Using video out / tape out as pre-out? - AVS Forum | Home Theater Discussions And Reviews
Old 12-17-2004, 01:14 AM - Thread Starter
silbi's Avatar
Just curious.
If a receiver has no pre-out connection to connect to a power amp to drive the front speakers, is it possible to use the video out or the tape out as a pre-out?
Anyone has tried this? Any success stories?
i am lost so i am cruel
silbi is offline
Old 12-17-2004, 01:19 AM
rynberg's Avatar
No, it will not work. The tape-outs are at a fixed output level. You would need a volume control between the tape-outs and your amps, which is what your receiver is doing!
What component are you using that doesn't have pre-outs?
rynberg is offline
Old 12-17-2004, 01:24 AM - Thread Starter
silbi's Avatar
I have an entry level receiver which doesn't come with pre-outs. But somebody has kinda told me that this would work...so I'm a bit confused.
Any other thoughts?
silbi is offline
