Best way to connect tv/dvd - AVS Forum | Home Theater Discussions And Reviews
Old 09-09-2004, 09:00 AM - Thread Starter
cbeldoch's Avatar
Hi All,
I would like to know what is the best way to connect the following:
Cable tv and dvd player directly to the moniter with audio through the receiver
or
Cable tv/dvd player directly to the receiver and then to the monitor
I have a Fujitsu plasma monitor and the Yamaha RX-Z9 receiver
I have a HD digital cable box
I would appreciate all thoughts on this
Chris
cbeldoch is offline
Old 09-09-2004, 10:42 AM
wmallory's Avatar
General rule of thumb is to minimize the interconnects so "Cable tv and dvd player directly to the moniter with audio through the receiver" would be best. However, as long as your receiver had enough video bandwidth (or was one of the rarer ones that use relays to switch video), you probably wouldn't see much (or any) difference.
wmallory is offline
