Denon 3806 Owners Thread - Page 97 - AVS | Home Theater Discussions And Reviews
post #2881 of 2902 Old 07-04-2014, 10:51 PM
EagleThrust77's Avatar
Hi..have maybe a dumb question. Do the knobs on the front of the 3806 pull off? I don't want to force them off if they aren't suppose to. Thanks.
EagleThrust77 is offline
post #2882 of 2902 Old 07-08-2014, 12:41 PM
KSparkuhl's Avatar
Yes, they pull straight off. A firm, gentle pull does the trick.
KSparkuhl is offline
post #2883 of 2902 Old 07-08-2014, 09:46 PM
Thanks I appreciate that. I want to do a little cleaning job on the front. It got a little water/plaster on it from a leak in my ceiling. Still works fine as most of the water went into my cable box.
post #2884 of 2902 Old 09-08-2014, 10:52 AM
Quoted: 18 Post(s)
Liked: 1
denon avr 3806 firmware update
Hey I just purchased a 2nd hand denon avr 3806 for $100. the seller told me he never updated the firmware. I couldn't download it from denon websites. Anyone has it and can send to me? thanks alot.
atx2014 is offline
post #2885 of 2902 Old 09-08-2014, 03:03 PM
bluer101's Avatar
Quoted: 178 Post(s)
Liked: 135
I have never done mine either from brand new in 2006. I would love to do mine now for 7.1 LPCM
bluer101 is online now
post #2886 of 2902 Old 11-26-2014, 12:30 AM
janghell's Avatar
Firmware
I have the firmware file for the 3806.
I can send it to you if you like.
I updated my 3806 yesterday:-)
janghell is offline
post #2887 of 2902 Old 11-26-2014, 08:11 AM
bluer101's Avatar
Quoted: 178 Post(s)
Liked: 135
Thanks, I got it from another member. But have not upgraded since I bought a new Denon 4520ci. My 3806 is boxed up for future zone amplification.
post #2888 of 2902 Old 12-10-2014, 12:17 PM
Liked: 0
Gentlemen,
I'm looking into upgrading the firmware on my 3806 because of an issue with the left front speaker tests.. the system always misjudges the distance of the left front speaker drastically compared to the others (which seem to be fairly accurate). Hoping a firmware upgrade would help.. or i'll have to swap out the mic.
can one of you make the firmware file available for me to download?
thanks,
Faisal Quadri is offline
post #2889 of 2902 Old 12-10-2014, 01:00 PM
janghell's Avatar
Originally Posted by Faisal Quadri View Post
Gentlemen,
thanks,
You can find it here in my next post. Need 5 post before I can share a link...
janghell is offline
post #2890 of 2902 Old 12-10-2014, 01:00 PM
janghell's Avatar
janghell is offline
post #2891 of 2902 Old 12-13-2014, 11:28 PM
mektare's Avatar
Hi janghell, can you please help with few instructions on how to upgrade the firmware? My 3806 purchased in 2005 started acting up recently - no video output at all, no OST either. Tried everything including factory reset with no luck. Was thinking of buying the X4100W, but would like to see if the new firmware breathes life into 3806. Thanks!
mektare is offline
post #2892 of 2902 Old 12-14-2014, 10:29 AM
saurav's Avatar
Post 1960 describes the process nicely. There's also a pdf file inside the zip, in German, IIRC.
saurav is offline
post #2893 of 2902 Old 12-14-2014, 11:50 PM
mektare's Avatar
Thanks a lot Saurav. I will try that out.
mektare is offline
post #2894 of 2902 Old 12-20-2014, 02:01 PM
Benefactor's Avatar
Haven't visited this thread in awhile.
Something I've never been able to figure out...how/where do I connect an external headphone amp?
I've tried a variety of different ways to connect my Perreaux SX-H1 amp to the 3806, but can't get audio out of it.
Seems like something I should have been able to figure out after all these years...gave up on it after awhile and forgot about it.
Can anyone lend me a hand...where does the headphone amp connect?
I've searched this thread, and found a few posts asking the same question, but I still can't seem to figure it out.
Exactly which jacks on the back am I looking for, as I don't see any labeled "rec out"?
Can somebody please walk me through this as if I'm a child?
What am I missing?
Thanks in advance for any assistance.
Benefactor is offline
post #2895 of 2902 Old 12-21-2014, 07:23 AM
Liked: 0
Another question related to the 3806. I recently connected a Sony Blu-Ray player (BDP-S790) to the 3806 via the optical link. Now when I play a movie the 3806 will abruptly shut off, with the power button blinking red. This seems to be correlated with loud scenes in the movie. Is this a known issue? Will updating the firmware fix it?
rvazreal is offline
post #2896 of 2902 Old 12-22-2014, 12:18 PM
Benefactor's Avatar
Disregard my question above - figured out the connection for an external headphone amp...after mucking around for a couple of hours.
I consider myself fairly well-versed in consumer electronics, but for the life of me, I forgot how unnecessarily complicated the 3806 is/was.
It would be comical if it wasn't so frustrating.
post #2897 of 2902 Old 01-04-2015, 10:27 AM
Nasmo_Q's Avatar
Another Firmware Question (HDMI problem)
Hi all.
I've been using my 3806 (US version) for many years with an old Sony VPL-50 projector (connected via HDMI) with no issues whatsoever. The projector recently died so I bought a new Epson Home Cinema 3000. The projector works great however, the 3806 will not recognize it, nor output to it, when connected to the 3806 over HDMI. The firmware versions I have are the original:
Main: 00.56
Sub: 00.42
DSP: 00.43
I found newer firmware that Janghell posted (thank you Janghell). The changelog for that version states:
Changelog of Firmware AVR3806
28.09.2007
00.76
When the customer connected the source equipment to the COMPONENT input of an AV amplifier and AV amplifier and Display with HDMI connection, the customer controlled MASTER VOLUME up and down, a Flashing Noise indicates in a picture at once.
06.09.2006
00.72
Improvement of the transaction of Bass management setting
Improvement of support the Audio Digital signal at PC resolution (SVGA, XGA, etc.) from the HDMI input with DVD-3930 or DVD-2930
16.06.2006
00.59
Supporting the LPCM 7.1ch digital signal
Supporting the PC resolution (1600x 1200, 60Hz max.) from HDMI iput
05.12.2005
00.56
adjustement the pop noise when operating the REC SELECT
Depending upon the timing after the function is switched, the Setup OSD is sometimes not indicated when the System Setup Button was operated continuously.
Improement of the RS232C Serial Control
A few questions:
Is this the latest firmware? If so, what versions does it update the Main, Sub and DSP to?
Will this work on the US version of the 3806?
The changelog doesn't mention the specific problem I'm having but does mention HDMI. Does anyone know if updating the firmware will address HDMI issues like what I'm seeing?
The reason I'm reluctant to upgrade is that I'm an Apple guy with no access to PCs, nevermind one old enough to have the serial port and XP, so I'll have to scrounge around to find something. That seems like a lot of hassle if it's not going to fix the problem, blow away all me existing settings etc.
Thanks very much,
Naz
Nasmo_Q is offline
post #2898 of 2902 Old 01-07-2015, 07:29 AM
sarcevic's Avatar
I use my 3806 to pass audio/video from my dvr and blu-ray with no issues. I'm considering purchasing a 4k tv and would like to know if the 3806 will have any issues passing 4k video content. I know that currently there isn't much in the way of content available, but I'd like to be able to see what content is available. Thanks.
sarcevic is offline
post #2899 of 2902 Old 01-07-2015, 07:32 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3040 Post(s)
Liked: 2002
No, it cannot pass full 1080p 3D or 4k. You would need to purchase a dual HDMI BDP to pass video to 4k TV and audio to AVR.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVS - We sell Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #2900 of 2902 Old 01-13-2015, 11:39 AM
niklass's Avatar
Liked: 0
Hi guys!
I've just bought an Epson TW3200 projector, since my old TW3500 broke this weekend.
Now I'm not getting any signal into the TW3200 via hdmi from my 3806. (When i hook the projector directly to my pc or ps4 i get signal, wich i tested to see that the HDMI "receiver" within the projector is working as it should)
the TW3500 worked just fine, and my backup samsung LCD/LED (series 5) are getting the picture via the same setup.
It seems that the TW3200 has some other interpretation of the HDMI signal than the other two "monitors".
I have an European D3806 and I've flashed it once wtih a download from denon.de to be able to pass through 1080p when i bought the TW3500 some 4-5 years ago.
I downloaded the new FW from the link above, but I'd like to figure out if that's the same patch that i applied some years ago, or if it's a newer one. How do i check my FW version on my 3806? (sorry if it's covered earlier in the thread, haven't read all the 100 pages yet)
EDIT: I googled a bit and found out how and wich version of the software i have in my 3806. it's 0.76 / 0.56 / 0.45 it seems that's the latest version that Denon released for this hardware?
I'd really like to keep the 3806 for a while more, since I still like it soundwise and featurewise.
Best regards
niklass is offline
post #2901 of 2902 Old 02-17-2015, 11:10 AM
brasspile's Avatar
Liked: 63
Thanks for posting this! Tried the link posted waaaay back in this thread and it was file not found.
John
brasspile is online now
post #2902 of 2902 Old Today, 08:21 PM
StoleMyOwnCar's Avatar
Does anyone have this thing paired with a Roku 3 box? I don't really care about Netflix as I do not use Netflix, but does this receiver in general play nicely with everything else on the Roku? I'm about to receive one of these from Ebay, and am considering a Roku to watch stuff. I know this thing is limited to like HDMI 1.1
StoleMyOwnCar is online now
Denon Avr 3806 Av Receiver
