The "Official" Denon AVR-4306 Thread - Page 81 - AVS Forum | Home Theater Discussions And Reviews
post #2401 of 2412 Old 02-07-2015, 08:31 AM
kschoenberg's Avatar
I think if you go back through this thread you might find a changelog. I would suggest not making the change as you're happy with what you have and haven't experienced problems. While the chance of bricking your receiver is small...why risk it?
Originally Posted by tabooki View Post
I'm guessing I've have had my amp for probably 7 years now. Never bothered upgrading the firmware. Stumbled across this thread and I'm seeing lots of people posting about it. Judging from a recent post it looks like I can go straight to the 6.0.0.4 one from whatever I'm on now.
My question. Is it worth it? I'm really not experiencing any bugs or issues. Is there any audio improvements that would make upgrading worthwhile?
Seems like a minefield ridden buggy upgrade so if there is not much benefit unless I have a bug that get's fixed should I bother?
Thanks for any help.
kschoenberg is offline
post #2402 of 2412 Old 02-07-2015, 08:38 AM
Phase Error Question...
We recently moved and I now have my home theater setup with the Denon 4306 in the back. I have three speakers M&K 150s under my screen, an M&K Subwoofer off to the viewer's left and two speakers M&K 150s in the back. I made the cables and checked them for continuity. When I read the Audyssey auto setup the receiver complained that the speakers were out of phase. I checked multiple times...they're not.
I didn't have this problem in the past, but the receiver was in a more traditional location (under the screen) then.
Any one have any idea why I'm getting this error? I skipped through it and everything sounds okay.
The only other difference is that I'm using one of the newer (little tower) Audyssey mics rather than the button which was lost in the move.
post #2403 of 2412 Old 03-26-2015, 05:57 PM
Dutchman01's Avatar
Again the list of changes after upgrade up to 6.0.0.4 firmware:
* Main version update because off code bugs in the AVR-4306.
* Memory problems fixed for AVR-4306 can't remember serveral programmed stations etc.
* When several FM stations are programmed in the presets there occurs a
malfunction when you use PC Control or the AVR-4306.
* Improve the Transaction of Bass management setting.
* supporting the Audio Digital signal at PC resolution (SVGA,XGA,etc.) from the HDMI input with DVD-3930 or DVD-2930,
* when the customer connected the HDMI output of the source equipment which does not support HDCP
(High-bandwidth Digital Content Protection system) to the HDMI input of an AV amplifier, a picture is blinking.
* Improvement for the Web control.
* supporting the LPCM 7.1 ch digital signal form the HDMI input.
* supporting of the PC resolution (1600 x 1200, 60Hz max.) from the HDMI input.
You can grab firmware here: http://www.zoonsweb.nl/files/denon/AVR-4306/
DENON AVR-4306
Firmware: Main ver. 01.00, Sub ver. 00.50, DSP ver. 00.04.
DENON DVD-3930
Firmware: BE 8284-A, Make Day C09, DSP 8250, IP 070518
Dutchman01 is offline
post #2404 of 2412 Old 06-28-2015, 06:26 PM
awalt's Avatar
I am hoping someone can help me with a problem that has cropped up on my Denon AVR-4306 receiver.
Last week we lost audio on the DVD player. It was a low end Samsung. I did a little investigation and thought, since it was old, that the DVD player may have gone bad. I replaced it with another similar DVD player, low end ( but now has BluRay!), but still no audio. The problem is I can't get audio working despite all my efforts!
Here is my setup:
Input:
HDMI-1: DVD
HDMI-2: DirecTV box
HDMI-3: Apple TV
Output: HDMI cable to Sony TV.
Sound/picture from Apple TV and DirecTV are fine.
I have:
- replaced DVD player
- tried another brand new HDMI cable from DVD player to HDMI-1 input
- Unconfigured the Apple TV and put the DVD player on HDMI-3 (re-setup in Denon Setup, again video fine no audio, yet audio/video are fine on HDMI-3 input with Apple TV)
- Added a Coax cable from DVD player to Denon, and setup the input audio to come from that coax input (I think I might have read this won't work because it won't send Coax audio to the HDMI output to the TV though, this may have been bogus attempt)
- tried about 4 different DVDs
- checked to make sure there were no audio settings with volume or mute on both DVDs, and made sure mute was not on, on the Denon.
So I have basically replaced the DVD player, DVDs, HDMI cable, and tried two different ports (coax and HDMI) to figure out what was no longer working, with no luck. IT's like the audio is being suppressed from the DVD player for some reason. Did some technology change happen that DVD players' audio no longer works?
Does anyone have any ideas? I am lost what could be failing as I feel I have replaced everything that matters.
awalt is offline
post #2405 of 2412 Old 06-29-2015, 07:41 AM
jdsmoothie's Avatar
Quoted: 12078 Post(s)
Liked: 5499
Does the DVD player pass audio/video when connected directly to the TV? Try powering off the AVR and unplugging the power cord for 10 minutes.
jdsmoothie is offline
post #2406 of 2412 Old 06-29-2015, 08:41 AM
awalt's Avatar
I updated the firmware and the audio is back! Not sure why that would have been required - uit wasn't like there was a new DVD or something - it just stopped working. Oh well, it works now!
awalt is offline
post #2407 of 2412 Old 10-04-2015, 01:09 PM
Liked: 0
No Web Page Access
Hi, folks. I am trying to repair a black AVR-4306 (US model). Everything works fine but it can't be accessed over the network: the page is there but gives an Access Error. This was the result of attempting to upgrade the firmware to 6004. After searching around, it seems that this upgrade was for Euro models only. I found the Denon UK Firmware page & this Serial # isn't recognized.
I tried running the update repeatedly myself and it always fails at "Erasing (Web page)".
The SS Manager program seems to work fine...it backs up & loads the backup...but what does it back up...the settings?
The best bet seems to be the Firmware Recovery Tool but it fails at "Communication NG", despite a known working Com port & a tested straight cable. At the same time, the unit will accept SOME commands using the Serial Protocol, so I know that the RS-232 is there...just not responding.
I would appreciate any help or advice any of you might offer as to what to try.
UncleAndy is offline
post #2408 of 2412 Old 03-10-2016, 07:19 PM
Jameshtx's Avatar
Liked: 0
Hello. I just received my avr 4306 (black usa spec) as a gift. 1st receiver I have ever owned. Can someone please tell me how on earth do I upgrade the firmware on this thing?
I got a laptop running on wifi and 1 ethernet cable. What's the next step?
Thanks for your input
James
Jameshtx is offline
post #2409 of 2412 Old 03-12-2016, 02:27 PM
Jameshtx's Avatar
Liked: 0
I called Denon support on how to update firmware and she didn't know how to either
Jameshtx is offline
post #2410 of 2412 Old 03-12-2016, 03:09 PM
juxtafras's Avatar
I've had a denon avr 4306 for about 8 years and everything has worked well until today. All of a sudden today no sound goes to the subwoofer. No sound from games, movies or even the receiver setup test sounds. Al other speakers work well in my 7.1 setup. The subwoofer is set to on and I've set the decibel settings. The subwoofer power lights come on to confirm it has power.
Is there a setting that could cause this problem that I accidentally changed? I did notice that the display shows MultI and I accidentally pushed Amp on the receiver remote. Could that have caused this error? I remember I've accidentally pushed receiver remote buttons in the past and it has caused weird audio issues like this.
Any help is greatly appreciated. I've looked on many sites and the manual but I can't find a solution. Is there a way to reset the receiver to just start over and remove any setting that could be causing this problem?
juxtafras is offline
post #2411 of 2412 Old 03-13-2016, 03:22 AM
jdsmoothie's Avatar
Liked: 5499
Is the sub cable plugged into the AVR's sub "pre-out" and not the "EXT IN"? When you press the INPUT button on the remote, is it set to "Auto" and not something else? If yes, check to make sure the cable/sub are actually working by unplugging the cable from the sub pre-out and rubbing your finger over the end tip with the sub powered on. Hear static? If not, either the cable or sub is bad. Otherwise, if you do, refer to p. 64 in the Owner's manual to reset the microprocessor back to factory defaults.
post #2412 of 2412 Old 09-25-2016, 04:18 PM
Liked: 0
Trigger output problems
I have been using Trigger out for some time to turn on my external power amp (using a Niles Audio remote power device/relay.
I now want to add one to trigger two for a zone 2 power amp.
The problem is, when either zone is turned on, I cannot get the other trigger to work.
As an experiment, I turned on both main and zone 2, then I disconnected one of the trigger cables, and guess what, the other trigger activated.
Has anyone else seen this?
Could I maybe have the polarity reversed on one of the trigger cables - I checked it carefully with an ohm meter when I built the cables.
Any help would be welcome.
RandyBryant is offline
Denon Avr 4306b 7 1 Ch Home Theater Multimedia A V Receiver Black
