5.2 Channel Denon AVR-S510BT - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jdsmoothie
post #1 of 11 Old 09-17-2017, 09:35 AM - Thread Starter
Liked: 0
All,
I'm a newbie and trying to setup speaker system in my living room which was pre-wired.
got Denon AVR-S510BT and installed two front, one center, two rear speakers in the wall, and i see 5 input options behind the Receiver for all 5 speakers, but i got two more pre-wired in my patio, i dont see any option to add them into my reciever, not sure, this receiver doesnt support or i'm not able to understand how to do it. would you please take time and explain how it works, since i'm newbie, it is very confising for me.
Thank You All.
manchem is offline
post #2 of 11 Old 09-17-2017, 09:46 AM
jdsmoothie's Avatar
Quoted: 15365 Post(s)
Liked: 7513
Only Denon 7CH models support Zone 2. The S510BT is only a 5CH model so no Zone 2 support.
Madmax67 likes this.
jdsmoothie is offline
post #3 of 11 Old 09-17-2017, 09:51 AM - Thread Starter
Liked: 0
Thank You for your response.
another quick question, I got sub woofer Polk PSW10 and it has two outs, do i need to use both to the receiver or only one is sufficient, it is saying 1 and 2 outs, not sure what does it mean.
Thank You
manchem is offline
post #4 of 11 Old 09-17-2017, 06:41 PM
Madmax67's Avatar
Quoted: 846 Post(s)
Liked: 947
Thank You
No dedicated LFE input on the sub so just use the single left white line input on the sub coming from a single sub pre output in the receiver. Either one will do.
You're very welcome.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. http://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #5 of 11 Old 09-17-2017, 06:49 PM
Madmax67's Avatar
Quoted: 846 Post(s)
Liked: 947
Also without an LFE input you want to make sure to set the subwoofers low pass filter knob to it's highest setting. This allows the receiver to handle the bass management instead of the sub.
Madmax67 is offline
post #6 of 11 Old 09-18-2017, 06:47 PM - Thread Starter
Liked: 0
Thank You for your response, I do appreciate it.
manchem is offline
post #7 of 11 Old 09-19-2017, 12:03 AM
Madmax67's Avatar
Quoted: 846 Post(s)
Liked: 947
No problem and good luck.
Madmax67 is offline
post #8 of 11 Old 09-19-2017, 06:57 AM - Thread Starter
Liked: 0
i was able to connect all my speakers and Receiver and able to play using my Iphone through Bluetooth, however my video is not working from any source, i have a old DVD player and Xbox 360, both were working when i connect directly to the TV but when i connect to Receiver audio is working from both and no video showing up, just so you know, both has 3 wires (red,white,yellow)
manchem is offline
post #9 of 11 Old 09-19-2017, 06:57 AM - Thread Starter
Liked: 0
any help is appreciated
manchem is offline
post #10 of 11 Old 09-19-2017, 07:02 AM
jdsmoothie's Avatar
Liked: 7513
The S510BT cannot do analog --> HDMI video conversion. You must also connect a yellow composite video cable from the AVR to the TV.
Please post additional questions in the dedicated Owner's thread linked below.
The "OFFICIAL" 2015 Denon "S-series" / "X-series" AVR Owner's thread + FAQ (HDCP 2.2)
post #11 of 11 Old 09-19-2017, 07:08 AM - Thread Starter
Liked: 0
Thank you for the response. next time i will use the thread as you suggested.
manchem is offline
patio speakers , pre-wire , receiver
