AVR Suggestions for the following setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 05-19-2017, 12:07 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 1
I am piecing together a setup primarily for movies/sports, less so for music (maybe 80/20). My plan is to start off with a good mid-level 2.1 setup (VTF-2 MK5 & RBH RB5iRs), Projector is still TBD.
I am looking for a receiver which will offer good performance without breaking the bank (thinking maybe $300 and under). While some offer all sorts of bells and whistles, I am just not sure which ones I really care about.
  • I can see myself extending to 5.2, and possibly 7.2 down the road.
  • I will be ~12' from a 100" screen, so I don't know how much I really require 4k over 1080p.
  • I may need enough HDMI ports to hook up various things (gaming consoles, apple tv, etc)
Would something like Denon 720W or Yamaha RX-V481 be good fits? Can I do with something simpler? Do I need to go bigger? Again, I would like to get the most out of my setup while avoiding costly overkill.
mcatta08 is offline
post #2 of 17 Old 05-19-2017, 03:14 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 1
Puppy bump.
mcatta08 is offline
post #3 of 17 Old 05-19-2017, 03:36 PM
afrogt's Avatar
Quoted: 1435 Post(s)
Liked: 982
Where are you located? Fry's has the new Denon s730 for $299 this week with promo code. It is an In store only deal though.
Afro GT
afrogt is offline
post #4 of 17 Old 05-19-2017, 04:03 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 1
Nowhere near frys unfortunately (Connecticut). What about the other ones I mentioned, are those good options?
mcatta08 is offline
post #5 of 17 Old 05-19-2017, 04:15 PM
afrogt's Avatar
Liked: 982
I would get this over either of your choices.
http://www.accessories4less.com/make...eceiver/1.html
Afro GT
afrogt is offline
post #6 of 17 Old 05-19-2017, 04:28 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 1
Thanks for the suggestion; I'll definitely take a look. If i may ask, what does the 1300 include that the other options don't? I'm still trying to wrap my head around all the features
mcatta08 is offline
post #7 of 17 Old 05-19-2017, 04:44 PM
afrogt's Avatar
Liked: 982
the x1300 is the s720 with an upgraded version of Audyssey MultEQ XT. And it also has a set of Zone2 preouts so you can run 7.2 in the main area and still be able to send audio to zone 2 by adding an external amp. And new x1300 vs new s720 has a 3 year warranty vs 2 year.
the RX-V481 is only a 5 channel receiver. No expand-ability, no Zone 2, only 4 HDMI inputs. Lesser version of room calibration. I would cross that off my list.
Afro GT
afrogt is offline
post #8 of 17 Old 05-19-2017, 05:55 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 1
Great, thanks for the additional insight. Is the 1300 really at the low-end of what you would suggest? I mean, I don't have a hard cap necessarily, but this one is at the higher end of what I was considering. Are there a couple cheaper alternatives which, while maybe not as good, would be acceptable for general use (and somewhat futureproof)?
mcatta08 is offline
post #9 of 17 Old 05-19-2017, 07:47 PM
afrogt's Avatar
Liked: 982
How much cheaper are you trying to go? You said your budget was $300 and under.
Afro GT
afrogt is offline
post #10 of 17 Old 05-19-2017, 08:58 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 1
I meant lower. And yes, I could technically go higher (if there was a substantial performance improvement) but I am just trying to keep myself in line. Like many others who visit these forums, you usually end up 2-3x (or more) higher than what your initial budget was (as I did for both the sub and the bookshelves!)
So I am curious if there are some other, cheaper alternatives, which I should also keep an eye on.
mcatta08 is offline
post #11 of 17 Old 05-20-2017, 07:39 AM
Broadus's Avatar
Quoted: 286 Post(s)
Liked: 116
I doubt you'll beat the refurbished Denon X1300W that afrogt linked. $299 with a 3-year warranty thrown in for free is really enticing.
If you want to bump it up a bit, I've had my eye on the Yamaha TSR-7810 (a relabeled RX-V781) at Costco for $490, but like you said, forums can help produce budget inflation. Would it bring anything to your table that the Denon X1300W doesn't? Perhaps someone more knowledgeable than I can comment on that.
Whatever way you go, I hope you the best in your choice.
Edit: I'm curious--what sub and bookshelf speakers did you get?
Broadus is offline
post #12 of 17 Old 05-20-2017, 09:14 AM - Thread Starter
Quoted: 24 Post(s)
Liked: 1
I haven't purchased yet, but after countless hours of deliberation, I am likely going w the HSU VTF-2 MK5 sub and RBH R5Bi bookshelves. I know everyone will tell me to go for the VTF-3 but the VTF-2 is already well beyond my initial budget and I'm good w going dual if I need more down the road
Thanks for the additional thoughts on the 1300. I'll probably end up going with that
mcatta08 is offline
post #13 of 17 Old 05-20-2017, 10:30 AM
Broadus's Avatar
Quoted: 286 Post(s)
Liked: 116
From what I've gathered, those are solid choices on the speakers and are at a good price point for the quality you're getting. I came to the forum looking to upgrade my old Sony 2.0 and ended up spending more than I anticipated, ordering a pair of Q Acoustics Concept 20 bookshelf speakers, a Concept Center Channel speaker, and an SVS NB12 sub. I like my new system, especially considering that the QA speakers had a substantial price increase the evening after I ordered them that afternoon. However, I suspect I would have liked the RBH R5bi just as well. I think you did well.
Broadus is offline
post #14 of 17 Old 05-20-2017, 01:25 PM
s44
s44's Avatar
Quoted: 17 Post(s)
Liked: 25
If it's mostly movies/sports, why not go all-Hsu with the HB-1 (since the very cool coax speakers are likely out of budget)? They're sold together at a bit of a discount and the higher efficiency and power handling should do wonders for movies, both for high-volume bits and dialogue clarity. 85dB mains for HT are a serious compromise.
s44 is online now
post #15 of 17 Old 05-20-2017, 04:03 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 1
Looks 799 for the package vs 817 individually. Oddly, the package also appears to be out of stock (despite being able to construct it separately). Not a huge discount but id certainly still consider it as an option. Is an 85db really that limiting compared to the 92db HSUs; it doesnt seem very significant, but i am pretty green on this topic.
mcatta08 is offline
post #16 of 17 Old 05-20-2017, 04:15 PM
s44
s44's Avatar
Quoted: 17 Post(s)
Liked: 25
It takes double the amplifier power to get a 3db increase.
s44 is online now
post #17 of 17 Old 05-20-2017, 05:19 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 1
I definitely see myself cranking up the volume a bit for some movies, but would this difference be realized at moderate volumes?
Regardless, this still sounds like a very good speaker, I'm just trying to figure out if it's something that I will utilize.
mcatta08 is offline
