Pioneer Electronics Product Questions - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #181 of 592 Old 09-02-2005, 08:27 PM - Thread Starter
WalkamoHB's Avatar
Originally Posted by Ange Rizzo View Post
Hi Chris,
When do you think we'll be able to see the spec sheets for the new PDPs? Also, does Pioneer U.S. take care of Pioneer Canada's website? If so, when do you think it might be updated?
Ange.
Hi Ange, the Plasmas will be up by the end of next week. We have not officially announced them yet. We do not control the Canadian Website.
Chris Walker
WalkamoHB is offline
post #182 of 592 Old 09-02-2005, 08:31 PM - Thread Starter
WalkamoHB's Avatar
Originally Posted by Lee Bombard View Post
Chris -
Thanks for all the terrific info!
I have a Elite 510 TV. I believe this has a DVI input. Would there be any problem in using the 74 to pass upconverted HDMI to the 510 using a HDMI to DVI cable?
Also - I currently have a VSX49Ti Elite receiver. In your opinion, would I be foolish to trade for the 74?
Appreciate your input.
Lee
Unfortunatley the 51 does not have a DVI input. You will need to use the component video jacks. As far as replacing your 49 with a 74, this would only be my personal opinion. I do believe the advances made to MCACC and the convienence of HDMI switching with transcoding are a worthwhile upgrade. I replaced my 59TXVi with a Silver 74 and have not regreted it at all.
Chris Walker
post #183 of 592 Old 09-02-2005, 09:22 PM
Lee Bombard's Avatar
I was mistaken. I have the 530 not the 510...so I would be good to go?
Lee Bombard is offline
post #184 of 592 Old 09-02-2005, 09:28 PM
Server error
post #185 of 592 Old 09-02-2005, 09:39 PM
sjoh's Avatar
Hello Chris,
Thanks for starting this thread. I have a couple of questions:
1. In another thread it was mentioned that the standing wave control filter in the new Pioneer VSX74 receiver contained 33 bandpass filters per speaker. However, looking at the manual it seems to suggest that it is 3 parametric EQs per speaker. Could you confirm this?
2. Are there any plans for Pioneer to release an upconverting 5 disk DVD video/audio/SACD changer?
Thanks in advance,
Sejin.
sjoh is offline
post #186 of 592 Old 09-02-2005, 09:52 PM - Thread Starter
WalkamoHB's Avatar
Originally Posted by sjoh View Post
Hello Chris,
Thanks in advance,
Sejin.
Hi Sejin, yes the Standing Wave control does use 33 band pass filters. I have attached a graphic from our av design group.
About the changer, the changer market is really small. We are currently using our optical disc based engineers for Blu-ray development. I do not expect one for awhile.
Chris Walker
[IMG]SWC Image[/IMG]
post #187 of 592 Old 09-02-2005, 10:11 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
So my question above applies to the 530.
In that case unless there are some sort of HDCP issues, it probably should work with the 530.
Johnla is offline
post #188 of 592 Old 09-02-2005, 11:29 PM
Mars Rocket's Avatar
Are the video conversion capabilities (i.e. analog to HDMI) of the VSX-72 and VSX-74 identical? On the web site comparison page, under 'Video Conversion' it says "Yes - To HDMI" for the 74 and "Yes - Digital To HDMI" for the 72. Is this just a typo, or is there actually a difference?
Mars Rocket is offline
post #189 of 592 Old 09-02-2005, 11:54 PM - Thread Starter
WalkamoHB's Avatar
Yes they are identical.. The website should state the same for both. We rushed to get them up last night.. Just a typo..
Chris Walker
post #190 of 592 Old 09-03-2005, 12:53 AM
John Villano's Avatar
Hey Chris,
Thank you very much for the response. I will try your suggestions, as well as the 1130 I will compare them side by side.
Thanks again
John Villano
John Villano is offline
post #191 of 592 Old 09-03-2005, 08:09 AM
Chris Walker
Great, thanks. I've been trying to decide on a new receiver for several months now and now I'm planning on getting a VSX-72TXV or VSX-74TXVi. Your participation in this forum is one of the deciding factors for me.
post #192 of 592 Old 09-03-2005, 08:10 AM
cdcray's Avatar
I am trying to make a decision on a Reciever/Amp and am close to deciding on the Pioneer 1015TX. But I am having a lot of trouble with the acronyms and other technical terms as what they mean to me or should I be concerned about them. Can you lead me to a good Glossary of terms?
cdcray
cdcray
South Bend, IN
cdcray is offline
post #193 of 592 Old 09-03-2005, 11:13 AM
subversive's Avatar
cdcray
http://www.audioed.com.au/glossary_free1.html
http://www.enjoythemusic.com/magazin...erminology.htm
subversive is offline
post #194 of 592 Old 09-03-2005, 12:36 PM
Joe Schwartz's Avatar
Hi Chris,
If the specs for the flagship receiver are not yet finalized, please consider providing more than two HDMI inputs.
Joe Schwartz is offline
post #195 of 592 Old 09-03-2005, 01:49 PM
jteodosio's Avatar
Hi Chris,
I´m live in Brazil - Rio de Janeiro. We don´t have in your representative in Brazil the boards to purchase of the model M-4000 audio power amplifier (rwz-3687 and rwz-3688). I have one model of this equipment but is defective more less 2 years.
Please, inform if you can send me the squematic diagram and/or the boards with the components.
I hope your informations.
thanks
Jorge Teodosio
jteodosio is offline
post #196 of 592 Old 09-03-2005, 04:16 PM
cdcray's Avatar
Thanks subersive.
Cdcray
cdcray
South Bend, IN
cdcray is offline
post #197 of 592 Old 09-03-2005, 04:32 PM
psycho's Avatar
ok I'm just jumping into this thread, I only read the first couple replies, it's not a question, but more of a Suggestion.
Recently when I was looking to purchase a new receiver I was looking for 2 thing in particular, 8ch input and dolby prologic 2x.
I narrowed it down between a 815 and a yamaha 650. although the 650 was $100 more, and one less component input I chose it over the 815 since it had an 8ch input. If the 815 would have hade an 8ch input, I would have bought it in a heartbeat, but it didn't. I would recommend that you put 8ch inputs on all of your 7.1 receivers. I would be willing purchase a pioneer in the near future, if it had the 8ch input feature.
psycho is offline
post #198 of 592 Old 09-03-2005, 06:26 PM
Jake Sm's Avatar
Is this because of DD+/DTS+ ?
Seeking a speaker recomendation? Compare for yourself or be swayed by others who hear differantly, or by marketing, or just save time and get the cheapest , nicest looking, or smallest.
Jake Sm is offline
post #199 of 592 Old 09-03-2005, 07:10 PM
Enigma's Avatar
I agree completely the 74 has an extremely complete feature set. The only thing missing is enough inputs to adequately cover future hdmi capable inputs (hd tivo, blu-ray player, ps3, future secure htpc, etc). Four HDMI inputs (pref. 1.2, but I understand the chips might not be available till next summer, so depending on the timing of the release 1.1 would be OK, with 1394 for muti-channel SACD).
Hal
Enigma is offline
post #200 of 592 Old 09-03-2005, 09:40 PM - Thread Starter
WalkamoHB's Avatar
Originally Posted by jteodosio View Post
Hi Chris,
thanks
Jorge Teodosio
Sorry Jorge, you can try calling our customer service regarding this matter at 800-421-1404.
Chris Walker
post #201 of 592 Old 09-04-2005, 06:59 AM
uw69's Avatar
I'm anxious to purchase a VSX-74TXVi, I have checked both of my local Magnolia Hi Fi's in the Seattle/Tacoma area but no luck. Any hints where I might find one? Thank you
I miss the rosewood sides on the old Pioneer Elite equipment!
Blu-ray - 576
HD DVD - 81
uw69 is offline
post #202 of 592 Old 09-04-2005, 01:56 PM
Nightmaster's Avatar
I bought the 815 about a month ago and for the money I think it's an incredible receiver.
Nightmaster is offline
post #203 of 592 Old 09-04-2005, 06:02 PM
psycho's Avatar
no, gaming from a pc with an audigy 2zs, I know its not a good all around sound card, but for gaming, it is(was) the best. gotta love EAX HD
psycho is offline
post #204 of 592 Old 09-05-2005, 06:49 AM
MattinWashDC's Avatar
I just wanted to get the official statement on what I beleive is a costco special, the Pioneed PDP 4300 plasma. Can you please share some information with us on this model. There have been numerous threads on this, and wanted to get your take. Is this a "dumbed down" model or is it the real deal made for costco.
Are there any limitations to this model?
THanks
Pioneer Elite VSX 52TX
Pioneer PDP4340 Plasma
Pioneer Elite DV-45A DVD
Pioneer Elite A-35R
Polk Reference (5.1) Speakers
MattinWashDC is offline
post #205 of 592 Old 09-05-2005, 10:48 AM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
It looks to me like the PDP-4300 is currently listed as a older discontinued Canadian model, and not a US model. So I don't think it's a model number that was/is made specifically for Costco. And that they probably just bought out a supply of them from someone.
http://www.pioneerelectronics.com/pn...548282,00.html
Johnla is offline
post #206 of 592 Old 09-05-2005, 11:08 AM
jteodosio's Avatar
Hi Chris,
I contact you after to try resolve the problem in Brazil. The model M-4000 not sale in Brazil, consequently the your service station here not have pieces and documentation to realize the repair. I can´t to agree without use the equipment. I need the squematic diagram and/or the boards rwz3697 and rwz3698.
Please, send other informations about this matter.
Jorge Teodosio
post #207 of 592 Old 09-05-2005, 10:04 PM
papaduxx's Avatar
Quoted: 30 Post(s)
Chris,
I have a question for you. I interested in purchasing one of these three models the Pioneer 74TXVI and the Denon AVR-3806 or AVR-4803. In comparing the WATTS, i notice on the back panel of the Elite its says "AC 120v 60hz 530w 690va." I am a little new to the higher end receiver market so sorry if its a bad question, why are the watts 530 and not what the receiver claims 140 x 7 = 980? When I look at the rear panel of the a yamaha receiver it is closer to the claimed watts and denon 3805 on the crutchfield site it lists power consumption at 7.1 amps which after some math is closer to the claimed watts. What is the power consumption of the VSX-74TXVI?( how many amps) what is the true wattage? How is this number reached from the claimed watts to what is written?
I am seriously considering the Pioneer but the denon is still hanging around. I just want to clear up some of these questions before i buy the 74TXVI and want to make the right decision. I would appreciate any help you or anyone else would be able to give me.
is 690 va canadian spec?
Anthony
2 Definitive Technology ST-L Fronts, CS-8080HD center channel, Gem XL rears, SuperCube 8000 subwoofer, Marantz SR-7008 , and Sony KDL-55w900a
papaduxx is offline
post #208 of 592 Old 09-05-2005, 11:28 PM - Thread Starter
WalkamoHB's Avatar
Hi Chris,
Jorge Teodosio
Hi Jorge, I wish I could help you, but I do not have access to thos service documents.
If our customer service could not help, there is really not much else I can do. We only offer service manuals to authorized service centers.
Sorry,
Chris Walker
post #209 of 592 Old 09-05-2005, 11:37 PM - Thread Starter
WalkamoHB's Avatar
Originally Posted by papaduxx View Post
Chris,
Anthony
Hi Anthony, the wattage your are referring to (530 watts) is the amount of power that the receiver draws from the AC outlet. The 140w x 7, is the ouput power of the receivers transistors.
I can assure you that the receivers power output is
140watts x 7 from 20hz-20kHz at 8ohms with .09% THD with all channels driven.
Chris Walker
post #210 of 592 Old 09-06-2005, 12:13 AM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Jorge Teodosio
Jorge
From what Chris just said, it looks like you maybe will need to use one of the online sources to acquire a M-4000 service manual and schematic.
http://www.electronicsrepair.net/rec17m.shtml
http://www.user-service-manuals.com/...ce-manuals.htm
http://www.servicemanuals.net
http://www.smshop.org/product_info.p...roducts_id/350
http://service.city.tomsk.net/manuals/pioneer2.html
And for the rwz3697 and rwz3698 parts. But I would advise you first, to make sure that is what you really need, try.
for the rwz3697
http://www.partstore.com/PartNumberS...Number=rwz3697
for the rwz3698
http://www.partstore.com/PartNumberS...Number=rwz3698
Now I can't say for sure if they will ship parts to Brazil or not, so you may want to send them a email and find out.
Johnla is offline
Pioneer Electronics Brand , Pioneer Electronics
