Denon AVR-5805 Arrived..... - Page 45 - AVS Forum | Home Theater Discussions And Reviews
post #1321 of 1333 Old 12-27-2015, 04:58 AM
Mkellyvich's Avatar
Yes. The Zone 2 HDMI output simply passes what the source sends ... so if the source (eg. BDP) is passing a DD/DTS standard or HD 5.1/7.1 signal, that is what the 5805 would receive. An AVS forum member actually uses a 2nd Atmos AVR (X4100W) connected to the Zone 2 HDMI output to pass an Atmos Blu Ray signal to achieve an Atmos 7.2.6 configuration (as current models are limited to a max of 7.2.4).
Excellent -thanks.
Mkellyvich is offline
post #1322 of 1333 Old 02-01-2016, 05:32 PM
audiooldhand's Avatar
5805CI Z2 Video Problem
I recently decided to once again setup Zone 2 of my 5805CI using Z2 component out to a Samsung 223HD. I am able to pass SV from a old TiVo and a Pioneer Elite DVD, but if a change the Pioneer out to component or try other HDMI sources, the 223HD displays "No Signal". I have read and reread the manual and studied batpig and tried all combinations of video settings with no joy. Finally I spoke to a tech at Denon support and after holding for the tech to check with ???, was told Z2 video does not support HDMI. I found this hard to believe and came across the above quote. I don't remember how I setup it long ago, but I think it passed HDMI. Changing the three Samsung Picture settings: Dynamic, Standard, and Movie has no effect.
While I am planning to move to the 7200WA and working through all the posts, I would like to have all the upgrades to it finished and use the 5805 a little longer before making the change.
Any help appreciated.
Audioolhand
audiooldhand is offline
post #1323 of 1333 Old 02-01-2016, 05:49 PM
Mkellyvich's Avatar
If the signal comes in to the 5805 only via HDMI, the 5805 will only output audio and video to Zone 1 - the 5805 doesn't transcode HDMI to component video or optical/coax digital audio. You'd have to hook the source up via component video and digital audio for the 5805 to output it to Zone 2. I ran exactly this setup in my last house.
In the quoted post JD was referring to the 7200's Zone 2 HDMI output.
Hope this helps...
post #1324 of 1333 Old 02-02-2016, 08:29 AM
post #1325 of 1333 Old 02-02-2016, 08:35 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 10296 Post(s)
Liked: 4766
Audioolhand
As noted, I was referring to the X7200WA as Zone HDMI output was only just first introduced on D+M models beginning in 2012.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Authorized dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, SVS, Oppo
Ask me how to get a FREE HEOS 1 HS2 wireless/Bluetooth speaker.
jdsmoothie is offline
post #1326 of 1333 Old 02-11-2016, 01:25 PM
Liked: 2
I am currently using denon5805 but want to upgrade to a more recent receiver, any recommendation guys?
ILOVEGOLFING is offline
post #1327 of 1333 Old 02-11-2016, 04:06 PM
fmalczewski's Avatar
Quoted: 85 Post(s)
Liked: 38
Just a followup to my previous post (Nov 2014), ultimately I ended up not being able to upconvert my svhs deck from svideo to 1080 via the Denon, something died or who know what (I'm still pretty sure it worked initially when I got the new tv). So I ended up running composite cable from the svhs vcr to the tv (since it has no svideo input (it would have killed them to put one in?)).
Too busy with other things to watch my tapes recently, but given the ones I was watching were recorded on a (different) slightly out of whack svhs vcr on a not very good cable tv system circa mid/late 90s and at the slowest recording speed, albeit with s-vhs et enabled, when I watched a couple it wasn't like an svideo connection would have made all that much of a difference compared with composite. I do have some other pre-recorded tapes I hope to get to eventually, they may fare better, so perhaps I'll give svideo another shot if/when that ever happens. In the meantime I'll mostly be sticking to those 90s tapes, via composite, if/when I get a chance.
Still fine with the 5805 otherwise.
fmalczewski is offline
post #1328 of 1333 Old 02-12-2016, 03:09 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4766
The current Denon flagship X7200WA would be an excellent choice.
post #1329 of 1333 Old 05-24-2016, 05:57 PM
Quoted: 85 Post(s)
Liked: 38
It's been ages since I ran Audyssey on my 5805mk2, but I've been pretty happy with the results, so haven't wanted to risk a bad re-calibration (before it was modified to become a mk2, it came out rather excessive on the high end as I recall). But I would like to try it again since the room has had some changes in the meantime and probably could stand a tweak.
I just relatively recently (a year or two ago) nailed down all the settings on my receiver to where I liked them and such that they matched my current configuration, and finally at that time did a Save on them (something I hadn't done before). I wondering whether these Save-d settings include the Audyssey calibration... so if I decide I liked the old calibration better, I could easily revert back to it. Does anybody (left) know the answer?
(My homework for the night is to RTFM, but maybe someone has some actual experience in the matter... ?)
post #1330 of 1333 Old 05-25-2016, 08:32 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4766
They do for models going back to 2007, so likely for the older 5805 as well as I doubt this feature has changed.
post #1331 of 1333 Old 05-25-2016, 09:42 AM
Quoted: 85 Post(s)
Liked: 38
There was no specific info in the manual about whether they were part of what was globally "Save"-d, which makes me think there's a chance they might not be. So the plan is to at least look at old Audyssey graphs and compare with the new ones before "Store"-ing the new ones (which minimally will clobber the active old ones). Then try them out for a while. If they're not to my liking I'll try the "Load" option, and see if the old Audyssey settings get restored in the process. (I might even do so anyway, just to see...)
Back on the front-burner, at least for now, but will do some further exploration before digging out the microphone.
Thanks for the info, gives me some reassurance.
post #1332 of 1333 Old 05-25-2016, 09:51 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4766
There has never been any mention in any of the D+M manuals .. to include current models.
post #1333 of 1333 Old 05-25-2016, 08:25 PM
Quoted: 85 Post(s)
Liked: 38
I suspect I might get to it in about a week. Damn the torpedoes...
