Pseudo-Official 3805 Thread - Page 90 - AVS Forum
post #2671 of 2681 Old 07-14-2009, 04:27 PM
tsteves's Avatar
danoeltico
Did it work fine before changing rack/stand? I have a salamander myself, which I love, but it did not stop anything from working!
Did you redo the setup or just plug everything back into the same places? Maybe you didn't write things down, and changed something? (my usual culprit)
tsteves is offline
post #2672 of 2681 Old 07-14-2009, 08:23 PM
JBaumgart's Avatar
Originally Posted by tsteves View Post
danoeltico
My rather complicated system is such a tangled mess of wires it's unbelievable. Left and right subs connected to the L/R mains, a separate L/R/C amp, a separate LFE sub, and now two DVD players, one of which uses D-Link and the other using EXT-IN analog. I've learned that whenever I change something I always mark each connection so I know exactly where it was plugged into before making the change. Someday I hope to simplify things somewhat using HDMI connections, but for now I am very happy with the way everything sounds.
JBaumgart is offline
post #2673 of 2681 Old 07-15-2009, 06:59 AM
danoeltico's Avatar
tsteves
Everything did work fine before hand, I know it isn't because of the stand, it is something with the Denon I guess. I did redo the set up, and tried every different component input on the back then changed the input in the setup and nothing. Like I said, I can get signal from the dvd player to go through, but nothing from the XBOX. The XBOX will work when I plug it directly into the TV, but not through the denon. I've even tried changing the output resolution of the XBOX and nothing...
Love my BDP-09!
danoeltico is offline
post #2674 of 2681 Old 07-15-2009, 02:19 PM
tsteves's Avatar
JBaumgart
3 Subs?! You are a Mans Man!
tsteves is offline
post #2675 of 2681 Old 07-15-2009, 02:22 PM
tsteves's Avatar
danoeltico
So even if you set the DVD player and Xbox to the same resolution and then swap inputs, nothing?
You may be in the A/V twilight zone!
tsteves is offline
post #2676 of 2681 Old 07-15-2009, 07:43 PM
JBaumgart's Avatar
JBaumgart
The real benefit is that the L/R subs allow for clean bass all the way down to 20hz from the main speakers, and allow these speakers to be set to "large" after doing the auto calibration. This provides "stereo bass" that improves imaging throughout the entire frequency range, and the separate (Odyssey) amp provides a more detailed sound and higher volumes than the 3805 can deliver on its own.
I am very happy with the sound, but it sure would be nice to have HDMI in the receiver which would eliminate some of the wires and allow room/frequency EQ from my new Oppo BDP-83.
post #2677 of 2681 Old 11-30-2009, 04:10 PM
SoNic67's Avatar
Liked: 29
Does anybody have a service manual for the 3805?
The search function sucks and I tried to go manually thru 2675 posts but it is not working...
SoNic67 is offline
post #2678 of 2681 Old 11-30-2009, 09:44 PM
JBaumgart's Avatar
I have the Owner's Manual, if that's what you mean, in PDF format. If you post your email I can send you a copy.
post #2679 of 2681 Old 11-21-2011, 04:10 AM
gchuva's Avatar
Is there a way to adjust the volume settings for different inputs? My dvd players plays a lot louder than my tv, and they both use coaxial, but I don't know how to adjust.
gchuva is offline
post #2680 of 2681 Old 11-21-2011, 08:06 AM
BIslander's Avatar
Quoted: 47 Post(s)
Liked: 126
Denons allow for separate settings by surround mode, not by input. That includes trimming levels. So, you could assign different surround modes to the usual types of audio from the TV and DVD player.
I don't have a manual handy. But, as I recall, the information is in the surround modes section.
BIslander is offline
post #2681 of 2681 Old 11-21-2011, 01:34 PM
pbarach's Avatar
Quoted: 43 Post(s)
Liked: 91
The advice given is true for the 3805, but some other Denons do allow differing levels to be set for each input (I replaced my 3805 with a 4310 that does have that feature.
AT&T U-Verse Northeast Ohio
Denon x4000, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, etc.
pbarach is offline
User Tag List
