Does anyone else have to turn up their marantz receiver to -20? - AVS Forum | Home Theater Discussions And Reviews
Old 05-22-2005, 11:41 PM - Thread Starter
bundee1's Avatar
Like the question says I have to turn my Marantz receiver up to -20 to get decent volume, -15 to get 75db. Is this normal? I first tried them with the Rocket Tyke system and Im getting the same results with some old Original Advents.
bundee1 is offline
Old 05-23-2005, 12:38 AM
middle america's Avatar
Yes, this is normal. The -20 reading means that the receiver is playing at 20 db below reference. The "0" reading on your receiver should play at reference, which depends on who establishes reference (usually 75 or 85 db) and also the efficiency rating of the speaker. I've listened to the Tykes, and although they are a great value, won't like the "0" reading on your Marantz. Enjoy, and don't worry! :)
middle america is offline
Old 05-23-2005, 03:31 AM
AVJ
AVJ's Avatar
I owned a Marantz SR7000 since mid of 2000, and when watching movies (no matter DD or DTS), the volume mostly turned-up to around -12 ! in order to obtain the right sound level to fully enjoy the movies !
I am using KEF Q50 as the main channel speaker, and KEF Model 90 as the center channel speaker.
Hence, don't worry to turn your Marantz to -20, it should be quite "normal".
BTW, what model is your Marantz ?
AVJ is offline
Old 05-23-2005, 08:10 AM - Thread Starter
bundee1's Avatar
I have a Marantz SR6400. I think its 110 x 6 and I was looking for old Jm Labs Chorus speaekers to match the 706 I have now. The older series is better than the newer series which makes them much harder to find used. Thanks for the help guys!
bundee1 is offline
Old 05-23-2005, 08:26 AM
Verinnal's Avatar
I'm powering my B&W 804S with a Marantz SR8500 and my typical listening level with an analog connection from my CD player is between -17 and -15. On the rare occasion I go to -10.
TV watching is a totally different story. I'm using a digital out on my Scientific Atlanta digital cable box and I can listen at -35. For some reason it is much louder than the analog out from my CD player.
Verinnal is offline
Old 05-23-2005, 09:27 AM
kendenton's Avatar
I've got a Marantz SR7400 (with an 8400 on the way) powering some not very efficient speakers. Most movie watching is done between -20 and -14. Anything above -10 is REALLY loud, anything above 0 would probably cause hearing damage :-).
kendenton is offline
Old 05-23-2005, 09:52 AM
Fraoch's Avatar
Sounds normal to me. I went with a 7400 just recently and calibrated to 75 dB from all speakers using the internal test tones.
Normal TV listening is -25. Sometimes -20 is good too.
DVD viewing is fine at -25 but some DVDs are mixed too hot to play at -20.
Very typical, I think, and remember every manufacturer does things differently - it's no indication of relative power, as 1W generates at least 87-90 dB from most speakers.
I had a Denon 1602 and then 1803. They seemed to play louder - I could never listen to TV at -20, but then again I calibrated it differently, 75 dB at -5 or so from a DVD test disc. Interestingly the 7400 seems to be more variable. I played anything and everything at -25 on the Denons, but I vary things around a lot more with the Marantz. This may indicate material sounds less harsh at higher volumes, I don't know.
Fraoch is offline
Old 05-27-2005, 01:43 PM
Paradox-SJ's Avatar
My new setup is the 8500 and Rockets 850's/200 up front and for TV connect to my Dish 942 I set it betwean 20 and 30 all depending on the show/SAT or OTA. I always have to mute the commercial though.
For DVD's -20 is as loud as I can go unless I invite the neighbors over :-)
Why is there not an unofficial SR8500 thread any?
Paradox-SJ is offline
Old 05-27-2005, 01:49 PM
Fraoch's Avatar
Originally Posted by Paradox-SJ
Why is there a unofficial SR8500 thread any?
Yeah, I was kind of thinking of starting a 7400/8400/7500/8500 thread.
But I guess the thing is, these receivers have no issues. What would there be to talk about?:D
Fraoch is offline
Old 05-27-2005, 02:00 PM
Paradox-SJ's Avatar
Well we could talk about how nice they are... :D
Old 05-27-2005, 02:05 PM
Fraoch's Avatar
True.;) Or how unbelievably large they are.:) I don't know how much value that would be though.
However the manual is very skimpy (I thought Denon's manuals were bad, sheesh!) so there could be some newbies out there with unresolved questions.
Fraoch is offline
Old 05-27-2005, 02:10 PM
Paradox-SJ's Avatar
Don't even get me started on the manual. :eek: I have never seen anything so poorly put together. You can tell they put next to no effort or thought into it.
Old 05-27-2005, 02:14 PM
Fraoch's Avatar
It covers what needs to be covered I guess. There are no spelling or grammatical errors.
However there's definitely no fluff or extra explanation. Denon has a nice section at the back of their manuals that goes a bit into the theory behind the various sound formats.
BTW do the new remotes buzz when backlit?
Fraoch is offline
Old 05-27-2005, 02:17 PM
Paradox-SJ's Avatar
Now that you mention it I believe they do.
I am not to fond of the remote either as the button are two close etc. I think my MX 850 that is on the way will resolve it this
Old 05-27-2005, 02:25 PM
breakbeat46's Avatar
As far as the HT EQ, has anyone noticed that it affects the LFE signal also? i just want to confirm if its just my ears or its the reciever.
breakbeat46 is offline
Old 05-27-2005, 02:26 PM
Fraoch's Avatar
I haven't noticed it, but I haven't used the HT-EQ much.
I have another question so rather than further hijack bundee1's thread I think I'll start an official "Marantz 7400/7500/8400/8500" thread.:)
Edit: done, thread here!
Fraoch is offline
Old 05-27-2005, 02:54 PM
nmo
nmo's Avatar
I have been mulling over starting a thread for the 8400. Guess you got to it first. Go for it! :)
Happiness is merely the remission of pain.
nmo is offline
Old 06-09-2005, 09:46 PM
porksoda's Avatar
You should set all channel volume to +10. it does not add noise, it for some reason missed a firmware before production...
i found aroudn -20 is almost earth shattering... i also do have very efficient speakers that accounts for it... but still set all channel levels to +10 or accordingly depending on your room.
porksoda is offline
Old 06-09-2005, 11:10 PM
~Ohdee~'s Avatar
I run the SR6400 as pre out for a Bryston B9. I usually listen to music between -18 and -13 but when I want to show off what she can do I take it all the way up to -5. I have Paradigm studio 100v3’s. It very loud but still sounds incredible. :D
~Ohdee~ is offline
