HK 635/435 firmware upgrade experience - Page 14 - AVS Forum | Home Theater Discussions And Reviews
post #391 of 417 Old 06-21-2008, 08:14 AM
cccs's Avatar
the firmware 4.12 has some bugs to store the eq and some others if you do a
hard turn off.
if you just turn your receiver in stand by there are no probs.
ich have upgrade my firmware to 4.15 with no probs
cccs is offline
post #392 of 417 Old 06-21-2008, 08:42 AM
jonnyozero3's Avatar
My 435 recently acquired a habit of dumping settings even if I haven't done a hard turn off. Sigh. Now I have to drag the PC downstairs to update it
Overall it's been a great unit and served me well, but I think I see some Pio Elite in my future
- Jon
"010 Meh"
jonnyozero3 is offline
post #393 of 417 Old 07-02-2008, 08:29 PM
redsandvb's Avatar
Did the upgrade go alright?
I want Ed on DVD/Blu-ray!
redsandvb is offline
post #394 of 417 Old 08-17-2008, 10:20 AM
02fizzy's Avatar
Can someone please tell me how to find out what version I have? 4.05, 4.12, 4.15.
02fizzy is offline
post #395 of 417 Old 09-25-2008, 08:34 PM
Oh hey, I never got a thread notification from this.
I actually am about to do it right now...I never got around to it because I was out of town for awhile and very busy with work. I'll post in a bit with an update Hopefully it won't drop settings anymore.
- Jon
"010 Meh"
post #396 of 417 Old 09-25-2008, 08:35 PM
I think you just have to hold the > right arrow button down while it's in standby mode (powered off, but with the amber power light) until it starts up and it should tell you.
- Jon
"010 Meh"
post #397 of 417 Old 09-25-2008, 11:14 PM
And the verdict is - it went fine. I got a verification error, but it went up to 5.15 without any other problems. I'll be happy if it keeps its settings from now on. One thing I noticed is that the EzSet program worked much better this time - the level trims were within 1dB of my own readings, and the distances were decently close as well. Maybe it was a fluke, but I think they tweaked it.
- Jon
"010 Meh"
post #398 of 417 Old 09-26-2008, 04:59 AM
sensibull's Avatar
A bit off topic, but has anyone achieved serial control (preferably bi-directional) of a x35 unit, without the help of some expensive piece of software like CharmedQuark? I'm slogging my way through the binary commands and computing the checksums at the moment, but it would help to know it can be done.
sensibull is offline
post #399 of 417 Old 10-11-2008, 02:28 PM
Tarheel72's Avatar
Is there any way to update the 635 without a serial connection? I was never able to find a laptop with a serial connection and have no desktop in the area. Hell, I don't know if you can even find a serial cable around anymore. last time I tried it was almost impossible to find one even at my local radio shack. Is there any method that can be done with a wireless connection????
Tarheel72 is offline
post #400 of 417 Old 10-13-2008, 04:01 PM
jbrandle's Avatar
I was just doing an update on my AVR 435 when the power went out. Now my 435 will not turn on. The memory was erased, but not updated. Does anyone know what I have to do? Do I have to take it to Harmon Kardon?
jbrandle is offline
post #401 of 417 Old 10-14-2008, 02:52 AM
cccs's Avatar
yes, the only way is to ship him to harman. if its out of warenty you must pay for that ( not cheap ).
so i think phone them first
cccs is offline
post #402 of 417 Old 10-17-2009, 05:41 PM
miked2023's Avatar
so do they not support these firmware updates anymore? the link in this thread doesn't work and when I go to the site I find nothing. I'm on the last version before the final one that came out and m just now getting around to it (serial cables and all!) but am I too late?
miked2023 is offline
post #403 of 417 Old 10-17-2009, 07:46 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Call HK and ask for an update CD if its available.
Afro GT
afrogt is offline
post #404 of 417 Old 11-01-2009, 05:01 PM
Flatypus's Avatar
I've contacted HK in hopes that they can help me locate the latest AVR 635 firmware file. Until then, I was hoping someone would be kind enough to email it to me so I can get a head start or have it handy in case HK doesn't come through for me?
Flatypus is offline
post #405 of 417 Old 11-02-2009, 01:27 AM
collin's Avatar
i need it too. PM me if you can help.
collin is offline
post #406 of 417 Old 11-02-2009, 04:56 PM
Flatypus's Avatar
I received the following response from HK support:
"Hi Eric,
Thank you for the inquiry. If you are looking for an firmware upgrade for your AVR635, currently is unavailable as the website is being restructured. You may want to check the website for the upgrade after couple of weeks. I apologize for the inconvenience.
I hope this helps.
Sincerely,
Andy
HCG Customer Support"
That said, hopefully someone can come through with the update via email as it doesn't look like HK is being too cooperative.
Flatypus is offline
post #407 of 417 Old 11-06-2009, 03:01 PM
Flatypus's Avatar
I'm pleasantly surprised with Harman's customer service, after what seemed like a losing battle (after numerous email exchanges). I came home to an envelope from Harman containing a disk and printed instructions for the AVR635 Firmware update. The disc includes v4.15/5.15, which is the latest for this model.
Since no one seemed to have the firmware, I've decided to help my fellow AVSforum members by making a .BIN backup of the entire disk. I'm still looking into the best method for uploading this but it should be a quick download as the file is only 3MB.
Flatypus is offline
post #408 of 417 Old 11-06-2009, 07:53 PM
redsandvb's Avatar
I'm using the same computer, cable, etc I used to upgrade to 4.12 or whatever it was. Anyone have trouble with the upgrade program telling you it is incorrect for your model?
I downloaded the upgrader multiple times from the US site (before they upped their new site) and kept getting the same error. Also, tried a factory reset prior to upgrade. The upgrader could see and control the 435, double/triple checked my serial number, picked the right .cpu file when prompted to, and nada. So I gave up. Wanted to upgrade because I now lose settings at any power outtage.
Any experience with this?
post #409 of 417 Old 11-09-2009, 01:05 AM
miked2023's Avatar
After emailing them, I got no response, but a few days later came home to the cd in my mailbox. I had to track down a computer with the right ports and just did the upgrade. Everything went well.
post #410 of 417 Old 11-12-2009, 11:40 PM
collin's Avatar
Thank you for your inquiry. The firmware is currently being tested and should be available for download within the next two to three weeks. Please access the below URl for downloading the firmware..
http://www.harmankardon.com/EN-US/Pr...px?PID=AVR+635
(link doesn't work at the moment...)
collin is offline
post #411 of 417 Old 11-13-2009, 04:01 PM
Flatypus's Avatar
I posted the AVR 635 .bin file as promised. You can burn this to a CD using freeware application ImgBurn (imgburn.com) or burning programs like Nero or Roxio. You can also use freeware app "Virtual Clone Drive" (slysoft.com) to "mount" the image on your PC without wasting a physical CD-R.
Here's the link: http://www.megaupload.com/?d=LZ0W3HW8
Enjoy!
Flatypus is offline
post #412 of 417 Old 01-22-2010, 02:43 PM
kidastra's Avatar
Well for anyone stumbling onto this post, I just ran the update myself, the files are located on the HK website. I had a heck of a time with the Wait Data screen. Finally figured out that the com port for the serial port has to be 1, I think 1 is reserved on most pcs. Also I spoke to a HK rep who did in fact tell me that a USB to RS232 cable/adapter would work. he also listed some that were tested to be working. I purchased a no name usb to serial cable and mine worked fine, picked it up for 11 dollars after tax!
kidastra is offline
post #413 of 417 Old 05-11-2010, 06:27 AM
Fackamato's Avatar
Hey guys.
I just attempted an upgrade on my AVR 635, but it failed in the end. The instructions said to retry the upgrade, but that failed. I only get the "WAIT DATA" screen now.
I've tried to power off the AVR, then powering it back on. Only the standby LED glows, it doesn't respond to any buttons or the remote. And still, "WAIT DATA"...
What should I do?
Fackamato is offline
post #414 of 417 Old 06-30-2010, 09:41 PM
coolcorgi's Avatar
The problem with my 635 is that after powering up my unit, it powers down after a few seconds. Been having this problem for awhile. I've tried the factory reset numerous times. Does not fix the problem. I finally had to disconnect the unit and quit using it.
I bought the receiver new 6 or 7 years ago and have never done any firmware update to the unit. Will the firmware update correct the power shut down issue I'm having? If not, then I'm thinking of sending it off to be repaired, and then hopefully let the repair shop update the unit while they've go it.
Any help on these issues would be greatly appreciated.
coolcorgi is offline
post #415 of 417 Old 07-01-2010, 01:15 AM
Fackamato's Avatar
Originally Posted by Fackamato View Post
Hey guys.
What should I do?
Solved it with money and time. (drove the unit to a shop that repaired it somehow)
post #416 of 417 Old 09-30-2013, 02:45 PM
Petar Tikvic's Avatar
I updated my AVR 635 and now it wont power up I am so mad now I called HK support need to ship it to them for repair.... Can I get new firmware.
Petar Tikvic is offline
post #417 of 417 Old 08-11-2015, 02:30 AM
Liked: 0
Originally Posted by cccs View Post
the firmware 4.12 has some bugs to store the eq and some others if you do a<br>
hard turn off.<br>
if you just turn your receiver in stand by there are no probs.<br>
Hi,
Are you still in a position to send me the necessary files for the European update to the AVR 435 ?
I am unable to get HK to send them to me, in fact they deny that they even exist !
Appreciate any help you can give !!
FlashBurney
FlashBurney is offline
Harman Kardon Avr 635 7 1 Channel Surround Sound Audio Video Receiver , Harman Kardon Avr 435 7 1 Channel Home Theater Receiver
