The "Official" Denon AVR-2807 Thread - Page 140 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #4171 of 4186 Old 08-25-2016, 02:15 AM
Liked: 0
I replaced my non-HDMI TV with a Panasonic 3D TV. From a PS3, I used HDMI directly to the TV and an optical cable to the 2807. I don't used HDMI on the 2807.
I was thinking of replacing the PS3 with a Blu ray player (like Oppo BDP-103) with dual HDMI output. If I configure the Oppo HDMI as Split A/V where HDMI 1 goes to the TV for video, and HDMI 2 goes to HDMI input on the Denon 2807 for audio (having a dummy video stream), do I still need to connect an HDMI cable from the 2807 HDMI out to the TV in order to get sound? Currently, I only use component connection from 2807 to TV for Menu Setup.
I want to use HDMI audio so I can get lossless High Definition audio from the blu ray.
I don't like to use analog connections from the Oppo to the ext. in of the 2807 if it disables Audyssey.
I really like the Denon 2807, and I don't intend to replace it soon.
art3 is offline
post #4172 of 4186 Old 08-25-2016, 06:08 AM
jdsmoothie's Avatar
Quoted: 12105 Post(s)
Liked: 5509
Generally no, as you're not passing any video to the TV from the AVR; however, in some instances the HDMI connection to the TV is required to complete the HDMI handshake and allow audio to play from the AVR. If this occurs, you can generally resolve it by connecting an HDMI switch/splitter or HDMI Detective to the AVR's HDMI monitor output (although may need to pass video through it to the TV one time so the TV's EDID information is passed to the splitter/switch or HDMI Detective).
jdsmoothie is offline
post #4173 of 4186 Old 08-25-2016, 10:03 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Just remember you need to set your Oppo to send lossless multichannel PCM to the AVR-2807 because the receiver does not decode TrueHD and DTS-MA. The 2807 uses HDMI 1.2 so you cannot bitstream TrueHD and DTS-MA. I have that receiver at my father's house. A little short on HDMI inputs with only 2 but otherwise a solid and powerful receiver.
the remote is funky too but once you figure it out you're okay.
Afro GT
afrogt is online now
post #4174 of 4186 Old 08-26-2016, 06:42 AM
Liked: 0
Thanks jdsmoothie and afrogt for your reply.
My Panasonic TV and this receiver have this HDMI issue that freezes this receiver so connecting an HDMI from the 2807 to the TV might be problematic. Others have also reported this issue on this thread.
Should I consider using the Oppo BDP-103 7.1 analog outputs to the ext. in of the 2807. Would I get better sound even without Audyssey.
Or should I consider the Oppo BDP-105D instead and use the 7.1 analog output for its audiophile Sable DAC. Would the Oppo BDP-105D be overkill for this receiver.
art3 is offline
post #4175 of 4186 Old 08-26-2016, 12:34 PM
jdsmoothie's Avatar
Liked: 5509
Using the EXT IN inputs, you disable Audyssey and would be using the DAC in the respective Oppo model. As most Oppo owners likely prefer using HDMI (for Audyssey), you would be better served upgrading to a more current AVR rather than going from the Oppo 103D --> 105D.
post #4176 of 4186 Old 08-27-2016, 12:50 AM
Liked: 0
Hmmm, maybe it's time to upgrade. I was thinking of the AVR-3300W, but then the closes match to the 2807 (I think) in terms of specs is the Marantz SR6010. I mainly use the 2807 for home theatre, and occasionally for music. I'm happy with the 2807 for home theatre, but 2 channel music could be better.
Do you think an Oppo (with Darbee) be a good complement to a new receiver and a worthy upgrade from PS3. Or should I get a less expensive consumer branded blu ray.
art3 is offline
post #4177 of 4186 Old 08-27-2016, 02:20 AM
jdsmoothie's Avatar
Liked: 5509
If you have a PS3 slim, I'd just keep it, otherwise, if a PS3 fat, then you'll want to upgrade to a newer model or the Oppo 103D.
post #4178 of 4186 Old 08-28-2016, 12:00 AM
Liked: 0
Can anyone make a suggestion on which I should go for. I used it mainly for home theatre. I listen to some music occasionally.
art3 is offline
post #4179 of 4186 Old 08-28-2016, 03:29 AM
jdsmoothie's Avatar
Liked: 5509
Both are sister models and use the much more advanced XT32 over just XT on your 2807. Marantz is better known for a better detailed music listening experience; however, is much more costly over the Denon. AVS no longer sells the SR6010, rather the newer SR6011 which will be able to use the new Audyssey phone app when released just as will the X3300W. Call for pricing and availability if interested.
post #4180 of 4186 Old 09-19-2016, 02:10 PM
Gallis1's Avatar
Thumbs down AUX L/R Input Not Playing In Stereo
Hello everyone. I have a question. I can't remember when this issue started. When I connect to play music from an iPod, phone or tablet via my RCA cable to 3.5mm the L/R aux input at the front of the receiver, I only get audio from the sub and right front speaker.
I watch TV in 7 channel stereo just fine and Blu-ray movies play perfectly fine through all speakers. Am I doing something wrong? Or, is my old AVR 2807 receiver starting to show it's age? I got it in 2007.
Any help/advice would be much appreciated!
Paul
Gallis1 is offline
post #4181 of 4186 Old 09-19-2016, 06:14 PM
jdsmoothie's Avatar
Liked: 5509
Paul
The issue likely resides with the iPod, however, try connecting it to the rear RCA inputs on the 2807.
post #4182 of 4186 Old 09-19-2016, 06:23 PM
afrogt's Avatar
Liked: 755
Or maybe you have a bad RCA to 3.5mm cable....
Afro GT
post #4183 of 4186 Old 09-20-2016, 11:54 PM
Gallis1's Avatar
@JDS smoothie, @afrogt ,
Thanks for your responses. I have swapped out cables and got the same result. I also get the same result from connecting my phone, iPod and tablet.
I will try an RCA input at the back of the receiver.
Fingers crossed and thanks again!
Gallis1 is offline
post #4184 of 4186 Old 09-23-2016, 11:10 AM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
What happens when you swap sides (e.g. hook up the RCA cable but feed it backwards, right side going to left input and left side going to right input)? Does the audio still only come out of the right front speaker or does it swap over to the left front speaker?
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #4185 of 4186 Old 12-26-2016, 05:23 PM
Liked: 0
I need help please.
I have a Denon AVR 2807 and I can not seem to figure out how to hook up it via my HomeSpot NFC-Enabled Bluetooth Audio Receiver for Sound System. It has a 3.5 connection to the device and a Red./White auxilary input to the Denon AVR 2807. Because of what I read, there are no AUX inputs, so I thought it said to use like the DVR Red./White audio input cables. But.. I can't seem to figure out if a) that is the correct way to do it? or b) how to get to the DVR. Right now it says V AUX and is playing my TV via a optical sound input.
Any ideas? I was looking forward to playing my pandora through my speaker and I have literally been trying for 2 frigging hours to figure it out, my last Onkyo I could just plug it into the front of it. But the inputs on the front of the AVR 2807 are apparently not for the red/white cable that comes with the NFC bluetooth device.
Help please !
Brian
Brian Tinsley is offline
post #4186 of 4186 Old 12-26-2016, 06:54 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Originally Posted by Brian Tinsley View Post
I need help please.
Any ideas?
Hi Brian Tinsley, connect the Homespot to CD input. On the remote press input mode button few times to cycle over to analog.
JChin is offline
