Is 5.1 Toslink Acceptable? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By asabrag
post #1 of 3 Old 09-19-2017, 04:23 PM - Thread Starter
Quoted: 121 Post(s)
Just how bad is 5.1 Toslink? I am a fairly impulsive individual, and decided to go with an old Toslink Denon surround receiver to cut costs, avoid low quality components, and to ensure I wouldn't have to worry about hdmi 3d pass through for the projector. Of course it was only after buying it that I read about the significant advancements in lossless audio formats. I'm just using a cheap set of Jamo's for the speakers, the room isn't treated at all, and I very rarely watch bluray quality content. Am I going to notice a serious loss of quality, or is it more like the difference between a good 320kbps mp3 vs lossless FLAC?
AVMB is offline
post #2 of 3 Old 09-19-2017, 05:57 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
IMO the lossless audio formats are not significant. If you know anyone that has a decent blu-ray player and an up to date AVR that plays lossless audio over HDMI you can demonstrate this for yourself. Just switch the AVR to use the optical input from the blu-ray player and take a listen. Are there differences to be heard? Yes. It just isn't earth-shattering differences.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 3 Old 09-19-2017, 08:58 PM
Quoted: 37 Post(s)
Really? It's like comparing a 1984 Ford Sierra with a 2016 Fusion.
Yes, both will take you from A to B.
I wouldnt buy a Sierra today except to display it in a museum.
Poepsnor likes this.
asabrag is offline
