The "Official" Denon AVR-2807 Thread - Page 138 - AVS Forum
 1Likes
Old 06-21-2014, 06:10 AM
habudab's Avatar
I have a denon 2807. and a sony blue ray player.. I had a lightning strike and the HDMI in and out ports on DENON do not work.. so I wanted to go back to the old way I set up my DENON and DVD player with HDMI from blu ray to TV and then optical line to the DENON... I think that used to work with the old DVD player.. but I cant get any sound when I play a BLu Ray.. I am getting the DENON fixed, not sure what to do for sound until that??? help. I did the set up screen and set DVD to OPTICAL 1 which is the one I have the line hooked into from the TV?? help??
habudab is offline
Old 06-21-2014, 06:27 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 2604 Post(s)
Liked: 1894
The optical inputs may have been taken out as well. Try connecting the optical from the Blu Ray player in order to get DD/DTS 5.1 as the optical from the TV is likely only going to pass stereo 2.0.
"JD" – jd@avscience.com ; Call me --> 585-645-1006, AVScience - AVSForum sponsor and dealer for AVRs and Speakers
Daily 8am – 8pm EST
Call for info on Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
Old 06-21-2014, 10:11 AM
habudab's Avatar
i did that.. still nothing. I am not sure it is the optical.. because I have an optical from my direct tv box to the Denon.. and it is working perfectly.. dolby 5.1..
any other options??
another thing, when I plug the optical at the tv. the other end of the optical line is lighting up RED.. so I figured it is working from the tv??
habudab is offline
Old 06-21-2014, 07:29 PM
JChin's Avatar
Quoted: 125 Post(s)
Liked: 140
Hi habudab, check the Blu-ray audio track option. Most likely it doesn't offer standard dolby digital (but it may have Spanish, French, etc...).
JChin is offline
Old 07-04-2014, 06:27 PM
kwburn's Avatar
Hello to anyone still watching this thread
I'm using an AVR-2807 which I do like very much EXCEPT for the volume control ratio with the knob.
Maybe this is normal but on mine you have to turn the volume knob what I consider A LOT in order to bring up the volume or bring it down. Meaning I have to keep spinning and spinning it to go from very low to very high.
While this of course allows it to be very finely adjusted as needed, I find it to be a real pain. Seriously I would be happy if I could just do two twists of the wrist to get from low to high. Currently it takes 9 twists of the wrist or 7 complete turns of the dial to get from lowest to highest.
Is there any way to adjust the ratio in the settings? I looked through the manual the best I could and didn't see anything.
Also, while I am asking...is there any way to make the volume increments be in another format than -80dB to +18dB? No biggie but thought I would ask.
kwburn is offline
Old 07-04-2014, 07:53 PM
afrogt's Avatar
Quoted: 379 Post(s)
Liked: 443
Do you use/have the remote? That way you don't have to spin the volume dial on the receiver.
If you want to get the manual in pdf you can download it here:
http://a248.e.akamai.net/pix.crutchf...033AV2807B.PDF
Page 55 shows you how to set the power on volume. Maybe you should set it to -30 or -25 so that you don't have to start off with a really low volume.
Afro GT
afrogt is offline
Old 07-05-2014, 05:12 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
No. A new "absolute" volume display (0-100) was only first introduced on XX10 and newer models.
Daily 8am – 8pm EST
Old 07-28-2014, 08:15 PM
Liked: 0
Selecting both A and B Speakers on a Denon AVR 2807
I have a Denon AVR 2807 with no remote. I have been unable to select the A & B speakers to play at the same time. Help! Please! I need both to play at the same time.
Seaplane100 is offline
Old 07-29-2014, 03:59 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Purchase a Harmony remote and download the 2807 remote codes from the Logitech website.
Daily 8am – 8pm EST
Old 10-12-2014, 07:29 PM
Okiedoke's Avatar
Subwoofer problem
With the help of this forum, I was able to get the AVR-2807 set up with the PSW125 many years ago. One of the main problems before was that there was no sound (connected using LFE) and the light at the back of the subwoofer stayed orange instead of green. Then we had a child and moved and have spent the last few years only watching TV at night after he went to bed on low volume and with closed captioning on. Today, I finally had a day to myself so thought I'd recalibrate Audyssey and get the system sounding optimally again. Well, it looks like I have the exact same problem again. I have all speakers set to large and the subwoofer to main+LFE with the crossover at 120Hz. I've tried on, auto, and standby setting on the PSW125 as well as the phase switch. Even with the volume on the subwoofer up full, there's still nothing. Any suggestions would be much appreciated.
BTW, I also noticed the Audyssey light on the front panel is red instead of green. How do I make it green again? Do I need to recalibrate?
Thanks in advance for any assistance.
Okiedoke is offline
Old 10-13-2014, 04:23 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Set the sub gain to about 10 o'clock. Run Audyssey. Reset all speakers to SMALL and raise the crossovers up to 80Hz. Raise the Subwoofer level about 5db using the AVR test tones. Press "Room EQ" until Audyssey is selected to change light to green.
Daily 8am – 8pm EST
Old 10-18-2014, 05:06 PM
Okiedoke's Avatar
Thanks a lot! I'm getting sound from the subwoofer now. The Audyssey light is still red. Does this mean Audyssey is still on and is just saying that I've changed settings after running Audyssey? Should I run Audyssey again after changing speakers to SMALL and raising crossovers?
Okiedoke is offline
Old 10-18-2014, 05:24 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
No need to run Audyssey again as it is still active.
Daily 8am – 8pm EST
Old 10-18-2014, 06:09 PM
jlever's Avatar
My 2807 will cut out sound randomly. Input is by optical cable. Stays out until I power off the receiver and back on. Any ideas?
John
jlever is offline
Old 11-10-2014, 02:21 PM
Liked: 0
Hey all,
I picked up a 2807 via Craigslist for $125. Upon getting it home found out it doesn't work right. Took it in for diagnostics. The repair folks said it was the main DSP board and there are no available parts (probably too old). Does anyone have advice for me? Would it be worthwhile to buy another broken unit and try to repair one? Sell it? Scrap it? Thanks.
zeldaman is offline
Old 11-10-2014, 02:31 PM
batpig's Avatar
Quoted: 1313 Post(s)
Liked: 1693
Junk it, the $125 is a sunk cost (unless you can get the guy you bought it from to refund you) and it's not worth putting more money into a unit that old.
You may be able to sell it broken for a few bucks.
zeldaman likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
Old 11-13-2014, 10:38 AM
Liked: 0
Thank you for the response. It's sad to see such a beautiful receiver be a waste of space.
zeldaman is offline
Old 12-31-2014, 02:36 PM
Mkard's Avatar
Originally Posted by zeldaman View Post
Hey all,
I am considering picking up a Craigslist 2807 also. For whatever strange reason I am strongly considering replacing my Adcom GFA 6000 and using this Japan-made Denon as amplifier from Yamaha 765. Can anyone think of a reason to not do something like this?
Mike
Mkard is offline
Old 12-31-2014, 03:23 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Yup. Keep the Adcom.
Daily 8am – 8pm EST
Old 12-31-2014, 03:45 PM
Mkard's Avatar
JDSmoothie,
So the @15yr old Adcom would give better amplification than the 8yr old Denon? I am not arguing so much as trying to understand how you reached your conclusion.
Mike
Mkard is offline
Old 12-31-2014, 04:02 PM
afrogt's Avatar
Quoted: 379 Post(s)
Liked: 443
Originally Posted by Mkard View Post
JDSmoothie,
Mike
I bought a used 2807 a couple years ago for $50. it works fine but is very user unfriendly. The remote is difficult, there are only 2 HDMI inputs, doesn't decode TrueHD or DTS-MA so you have to set your devices to send multichannel PCM instead.
I ended up taking it to my dad's house and installed in my old bedroom. I visit a couple times a month and only have the DirecTV genie mini connected to it with Energy RC Mini and micro speakers. It's perfectly fine for that use but I wouldn't want it as the control center for a main home theater setup. Very frustrating receiver. The newer Denon receivers and remotes are easier to use.
It does sound good though, don't know if it would sound as good as your Adcom.
Afro GT
afrogt is offline
Old 12-31-2014, 04:09 PM
afrogt's Avatar
Quoted: 379 Post(s)
Liked: 443
If both are 5 channel amps, I'd just use the Adcom. Simpler setup.
Afro GT
afrogt is offline
Mkard's Avatar
Afrogt,
Well, I was thinking of keeping the Yamaha as the controlling unit, and outputting to the Multi-Ch inputs of the Denon. Reputedly, the Denon amplifiers are high quality and fairly honest power ratings.
The Adcom puts out 100W pretty honest for the front channels, 60 for the rears. I'd expect the Denon to do reasonably well driving 3 speakers.
You got yours for a much better price than they show up here. People asking more than I am willing to pay so far. Keeping my eye out.
Mike
Mkard is offline
Old 12-31-2014, 04:12 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
JDSmoothie,
Mike
If only using the 2807 for external amplification, you likely won't notice any difference.
Daily 8am – 8pm EST
Old 12-31-2014, 04:14 PM
Mkard's Avatar
My surround L/R are Paradigm Monitor 7, V.2. Reasonably easy to drive. Front stage is V1 Paradigm Monitor 7, with a Paradigm reference Center. I am currently using the Yamaha to amplify the surround L/R and the height book shelves. Adcom doing the front 3 only, as it has a bad surround amp.
Mkard is offline
Old 12-31-2014, 04:15 PM
Mkard's Avatar
OK. I suppose I am just leaning in the direction of durability, as the Adcom is a bit long in the tooth. One channel has gone south already, but front stage is holding on.
Mike
Mkard is offline
Old 12-31-2014, 04:17 PM
afrogt's Avatar
Quoted: 379 Post(s)
Liked: 443
Afrogt,
Mike
The former owners bought a newer Denon receiver with more HDMI inputs, networking, Pandora and internet radio streaming, etc. Even though the new one was a lower level model, it was easier to use. The wife told the husband to get rid of the 2807 ASAP!!
I got lucky and saw it on Craigslist at the right time. But after fiddling with it for a few days, I was glad I didn't pay any more than that.
I dunno if the amps in the Denon would be better than a dedicated 5 channel amp like the Adcom.
Afro GT
afrogt is offline
Old 12-31-2014, 05:06 PM
Mkard's Avatar
Afrogt,
Yep. You and me both. But, if I ever stumble upon one of these at a price close to what you found, I'll sure as heck find out!
Happy New Year. Be safe.
Mike
Mkard is offline
Old 12-31-2014, 05:24 PM
batpig's Avatar
Liked: 1693
Amplification technology doesn't change that much. Receivers are advancing rapidly in processing and features, not raw guts amp grunt.
