Pioneer Elite 59Txi Owners Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 199 Old 06-25-2009, 10:48 AM
markabuckley's Avatar
Quoted: 101 Post(s)
Liked: 34
hiya - can just about fully control mine with a Logitech One - it has an downloadable controller file for the 59txi online
Originally Posted by MI_CT View Post
hey all,
I unfort broke my remote to my 59 txi the other day. After moving the remote touch screen decided to stop working. So I tried to take it apart and cracked the screen. Looking on line i can order a replace to the cost of 400ish.(i can buy an new cheap receiver for that much)
So I have 2 questions, anyone have one they like to sell cheap? and other question anyone fully controlling their receiver using a universal remote? -if yes to remote did you have to manual do learn function or did it know all the functions via download,etc.
markabuckley is offline
post #92 of 199 Old 07-26-2009, 12:42 PM
Quoted: 101 Post(s)
Liked: 34
I'm still enjoying the USB input on mine
8 channel 48khz lossless - or in most cases I set to 6 channel + PLIIx for rear
just a pity when I switch to 2 channel trailers - that I have to cycle through 6 channel to 7, 8 and then to 2 - to then be able to use full PLIIx
I don't suppose there are any discrete codes for this are there ? I suppose I could set up a macro
post #93 of 199 Old 07-26-2009, 04:33 PM
spongebob's Avatar
Quoted: 90 Post(s)
Hi Guys
I just added a 51 to the 59. Analog out from the 51. CD'd sound awesome, even my "harsh" ones.
Question:
Would DD or DTS movies benefirt from the multi-channel out/in?
I know it will for HD audio content but what about DVD audio? (DD &DTS)
Long live the might 59!!!
bob
spongebob is offline
post #94 of 199 Old 08-08-2009, 08:04 PM
tboo's Avatar
Does anybody know where I can find a 59Txi? Im in the market for one.
tboo is offline
post #95 of 199 Old 08-08-2009, 10:51 PM
spongebob's Avatar
Quoted: 90 Post(s)
ebay or audiogon. Don't give up. It's worth it!
bob
post #96 of 199 Old 08-09-2009, 06:01 AM
tboo's Avatar
bob
All I can find are some 49txi's
tboo is offline
post #97 of 199 Old 08-09-2009, 07:13 AM
spongebob's Avatar
Quoted: 90 Post(s)
Patience!
The 49 is very nice. Same amps, missing advanced MCACC and I forget what. For 2 channel analog, should be close.
bob
post #98 of 199 Old 08-09-2009, 09:12 AM
spongebob's Avatar
Quoted: 90 Post(s)
http://cgi.ebay.com/ws/eBayISAPI.dll...E:B:SS:US:1123
Snag it!
bob
post #99 of 199 Old 08-10-2009, 08:08 AM
tboo's Avatar
Snag it!
bob
Somebody beat me to it.
Oh well, not all is lost. While I was searching Ebay I came across a Yamaha Z9 & ended up buying that.
tboo is offline
post #100 of 199 Old 08-10-2009, 11:35 AM
mcfoo's Avatar
Sad. I happen to have one that's available...
mcfoo is offline
post #101 of 199 Old 08-10-2009, 11:43 AM
tboo's Avatar
PM me-I still might be interested.
tboo is offline
post #102 of 199 Old 08-10-2009, 03:18 PM
mgfred's Avatar
Hi Guys
Question:
bob
Bob:
I've got a 09 connected to my 59TXi and exclusively use the multi channel inputs for all DVD and BD audio. I did buy a optical cable for the occassional DTS-ES 6.1 or DD 5.1 EX track, but the 09-59 combo sounds so good I have not even bothered to hook it up. I'd use the multichannels for everything..
Fred
mgfred is offline
post #103 of 199 Old 08-10-2009, 03:42 PM
spongebob's Avatar
Quoted: 90 Post(s)
Originally Posted by mgfred View Post
Bob:
Fred
I have been using the MCH for movies, BD & DD, DTS, but the midnight mode doesn't work right. It acts like a loudness function, boosting at all volumes. I like night mode for the family viewing. keeps the peaks down so my wife doesn't jump out of the seat so far
(works properly w/ optical out)
bob
post #104 of 199 Old 08-10-2009, 04:21 PM
mgfred's Avatar
bob
That may have to do with you using stream direct possibly. Personally I shut it off and use MCACC and apply THX Ultra2 to any 5.1 (6 channel in) source. For the few 7.1 BDs I have, I change to 8 channel in and apply MCACC and THX to it. There's a few things that don't work with stream direct, I also use the ATT INPUT setting to make sure the analog inputs don't set off my "over" light, after applying the DTS-MA firmware to my player I started to see that occasionally.
Fred
mgfred is offline
post #105 of 199 Old 08-10-2009, 04:43 PM
Quoted: 101 Post(s)
Liked: 34
I've asked this question before - but never really got an answer that I understand - why can't the 59TXi apply DPLIIx to a 5.1 D.Digital input to simulate the rear centre when only using 1 back channel ?
wheras DPLIIx can be used to simulate for a single back channel on 2 channel sources ?
I only have choice of D.Digital EX or SX for 5.1 when I use a single rear (I only have one centre rear) but if I change the speaker menu setup to say I've two rear centres - D.Digital + DPLIIx becomes available
weird
post #106 of 199 Old 08-10-2009, 05:11 PM
spongebob's Avatar
Quoted: 90 Post(s)
Fred
Stream Direct (1,2, or 3) won't allow night mode. SD1,2 do apply MCACC oddly enough. SD3 does not, pure analog.
When I change to Standard, night mode is allowed but behaves as I described above but not how it should.
On my 51 player, I am able to output mch and optical out so I just switch to optical (standard) when I want nite mode.
bob
post #107 of 199 Old 08-22-2009, 05:04 PM
Quoted: 101 Post(s)
Liked: 34
if anyone has the service manual - could they let me know what USB receiver chip the 59TXi uses please? I'm interested to see what implentation it has over USB (ie the mode it uses) cheers, Mark.
post #108 of 199 Old 08-25-2009, 11:55 AM
vox8940's Avatar
I just picked up a used 59Txi and will be pairing it with my DV-79Avi player via i.link. For those doing this combination, have you found that using a high-end i.link cable improves the sound over a $10 cable?
My experience has been that USB cables and digital coax cables make a difference. I've tried MIT Shotgun Digital, Virtual Dynamics Master LE 2.0, and others, and they open up the sound stage, increase detail, and extend frequency response.
Some i.link cables I've been looking at include Audioquest 1394-3 ($150), Acrolink Mexcel ($725), Siltech ($1050). Locus Design and Ridge Street Audio are supposed to have one soon. I realize there is a point of diminishing returns, so I would like to stay under $300.
Any recommendations? Please no Monster or RatShak - those are not high end!
vox8940 is offline
post #109 of 199 Old 08-25-2009, 12:24 PM
ccotenj's Avatar
Liked: 101
interestingly enough, my $4 firewire cable works just fine between my 79avi and susano...
yes, there is a point of diminishing returns... and it's well below $300...
however, to each his own...
- chris
ccotenj is offline
post #110 of 199 Old 08-25-2009, 11:53 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 31
No, I do not hear any difference or "improved sound" at all between $10-$15 i-Link cables and ones that cost over $100. There is no reason to spend big money on them. Spending anything much more than $20 for a well made i-Link cable, is also spending too much.
Johnla is offline
post #111 of 199 Old 08-26-2009, 05:56 AM
vox8940's Avatar
I appreciate the opinions, but which $100 cables did you try? I used to be a cable skeptic like most, until I actually tried one and heard the difference for the better.
I'm looking for some specific examples instead of generalities.
vox8940 is offline
post #112 of 199 Old 08-26-2009, 07:30 AM
QuadESL63's Avatar
That's the reason I didn't get rid of mine
QuadESL63 is offline
post #113 of 199 Old 08-27-2009, 08:53 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 31
Just buy whatever cable you want then, because telling you any brand names is not going to change your mind about what you think cables can or can not do.
Johnla is offline
post #114 of 199 Old 11-08-2009, 03:38 PM
Quoted: 101 Post(s)
Liked: 34
do any of the "stream direct" etc modes - allow for as good as analogue passthrough for a multichannel analogue input ?
ie I would like to input a 7 channel analogue in - without it then being converted to digital and and back to analogue again - yes without bass management or EQ.
manual implies this isn't possible ?
manual implies that in one of the stream direct modes - a multichannel analogue input will be down-converted to 2 channel, and in another of the stream direct mode, if a multichannel analogue input is input, then full bass management etc will be applied - ie it will have to be re-digitised
post #115 of 199 Old 11-08-2009, 03:45 PM
ss9001's Avatar
Quoted: 358 Post(s)
Liked: 423
do any of the "stream direct" etc modes - allow for as good as analogue passthrough ?
ie I would like to input a 7 channel analogue in - without it then being converted to digital and and back to analogue again - yes without bass management.
marka,
This will do it -
Use Stream Direct 3 for your 7 ch analogs and doesn't convert analog inputs to digital. Check the manual, page 47 (US version) for a description. It doesn't say specifically no A/D/A conversion, but it's very much implied. SD3 is the analog passthrough mode with analog sources.
"SD:3 ANA - DIRECT – All analog sources are heard without any digital processing. All processing is done through the analog circuitry and the center channel, if present, will be sent to the front right and left speakers (the channel level is adjusted automatically). With digital sources, playback is the same as the NORMAL setting (above)."
ss9001
Steve
Steve
ss9001 is offline
post #116 of 199 Old 11-08-2009, 04:53 PM
spongebob's Avatar
Quoted: 90 Post(s)
Originally Posted by ss9001 View Post
marka,
This will do it -
"SD:3 ANA - DIRECT - All analog sources are heard without any digital processing. All processing is done through the analog circuitry and the center channel, if present, will be sent to the front right and left speakers (the channel level is adjusted automatically). With digital sources, playback is the same as the NORMAL setting (above)."
Steve,
MCCAC is still active, tho, right?
ss9001
Steve
When I listen to CD's from the analog outputs of the BD-51, MCCAC still cycles through it's choices (OFF, ALl channel, etc) What is strange is that the red light indicator doesn't light and I don't think it really is active. It should flash "Stream Direct" like when you try to activte Night mode, tone, etc. I think it's a software bug?
thx
bob
post #117 of 199 Old 02-01-2010, 07:33 PM
geoellis's Avatar
Anyone using an iPod with their 59? Is it possible?
geoellis is offline
post #118 of 199 Old 02-01-2010, 11:15 PM
spongebob's Avatar
Quoted: 90 Post(s)
Sure, Just use the headphone out with an adaptor to stereo RCA and plug in to the front input.
bob
post #119 of 199 Old 02-02-2010, 11:50 AM
geoellis's Avatar
Thanks spongebob, I'll give that a go when I return home later this week. How does it sound to you?
geoellis is offline
post #120 of 199 Old 03-30-2010, 12:47 PM
Quoted: 101 Post(s)
Liked: 34
anyone know if Bass Management is applied to the USB input ? I thought from some 2 channel tests it was (as sub was working - even though only 2 channel input)
but when watching movies I'm half sure my speakers are outputting the full range ?
is it possible that in 6/7/8 channel USB input mode ? it assumes the Bass Management is done external to the amp ? MCACC is definately being applied and is on - but I'm not sure if BM is ?
any ideas ?
