Center channel speaker not working on Harman Kardon AVR-230 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-20-2017, 04:27 AM - Thread Starter
Liked: 0
I just purchased the HK avr230 (used) and had it for about 4 days now. I've hooked everything up and no sound will come from the center speaker. I have ran a tone test for all three channels and the tone DOES come from the center but no sounds/voices at all. I have hooked up bluray player to the receiver via optical cable to test it and it still does not work. The audio is playing as if the center channel is there (Dialogue is quiet when centered on the screen), but still no audio. I have also hooked the center channel speaker to the left and right channels to make sure it works fine and it does.Already did the factory reset hoping it will works but same result. I would appreciate any and all suggestions! Thank you!
ezar is offline
post #2 of 5 Old 09-20-2017, 04:58 AM
jdsmoothie's Avatar
Quoted: 15333 Post(s)
Liked: 7488
Are you using a multi channel surround mode and not STEREO? If yes, return it and get your money back.
jdsmoothie is online now
post #3 of 5 Old 09-20-2017, 05:51 AM - Thread Starter
Liked: 0
im running multi channel
ezar is offline
post #4 of 5 Old 09-20-2017, 10:33 AM
Dargent0628's Avatar
Quoted: 119 Post(s)
Liked: 57
Make sure you have your center channel selected (yes) in your receiver's speaker configuration set-up
Sent from my XT1585 using Tapatalk
Dargent0628 is offline
post #5 of 5 Old 09-23-2017, 03:37 AM - Thread Starter
Liked: 0
it is already selected
ezar is offline
