Official Yamaha RX-V1600 & 2600 thread - Page 89 - AVS Forum | Home Theater Discussions And Reviews
post #2641 of 2666 Old 01-23-2011, 02:08 PM
xfullboost's Avatar
I have been working all weekend trying to get my RX-V1600 to work. One morning I turn it out and there is no sound coming from the speakers. I check all my connections, nothing is loose or disconnected. I went through the troubleshooting guide from my manual but that did not make a difference.
There are no error codes, the OSD looks normal. No sound comes from any source. I plugged in my headphones and still no sound.
Another note, when I push the "Pure Direct" button, the OSD gets dim then fades out. And still no sound.
Im at a loss, what could be causing this?
xfullboost is offline
post #2642 of 2666 Old 02-12-2011, 04:50 PM
merrymaid520's Avatar
Quoted: 60 Post(s)
Liked: 31
Hey Guys,
On my Yamaha Rx-V2600, there is an analog L&R Output (for recording I imagine). My question is this, if I have several sources connected to the analog L&R inputs such as a music streamer, CD player, or any other 2ch analog source, will all of these be output through the REC out if the corresponding input is selected?
I ask because I need to send these analog 2ch signals to another room / device. Also, say I am watching a movie through my PS3 thats connected via HDMI, will these REC outs still be active for another analog source at the same time?
Thanks and hope my question was straight forward
Brandon
merrymaid520 is offline
post #2643 of 2666 Old 10-14-2011, 09:59 AM
jimmueller's Avatar
Quoted: 73 Post(s)
While painting my living room, I noticed that one of my surround grills was loose. Reseating it released a fair amount of disintegrated foam driver surround. So, it's time for new surrounds and I might as well upgrade the center at the same time.
Because I'm using Polk SDA-1C's with their updated tweeters (and likely a x-over rebuild soon) as the front mains, I want to stay with their products to attempt timbre-matched drivers. Support recommends a CSiA4/CS10/CS20 for the center and RM8/TL1/TL2 for the satellites.
I'm currently using the 2600 in 5.1 mode. What's the consensus on the best combination of speaker channels for home theatre with this receiver? Is it more effective to add 2 front presence speakers or have a pair each for surround and surround back speakers? Can I correctly use one of these settings for side speakers? Which scenario takes advantage of the most released material?
Or should I just stick with 5.1 due to lack of material and/or cost? Since my room is only about 13' deep, even if I could make the side speakers work, would it be worthwhile?
Yamaha RX-V2600, Fisher MT-9090, Mitsubishi HS-U80, Pioneer DVL-90, Sony BDP-S550, Nakamichi Dragon, Sony CDP-X555ES, Carver AV-634, Carver TFM-42, Panasonic TC-P54V10, BenQ W1070, Polk SDA-1C mains, Polk CS400i center, Polk Fxi A4 surrounds, Polk RT1A1 surround back, Polk RM1000W sub.
jimmueller is offline
post #2644 of 2666 Old 10-14-2011, 03:32 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
I tried it both ways with my 2600 when I was using that one. With that version of YPAO, to me the presence speakers made the room sound like it had a reverberation sound effect. The surround back speakers were a lot better to me. They do work though and my advice to you would be to try it both ways and see which you prefer. I finally ended doing what you are doing and went to just 5.2. Still doing it right now with a new Yamaha A3000.
phantom52 is offline
post #2645 of 2666 Old 12-12-2011, 05:49 PM
Shsinclair's Avatar
does anyone know a way to go digital optical in (DTV)---->rca stereo out????------>dtv rca audio in?
Why the heck would someone want to do this you may ask. I have an apple tv in my main room for which the audio is transferred via digital optical (DTV dig optical in on 2600). I want to be able to listen to my itunes via apple tv in my second zone (Apple tv has no rca outs and 2600 zone 2 can only be played via RCA in). So I thought this might be a work around although I am not sure there are RCA's out in the 2600 and second whether this would actually work even if there was one (i.e. would zone 1(main) have to be on as well in this configuration or could it work with just zone 2).
Anyone have any advice?
Shsinclair is offline
post #2646 of 2666 Old 12-12-2011, 07:07 PM
constp's Avatar
Is this what you're looking for:
constp is offline
post #2647 of 2666 Old 12-12-2011, 07:28 PM
Shsinclair's Avatar
No that won't work and I talked to monoprice and they don't have anything like that. I want to somehow take the dig optical signal going into the 2600 from atv, run it out of the 2600 via RCA and loop it back in via RCA using the Dtv RCA inputs.
post #2648 of 2666 Old 01-23-2012, 03:24 PM
jimmueller's Avatar
Quoted: 73 Post(s)
I have a spare set of speakers that I won, and I'd like to test them as 7.1 surround back speakers. They are Polk RTiA1's. I have Polk SDA 1C's as mains, CS400i as the center, and FXiA4's in dipole mode as side-wall surrounds. It's about 65" from the listening position to the back wall.
The following link indicates two different options: either 60* apart from the listening position if using THX, or right beside one another is using 7.1. Because part of the back wall is open behind the sweet spot, the left surround back would need to be behind the sweet spot instead of angled out. Since the 2600 has THX Select2, I'm not sure what placement locations I should try.
http://www.thx.com/consumer/home-ent...peaker-set-up/
Suggestions?
post #2649 of 2666 Old 01-23-2012, 03:55 PM
bigbrain28's Avatar
a) I clicked the link, and the product was there, and yes that would work, but you's also need this;
http://www.monoprice.com/products/pr...t=1#largeimage
So you could split the toslink - 1 to the DTV in and one to convertor, then to a different RCA input on the 2600 (so z2 can see it)
OR
b) Have you tried looping pre-out L/R back into a RCA/Analog input (such as CD)? I'm not sure how that may work. I have never actually used Zone 2, do you tell it what input to listen on? Can you say "Listen on CD in" which is getting signal from pre-out l/r fed by the signal going into DTV?
*edit: rereading your post, and I think trying to use one input (DTV for both RCA & toslink will be the issue).
bigbrain28 is offline
post #2650 of 2666 Old 02-22-2012, 02:53 AM
domigreece's Avatar
connect my ps3 in to my rx v1600 and out to my tv... picture is green and strange ? any ideas. thanx
domigreece is offline
post #2651 of 2666 Old 03-05-2012, 03:37 PM
bigbrain28's Avatar
HDCP issue (High Definition Content Protection). Could be the HDMI cable, could be your TV, 1600 or the PS3... If you connect the PS3 directly to the TV, does it work? If so, the 1600 is failing to pass the HDCP handshake along to the TV in a way that the PS3 is 'happy' with.
post #2652 of 2666 Old 03-14-2012, 08:59 PM
Dominic26's Avatar
Quoted: 54 Post(s)
Does anybody know if the IR on the 2600 is single or dual band?
Dominic26 is offline
post #2653 of 2666 Old 04-10-2012, 10:13 PM
Sounds like your ps3 is set to 1080p output. IIRC, the rx-v1600/2600 max is 1080i. You might try setting the ps3 to output 1080i to see if that's the problem.
Hope that helps.
kohi is offline
post #2654 of 2666 Old 01-10-2014, 05:20 PM
Rinke's Avatar
Quoted: 21 Post(s)
Hi all. I am having trouble getting a lot of bass out of this receiver. I have to use pure direct mode to get most bass. I have Cerwin Vega VE12's so with 12" drivers I should be getting more bass. I am talking about stereo mode here. 5.1 playback is good. Any suggestions?
Rinke is offline
post #2655 of 2666 Old 02-25-2014, 09:32 PM
FFWD's Avatar
I meant to post this as a reply to this thread, but accidentally created a new one. Hopefully one of you RX-V guru's subscribed to this thread can help:
I have an RX-V1600 that I am using in my bedroom with the following connections:
RX-V1600 input set to CBL/SAT
WDTV Live - HDMI2 IN
Projector - HDMI OUT
Wireless headphones - headphone out
This was OK for a while, but now I'm tired of having to use headphones and don't want speakers all over the room. I have a YSP-600 sound bar that is collecting dust that fits perfectly on the fireplace mantle without looking out of place, and there is existing wiring in the wall there that I can use to fish an optical cable up to. My plan was to connect the YSP to the RX-V via optical and have the sound bar take care of virtual surround processing. Problem is, I get no sound at all when using either the MD or CD optical out ports on the RX-V1600. I can connect via the WDTV optical out, but I want the sound bar connected to the receiver for when I eventually add more components.
The manual is pretty vague when it comes to the optical outs, but at least it confirms that audio input via HDMI IN is channeled to the optical ports. Can anyone help me figure this out?
FFWD is offline
post #2656 of 2666 Old 02-28-2014, 01:52 PM
Dominic26's Avatar
Quoted: 54 Post(s)
Try the images on page 21 of the manual. It shows on the left what is input. The one's on the right show what can accept from where. You may have to go into the menu to enable some of these. Those directions are on pages 81 to 83.
post #2657 of 2666 Old 10-06-2014, 01:09 AM
Rinke's Avatar
Quoted: 21 Post(s)
Does the 2600 support ARC ???
Rinke is offline
post #2658 of 2666 Old 12-05-2014, 07:06 AM
jimmueller's Avatar
Quoted: 73 Post(s)
I just bought a 3D DLP projector, but I only have a Sony bdp-s550 (non-3D) player & rx-2600 receiver. I don't want to run a cable direct from the player to the projector. I didn't buy the PJ for the 3D, but if I wanted to test it out, do I need to upgrade the receiver also?
post #2659 of 2666 Old 12-20-2014, 09:23 AM
tivoboy's Avatar
Sorry to jump into what seems to be an older thread, but need a quick answer it at all possible.
I'm at a third party house, system seems to be here for many many years.
2600 has ONE monitor out, component to an overhead projector. All the current inputs, DVD and CBL/SAT are using component IN to the 2600 and out over component to the projector. Fine and dandy.
Problem is there is literally NOTHING WE HAVE that isn't HDMI and there is no way to get HDMI to the overhead monitor.
IS THERE even a way to use the HDMI IN with say an apple TV and get the video OUT over the current component MONITOR OUT and switch the audio to something else, or can one simply not do HDMI to COMPONENT someone?
I've finally found the remote, so I can get the yamaha menus and have tried switching things to the IN1 HDMI etc, but I can never get a picture.
tivoboy is offline
post #2660 of 2666 Old 12-20-2014, 10:09 PM
Dominic26's Avatar
Quoted: 54 Post(s)
The short answer is no. HDMI is digital and connects using the "digital handshake". All the other connections are analog. Here is a link to the owner's manual, http://usa.yamaha.com/products/audio...2600_black__u/ . On page 22 of the manual (page 26 on the adobe reader) you will see the flow chart of signals. I also have an Aventage (A-2000) and the same applies. Once the manual is downloaded to your Adobe Reader I would save it to your hard drive for future reference.
post #2661 of 2666 Old 12-20-2014, 10:16 PM
Dominic26's Avatar
Quoted: 54 Post(s)
This is the product page. At the bottom of the page is a tab called "support". Click here and you will get the actual link itself for the manual.
post #2662 of 2666 Old 12-21-2014, 11:05 AM
tivoboy's Avatar
thanks
Thanks for the reply.
What I actually did and found to work was to get one of those HDMI to component and red/white AV composite breakout cables. I never really thought they worked, but plugging it in to the components ins remaining DVR/VCR2 in this case.. telling the receiver it was component (even though going from the apple TV (at 720P and 60hz) seemed to work..
decent quality, sound, etc..
work around for sure, but probably the only way to get it to work at this point.
tivoboy is offline
post #2663 of 2666 Old 12-26-2014, 04:46 PM
Liked: 0
I have my sister's yamaha rx-v1600. It has recently started to exhibit a hum when you used it. I was wondering if anyone on here could let me know if it was even worth my time to pursue a fix for it or would my time and her money be better used just buying a new receiver?
Soklo1 is offline
post #2664 of 2666 Old 02-02-2015, 06:05 PM
dexterblack's Avatar
Quoted: 24 Post(s)
Love my 2600
I just upgraded my projector to 1080 p. I purchase a hdmi matrix to handle 1080p. I love the sound of the 2600 and to get similar sound quality I may have to spend upwards o $700. I am content to use my hdmi matrix to send sound to 2600 and send video straight to projector. Any suggestions about upgrding avr decoders or network access?
thank you for all comments and replies
dexterblack is offline
post #2665 of 2666 Old 12-06-2015, 01:21 PM
catherwood's Avatar
hi everyone... just hooked up my new ps4 to the 2600, with HDMI cable. only played a little while when the 2600 started to shut off. This happened 4-5 times, and each time i had to press the power button for it to come back on. It seemed to coincide with things happening on the ps4. I tried a different game and the same thing happened, a number of times. I dont understand it... the ps4 and controller is bluetooth.... the 2600 is IR. Has anyone heard of this happening... btw, this never happened with my old ps3. Help.... i like my 2600 and dont want to replace it. thanks.
catherwood is offline
post #2666 of 2666 Old 12-07-2015, 08:23 AM
Marc Alexander's Avatar
Quoted: 748 Post(s)
Liked: 441
Not worth fixing. I've seen them on eBay for $40. I think you might be able to sell one for $100 if you had all of the original accessories and box in mint condition.
I bought an 1800 which is equivalent to the 2600 for under $200 on eBay. It does everything except 3D and 4k. A marked SQ improvement over my 1600. I moved the 1600 into my bedroom.
Also the 1600 (2600?) doesn't accept 7.1 LPCM from PlayStation or Xbox, only 5.1.
Marc Alexander is online now
