Carver RH17 Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-25-2004, 01:16 PM - Thread Starter
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
Looking for a remote, working or non-working..for a Carver CT17 Preamp
Or, a Carver PRH-1 Universal Remote
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #2 of 4 Old 04-27-2004, 11:53 AM
Gig103's Avatar
RemoteCentral has IR codes for universal remotes:
Link
HTH.
Gig103 is offline
post #3 of 4 Old 04-27-2004, 12:35 PM
RIT
RIT's Avatar
bdfox18doe, is the ct 17 still working ? I've had mine since 1990 still working . Look on ebay the ct17 comes up every now and then ... Rit
Home theater on a budget.
RIT is offline
post #4 of 4 Old 04-27-2004, 12:42 PM - Thread Starter
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
RIT,sorta..
the pads had worn out on the volume control, so I took it apart, and cut
the rubber pad between the 4th and 5th row, and flipped around. This moved "bad" buttons to key's I don't use. So, I should now be able to get another 15 years out of it hopefully. But If I can get another one I probably will. Found several Carver remotes on Ebay, but none of this one yet.
Bob
Closed Thread Receivers, Amps, and Processors
