Paradigm Prestige 75F's
1 x Paradigm Prestige 45C
8 x Paradigm CI Pro P65-R's
Sub 2 x Rythmik LVX12's
TV: LG 65B6
tjcinnamon is offline
post #4 of 945 Old 04-05-2017, 09:33 AM - Thread Starter
imagic's Avatar
Liked: 10288
I'll stay away from details. Edited.
Here's the list, I did not explicitly check release dates for each one.
The following existing AV Receivers will support the MultEQ Editor: Denon AVR-X6300H, AVR-X4300H, AVR-X3300W, AVR-X2300W, AVR-X1300W, AVR-S930H, AVR-S730H, AVR-S920W, and AVR-S720W. Also, Marantz AV7703, SR7011, SR6011, SR5011, and NR1607.
post #5 of 945 Old 04-05-2017, 09:35 AM
DreamWarrior's Avatar
Quoted: 421 Post(s)
Liked: 297
Does this, "adjust the overall EQ frequency roll-off for each channel pair", mean the high-end roll-off or does it mean the EQ "rolls off" (i.e. stops correcting) at a chosen frequency?
Or, to get to the point, can we use this to select the frequency that EQ stops working so it only EQs the bass? Such a thing may be nicer than the "L/R off" feature for those who run their mains at lower crossovers or full-range.
bjaurelio likes this.
DreamWarrior is online now
post #6 of 945 Old 04-05-2017, 09:36 AM - Thread Starter
imagic's Avatar
Liked: 10288
Edit- not sure, wording is not totally clear, will check into it.
post #7 of 945 Old 04-05-2017, 09:50 AM
Quoted: 421 Post(s)
Liked: 297
Doesn't make sense to have a select-able roll-off (in the classic sense of the word) when the curve definition should already tell it how to roll-off the highs.
I wonder if they didn't mean cut-off instead; regardless, I just want to know if I can instruct it at what frequency to stop applying EQ to my mains, lol. Thanks for inquiring.
post #8 of 945 Old 04-05-2017, 09:53 AM
bjaurelio's Avatar
Liked: 32
If I were able to disable the room correction above 200hz, I would enable Audyssey. Above that region all it's doing is harming the flat frequency response from the direct sound to make the reflections sum flat in the average of multiple locations.
nathan_h and BGLeduc like this.
bjaurelio is online now
post #9 of 945 Old 04-05-2017, 09:55 AM
Molon_Labe's Avatar
Quoted: 2104 Post(s)
Liked: 2186
In a subsequent story, there appears to be a sudden, unexplained flurry of Denon and Marantz units heading to the AVS for-sale threads.
muzz, sdrucker, turbonut and 6 others like this.
Molon_Labe is offline
post #10 of 945 Old 04-05-2017, 10:00 AM - Thread Starter
imagic's Avatar
Liked: 10288
OK found this on iTunes, so it looks like we are talking about an adjustable range for the EQ. Sorry no details, I'm trying to get a compatible device to try this out ASAP.
post #11 of 945 Old 04-05-2017, 10:08 AM
shoeboo's Avatar
Quoted: 48 Post(s)
Liked: 48
Yes, can choose upper frequency that the room correction is applied up to. I have mine set to 150 hz (Schroeder for my room) and am only getting corrections below this.
You can also tailor the curve to remove roll-offs or add house curve and there is a setting to remove midrange compensation (BBC dip) automatically.
shoeboo is online now
post #12 of 945 Old 04-05-2017, 10:11 AM - Thread Starter
imagic's Avatar
Liked: 10288
Lots of what made Dirac so great to use, now in Audyssey. Awesome.
post #13 of 945 Old 04-05-2017, 10:18 AM
b0rnarian's Avatar
Quoted: 1146 Post(s)
Liked: 542
Wonder how easy to use the app will be for a newbie like me who don't understand much of frequency's etc. Still, my next AVR is def. either a Denon or a Marantz b/c of this awesome feature.
srinivas1015 likes this.
Best,
Main Living Room: Samsung 65 KS9800 + Audio: Onkyo HT-S6300 7.1 + Sony UBP-X800 + PS4
Other Living Room: Panasonic Plasma 55 + Onkyo Home Theater System 5.1 + PS3
Currently For SALE : UHD Media & Codes
b0rnarian is online now
post #14 of 945 Old 04-05-2017, 10:18 AM
turbonut's Avatar
Quoted: 39 Post(s)
Liked: 32
Originally Posted by Molon_Labe View Post
In a subsequent story, there appears to be a sudden, unexplained flurry of Denon and Marantz units to the AVS for-sale threads.
You speak the truth. *stroking beard while thinking of how to tell the wife I need a new receiver*
This looks like it could be very good. I'm excited to see more info as people start using the app!
My Humble Theater
turbonut is offline
post #15 of 945 Old 04-05-2017, 10:19 AM
tjcinnamon's Avatar
Liked: 255
they have that. It's called LFE+Main. It'll push the sub crossover frequencies to the subs as well as the mains.
TV: LG 65B6
post #16 of 945 Old 04-05-2017, 10:22 AM
tjcinnamon's Avatar
Liked: 255
no 7010. From a sales perspective I get it; from a customer service perspective I'm let down.
TV: LG 65B6
post #17 of 945 Old 04-05-2017, 10:24 AM
Molon_Labe's Avatar
Liked: 2186
This is a big plus for Audyssey owners, but I don't think its going to close the gap on the superiority of Dirac's algorithms and impulse response corrections vs Audyssey. The target editor is just icing on the cake with Dirac. Still a big win though and something that Audyssey has been far too long missing.
OzHDHT, stef2 and Fattykidd like this.
post #18 of 945 Old 04-05-2017, 10:25 AM
genesplitter's Avatar
Quoted: 56 Post(s)
Liked: 38
I have a Marantz 7009 with MultEQ XT32 (the best version) and I keep Audyssey disabled at all times because I don't want it to EQ frequencies above the room transition frequency (around 200 - 500 Hz for most rooms). This is a huge improvement if you can EQ only the bass frequencies and your receiver is compatible.
nathan_h likes this.
U-Turn Orbit Plus turntable, Marantz SR-7009 AVR, iNuke 6000DSP, DIY LinkwitzLab speakers, MartyCube + JohnnySub, BenQ W1070, Roku stick, Plex
genesplitter is online now
post #19 of 945 Old 04-05-2017, 10:27 AM
stef2's Avatar
Quoted: 390 Post(s)
Liked: 236
It looks to me like Dirac is way ahead of what Audyssey does. An iPad app will barely help fix that.
stef2 is offline
post #20 of 945 Old 04-05-2017, 10:32 AM
Quoted: 421 Post(s)
Liked: 297
Sounds good, but...if I tell it not to correct above 150hz why would the MR compensation play a part, shouldn't it leave that alone when I tell it not to touch anything above that? Or is that a separate thing (along with the HF rolloff selection)?
That's not what I was driving at. The "L/R off" I was speaking about was a feature selection to turn EQ all the way off on the mains. But, if you're listening to your mains without a sub, you probably want some EQ there below Schroeder. So, only having the choice to EQ everything or nothing isn't desirable; especially so for these folks.
post #21 of 945 Old 04-05-2017, 10:37 AM
bjaurelio's Avatar
Liked: 32
Between this announcement and the poll showing that most people find Atmos more immersive than HDR, I may have to adjust my priorities to upgrade my AVR and figure out how to add ceiling speakers. I can easily reach the attic above the living room which may give me more options.
post #22 of 945 Old 04-05-2017, 10:38 AM
dan webster's Avatar
Quoted: 182 Post(s)
Liked: 139
So sad that my flagship marantz 8802a cant use this. Strange that Marantz s current flagship piece of equipment cant somehow be updated to accept this.
Schwa, nathan_h, markrubin and 8 others like this.
Dolby Atmos 7.2.4 Marantz AV8802a processor Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 Sony UBP-X800 4K Ultra HD Blu-ray Jvc RS500 projector Vivitek 1186 projector
Carada 110"BW screen Monster HTS 5100 MK11 power conditioner
Golden Ear Triton 5 L&R &super center XXL triton 7's sides Martin logan motion 12 rears
4 RSL C34 in ceiling SVS PB2-plus sub Outlaw LFM-1-plus sub
dan webster is offline
post #23 of 945 Old 04-05-2017, 10:49 AM
gregoryperkins's Avatar
Quoted: 474 Post(s)
Liked: 180
Let's hope there will be more. I have an 8 month old x4200!
gregoryperkins is offline
post #24 of 945 Old 04-05-2017, 10:55 AM
shoeboo's Avatar
Quoted: 48 Post(s)
Liked: 48
Correct, separate things. If you limit frequency below BBC dip you don't even see that part of the curve. But if you were behind an acoustically transparent screen or have a particularly live room some full range EQ may be appropriate and it is soooo much more flexible now.
What is interesting (but I haven't actually tested to see if it works in the receiver) is that you can edit the correction curve below what I assume is the calculated roll-off of the speaker. It defaults to a smooth roll-off but can be edited. Could be helpful in some circumstances.
DreamWarrior likes this.
post #25 of 945 Old 04-05-2017, 11:00 AM
tron49's Avatar
Quoted: 136 Post(s)
Liked: 38
Unhappy Feel the same about my X7200WA
I can't imagine why the Denon X7200WA won't be able to utilize this app. but every AVR model below it can.
This sucks.
SONY XBR75X850C; OPPO 95; DENON AVR-X7200WA; PS Audio P10 Power Plant; Sony FMP-X10; (2) Mirage OMD-15, (2) OMD-R, (2) OMD-5, Omni S10, OMD-C2; Apple AirPort Extreme_ac network; Comcast Internet 350 MBs; Harmony Ultimate Home w/Hub;
Life is but a beautiful dream and death is it's rude awakening.
tron49 is offline
post #26 of 945 Old 04-05-2017, 11:06 AM
dman918's Avatar
Quoted: 383 Post(s)
Liked: 117
Can someone explain, in simple terms, what this app gives the average user that may want to do basic tweaking etc.
ez1dog likes this.
Sony XBR-75X850D TV
Denon X4300 Receiver
(3) Elusive 1099s LCR - (4) Polk RC85i Surrounds
iNuke 3000dsp powering a Dayton Ultimax UM18 in a Minimarty
iNuke 6000dsp powering (2) SI HT18s in Martycubes (Nearfield)
dman918 is offline
post #27 of 945 Old 04-05-2017, 11:18 AM
groove93's Avatar
Quoted: 161 Post(s)
Liked: 86
Not too long ago I noticed that one of the two Marantz Android Apps stopped working after it was updated. Now I'm down to one for the 7010. This new Audyssey app not being available for the 7010 as well, I guess I'll work both Audyssey and REW together.
groove93 is online now
post #28 of 945 Old 04-05-2017, 11:23 AM
tjcinnamon's Avatar
Liked: 255
ahhh, I see. Sounds like a cool idea.
TV: LG 65B6
post #29 of 945 Old 04-05-2017, 11:53 AM
adrummingdude's Avatar
Quoted: 483 Post(s)
Liked: 319
Yes, that's the whole point of room correction. If you were to have a floating room full of non parallel surfaces, diffusers, and traps, you wouldn't need room correction tools. Most of us don't have that, therefore we do.
sdrucker and smo0thie like this.
HT: B&W 802 D2 - DefTech Mythos Ten - DefTech XTR-20BP - Dual SVS SB16 Ultra - Parasound Halo A21- Anthem MRX 720 - Samsung UN65JS8500
2CH: Sonus Faber Cremona Auditor M - Parasound Halo A23 - Bluesound Node 2 - Iomega NAS
WAF is currently at DEFCON RED
adrummingdude is offline
post #30 of 945 Old 04-05-2017, 12:22 PM
Madmax67's Avatar
Quoted: 611 Post(s)
Liked: 649
Well then it's a good thing Audyssey isn't really in direct competition with Dirac or to put it in an analogous form , "Audyssey doesn't have to outrun the bear (Dirac) they just have to outrun you!"( YPAO, MCACC,DCACC, AccuEQ)
sdurani, mthomas47 and v6viking like this.
Madmax67 is offline
Audyssey , Denon , Marantz , multeq editor app
