Denon AVR-5805 Arrived..... - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 1350 Old 04-18-2005, 07:34 AM
ted_b's Avatar
Originally posted by aaronwt
Why would someone spend over $5k on a receiver, only to spend $100 on a rack to put it in?
A) Spent all his budget and only has $100 left
B) Typo; meant to read "$1000"
C) Realizes that racks don't add much to the sound of a system and puts his money where it counts
Just make sure the rack is sturdy enough to hold that beast.
Ted
"We're all bozos on this bus" - F.T.
ted_b is offline
post #272 of 1350 Old 04-18-2005, 01:29 PM
Xezoid's Avatar
Thanks for the reply Mr. ted_b. The weight I estimate(It's still on the floor) after hooking up the cables will add 25 pounds at least to the weight which is already 100 pounds!!! I've decided to go to a welding shop and have them make me one.
A $100 rack I believe is just being naive on my part to which Mr.aaronwt is right. After staring at it for a couple minutes I just can't justify myself spending more money just to integrate this rcvr. Now that the hangover is gone I pretty well damn sure whatever rack I put this on will not tip over or bend! I live in SoCal and earthquakes are common.
Sold some of my treasured comic books to offset the cost of this rcvr.
I promise not to complain & whine 'coz I get HD for free.
Xezoid is offline
post #273 of 1350 Old 04-18-2005, 01:49 PM
DreamCatcher's Avatar
I've been doing some comparing of video quality through the 5805 between HDMI/DVI and Component output.
To my eyes and with my display (Panny 65" 7U) the component output looks a little better when viewing HD/SD DirecTV material. (with the exception being DVD material viewed via HDMI from the Denon 5910 which is phenomenal!)
Previously I've always preferred the digital video output of a given source vs component output, usually fed directly to my display, but now......
A friend of mine suggested that it may well be the Progressive video processing & scaling of the 5805 (Faroudja DCDi) that's doing a better job than my source components &/or display.
Any thoughts boys and girls.....
dc
StayThristyMyFriends
DreamCatcher is offline
post #274 of 1350 Old 04-18-2005, 05:26 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
Same source, same connections and cables, but bypassing the 5805, which looks better?
______________________
__________
Dave
moonhawk is offline
post #275 of 1350 Old 04-18-2005, 05:32 PM
HDMI/DVI looks slightly better...........
A friend of mine and I are in the process of setting up a comparsion between component straight into display vs component through the 5805.
dc
post #276 of 1350 Old 04-18-2005, 05:49 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
I guess I meant does HDMI/DVI look better than component, when you bypass the 5805 with both.
Let us know, thanks.
__________
Dave
moonhawk is offline
post #277 of 1350 Old 04-18-2005, 05:59 PM
hjones's Avatar
If you happen to be using a HD TIVO, some users have noted that the component output looks better than the HDMI. That's the case for me, using a NEC HT-1000 projector. So, that is one variable that is outside the control of the 5805.
hjones is offline
post #278 of 1350 Old 04-18-2005, 06:20 PM
Yes, HDMI/DVI looks slightly better than component when routed directly to display, but HDMI/DVI looks no better or worst when routed through the 5805.
dc
post #279 of 1350 Old 04-18-2005, 10:10 PM
Jake Sm's Avatar
Could we get an updated head count of who owns one and "unmentioned/atypical" pros 'n cons ?
Seeking a speaker recomendation? Compare for yourself or be swayed by others who hear differantly, or by marketing, or just save time and get the cheapest , nicest looking, or smallest.
Jake Sm is offline
post #280 of 1350 Old 04-18-2005, 10:39 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
dc
How do you like the sound overall, and do you like Audessey for both music and movies?
__________
Dave
moonhawk is offline
post #281 of 1350 Old 04-18-2005, 11:49 PM
dc
I prefer Audyssey EQ for just about everything, music and movies, hi-rez multichannel material, SACD, etc...
I haven't dialed in 2-channel music sound however. Audyssey with 2-channel material (compared to Audyssey switched OFF) brings an improved soundstage, crisper mid-range, a little more depth, vocals sound richer/cleaner, but the bass lines seem to almost dissappear compared to Audyssey switched off. This may be my setup problem since I've had the Direct/Stereo settings on the 5805 set to run my mains full w/ no sub. I've been playing with the settings recently, swtiching to Small mains w/sub (and/or Large w/sub, also an option) and crossover set to 60 or 80 with Audyssey turned ON, which has brought back the bass lines. So I'll continue to play with the settings for Advance Playback Modes (Direct/Stereo mode) within the 5805 menus until I get 2-channel sound dialed in to my liking and keep Audyssey turned ON because of all the attributes it brings to the sound.
I do wonder however if a user wanted to run their Mains full range with no subwoofer, would they be missing the bass when Audyssey is turned on? Or are my mains just a little too "anemic" to be run full range? Or is their placement not ideal? (probably)
btw 5805 cons?
big
heavy
expensive
5805 pros
everything else
dc
post #282 of 1350 Old 04-19-2005, 05:44 AM
Flying Ed's Avatar
What are the differences in the EQ options on the Denon 5805 [Audyessey,flat,etc]
Is one a better allrounder than the other?
Can this unit recognize full range speakers or does it group everything into small.
Anyone driving a full range system who has 5805/5910 combo in operation and who has experimented with the EQ?
PLUS the love of multi channel audio/2ch audio and movies.
Anyone...
Flying Ed is offline
post #283 of 1350 Old 04-19-2005, 07:05 AM
ted_b's Avatar
Flying Ed,
Thanks. I've been asking about the audio since page 12, and no one but DC has chimed in. Not that I'm disappointed in the video discussions, just that the Audyssey stuff has real potential and want to know what it does in a real-world full-range setup.
Ted
ted_b is offline
post #284 of 1350 Old 04-19-2005, 08:35 AM
theranman's Avatar
I'd also like to know what the EQ options are. Does the Audyssey always EQ the listening position to flat response across the frequency spectrum, or can it be customized to one's tastes?
Query: I have a strong personal preference for flat response. Although to many, this might seem too bright, harsh, shrill, etc., for ME, I love the details it brings out. Consequently, I would assume that the Audyssey system would probably leave that pretty much "as is" in the final eq, right?
Now what if I had some speakers that
were a bit recessed in the midrange and tipped up on the ends..ie..the usual home audio suspects? Would the Audyssey system tone down the ends and raise the midrange in order to achieve flat response at the listening position?
How much user control is there to tailor the system to one's preferences???
thanks!
theranman is offline
post #285 of 1350 Old 04-19-2005, 08:41 AM
kromkamp's Avatar
Quoted: 88 Post(s)
Liked: 70
I know from a previous thread that the Audyssey EQ can be targetted to a flat response as well as thier preferred 'house curve'. There may be other target curves or the ability to design your own, I dont know about that.
kromkamp is offline
post #286 of 1350 Old 04-19-2005, 08:53 AM
theranman's Avatar
and that's what I'd love to know.
I'd also like to know what their "house curve" looks like on a fq. response chart.
Ran
post #287 of 1350 Old 04-19-2005, 10:38 AM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
Read back a few posts....Audessey Chris addressed that issue to some degree.
__________
Dave
moonhawk is offline
post #288 of 1350 Old 04-19-2005, 12:14 PM
kromkamp's Avatar
Quoted: 88 Post(s)
Liked: 70
I tried to get Chris to reveal the house curve a while back but he seemed reluctant. I suppose they consider it proprietary information. Although, it should be easy enough to determine by measuring the room with the EQ engaged.
Andy K.
kromkamp is offline
post #289 of 1350 Old 04-19-2005, 12:37 PM
theranman's Avatar
interesting notion...that the frequency response curve should be proprietary.
Most speaker designers feel the same way...and that's why they so often claim that reviewer's fq. response charts are wrong or inaccurate. It's because they don't like their "house curve" to be "outed". I say we don't need no stinkin' house curve...let us make our OWN curve.
Ran
post #290 of 1350 Old 04-19-2005, 02:53 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
From post #268
"...The Audyssey curve performs best for movie content that has been properly mixed following the standards. Since the music industry has no such standards, we could not simply guess at the intentions of the program creators. For that reason, the best starting point for music is to use MultEQ and calibrate to "flat". From our own experience with MultEQ users we find that many start with flat for music, but almost all of them migrate to the Audyssey curve that has a slight high frequency roll-off.
Best regards,
Chris..."
__________
Dave
moonhawk is offline
post #291 of 1350 Old 04-19-2005, 02:54 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
DC
Which curve do you use?
__________
Dave
moonhawk is offline
post #292 of 1350 Old 04-19-2005, 03:41 PM
DC
I use the Audyssey curve almost exclusively. I've played with the others, Flat, Front and Manual but find the Audyssey curve the most musical for, well, music..... and the most realistic & dynamic for movies. I could live with Flat for music as well but feel Audyssey opens up and fills in the sound a little further, a little better.
post #293 of 1350 Old 04-19-2005, 10:49 PM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
"I've played with the others, Flat, Front and Manual"
This is the first I've heard of Manual; can you describe it?
Noah
noah katz is offline
post #294 of 1350 Old 04-19-2005, 11:16 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
The new May issue of Sound & Vision has a review of the 5805, and yeah they like it. But man did it do lousy in the power output test, even though they raved about it's power in the review itself. It drops down to 121wpc at 1kH with 5 channels driven. So I'd guess if you were to use all 7 or 10 at once, you're then maybe looking at about 100-110wpc, or probably even less with all 10.
I'm really surprised, because I thought it would have been much stronger than 121wpc into 5. And I also thought that on something like this, that Denon would have made something that came a lot closer to the ad specs.
http://www.soundandvisionmag.com/ass...VR-5805lab.pdf
note:
Before anyone asks.....
As of right now. They only have the "lab" test results on their web site, and not the full product review.
Johnla is offline
post #295 of 1350 Old 04-20-2005, 07:29 AM
audyssey's Avatar
"Manual" does not use the MultEQ process. It is a parametric EQ that can be set manually by the user.
Chris
Chris
Join me for Audyssey Tech Talk on Facebook here.
Follow me @ChrisAudyssey on Twitter here.
audyssey is offline
post #296 of 1350 Old 04-20-2005, 08:03 AM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
Is there a way to check what the settings are for each speaker in the various curves? IOW, can you then tweak a pre-set curve slightly to your taste, both in level an EQ?
__________
Dave
moonhawk is offline
post #297 of 1350 Old 04-20-2005, 08:17 AM
theranman's Avatar
Chris
If it doesn't use the MultEQ process, shall we assume that the p-eq. only works for a single mike position?
I'm also interested in knowing if the MultEQ's curves can be tweaked. I'm guessing not.
Ran
post #298 of 1350 Old 04-20-2005, 08:41 AM
audyssey's Avatar
"Manual" does not use the microphone at all. It is a few bands of parametric EQ that the user can set manually based on "divine inspiration". Denon has implemented a way to "copy" the Flat curve that has been calculated with MultEQ into the Manual setting and then tweak from there using the parametric. the problem with that is twofold: (1) the copying tries to squeeze 512 points of the FIR correction filter into 10 bands of parametric so there is some loss of information and (2) now you are in the world of IIR filters and the associated phase and time domain problems.
Chris
Chris
audyssey is offline
post #299 of 1350 Old 04-20-2005, 08:58 AM
theranman's Avatar
>>Denon has implemented a way to "copy" the Flat curve that has been calculated with MultEQ...<<
Speaking of the oxymoron "Flat curve", does MultEQ REALLY make the response FLAT at the listening position? As I asked before, if a speaker is designed with a midrange dip, would the "Flat curve" bring the dip up to TRUE flat at the listening position?...or is "Flat" really curved in some fashion? Catch my drift?
Ran
post #300 of 1350 Old 04-20-2005, 11:19 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
note:
Well the interesting part is the comment with it :
The Denon AVR5805 performed at or near historic levels for A/V receivers: power, noise, and distortion measurements were all record-setters on my test bench
Daniel.
for men to evolve we have to upgrade
danielo is offline
