Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1073 - AVS Forum | Home Theater Discussions And Reviews
 146Likes
post #32161 of 44730 Old 01-25-2011, 06:27 AM
studlygoorite's Avatar
Quoted: 100 Post(s)
Liked: 42
Originally Posted by groy67 View Post
Hello everyone,
Is there a special way to attach or post the graphs?
sorry.. I tried a few different ways.
Thanking you in advance,
Gerry
When your graphs are on your computer screen press "Print Screen". Open "Paint" and press "Control V"(the control key and the letter V key at the same time). The graph should now show on your paint sheet, press "File" an hit "Save As", change the file to a "J Peg" file and save it, you should be good to go. Do the same for the rest of the files. Don't forget to show your "Targets" screen also.
John
Anthem AVM 60, Paradigm Sub 2, Paradigm S8s with C5, Anthem Statement M1 Amps, 174" Curved AT Scope Screen, Epson Pro Cinema LS10000 Laser 3D Projector, Samsung 4K Blu-ray Player, Xbox One, PS4, Clark Synthesis Transducer For Chair
studlygoorite is offline
post #32162 of 44730 Old 01-25-2011, 10:42 AM
p.las's Avatar
John
i have the same question. i dont have "print screen" iam running windows 7.
Peter
Denmark
p.las is offline
post #32163 of 44730 Old 01-25-2011, 10:43 AM
jitenn's Avatar
Is there a sound quality difference between using L/R preamp-out connections vs. LFE-out connection for a sub-woofer?
I currently use LFE-out on my Focal SW800V, but want to use L/R preamp-out instead to keep the analog signal from my turntable/phone stage as pristine as possible. Only way to do this seems to be to bypass the ADC, which in turn means no ARC or s/w LFE out, so leaves me with no choice but to wire s/w directly using L/R preamp-outs. Am guessing this would be my permanent configuration if it works out.
I would normally try this out before asking, but I do not have long enough cables to experiment. Before I plop down cable $, I thought I'd ask you experts...
jitenn is offline
post #32164 of 44730 Old 01-25-2011, 10:48 AM
drhankz's Avatar
Quoted: 76 Post(s)
Liked: 62
I have PRINT SCREEN in Windows 7
drhankz is online now
post #32165 of 44730 Old 01-25-2011, 12:38 PM
gbhodge's Avatar
Originally Posted by obie_fl View Post
Lost me on this one. What does the Oppo have to do with 3D on DirecTV????
A second follow-up on this question. The attached is from Oppo:
Dual HDMI Outputs - The BDP-93 is equipped with two HDMI output ports and offers the most versatile installation options. You do not have to upgrade your A/V receiver to a 3D model in order to enjoy 3D. One HDMI output of the BDP-93 can be connected to a 3D TV and the other can be connected to a pre-3D HDMI v1.1-v1.3 A/V receiver. For projector users, you can connect one output to a projector for home theater use and the other to a TV for casual viewing. For a multi-room installation the BDP-93 can output audio and video to two 3D or 2D TVs simultaneously.
gbhodge is offline
post #32166 of 44730 Old 01-25-2011, 02:33 PM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Check the top row of your keyboard on the far right.
It may say PRTSC instead of Print Screen.
thestewman is offline
post #32167 of 44730 Old 01-25-2011, 02:34 PM
Shrike645's Avatar
Quoted: 45 Post(s)
Liked: 38
Print Screen is a button on your keyboard. May be labeled PrtSc or some such. Pressing the Alt Button and the Prtsc button at the same time copies the active window screen to the clipboard buffer that can then be pasted into any application such as windows paint.
Shrike645 is online now
post #32168 of 44730 Old 01-25-2011, 07:39 PM
work permit's Avatar
Quoted: 12 Post(s)
Thank you both for your replies
Originally Posted by dmusoke View Post
The maximum supported resolution is 1920x1080p60. There is a Custom Resolution option but don't think it can exceed the maximum allowable. Call anthem tech support for further help. Just for fun, try the AUTO setting and see if the unit syncs up to the source.
I know the D2 can do 1600x1200. I was hoping that feature wasn't lost with the D2V/AVM50. 1600x1200 actually requires less video bandwidth then 1920x1080p, so I'm hoping it's supported through using a custom resolution.
Originally Posted by thestewman View Post
This sounds like a computer video display why not reduce it in the computer ?
Most 1600x1200 outputs are way to small to be legible on a television screen.
It's a front projector CRT. I currently use this resolution when viewing 4x3 material. My reason to use this resolution is that it reduces visbility of scan lines. It has the added benefit of allowing for a brighter image.
Thanks again
Alex
work permit is offline
post #32169 of 44730 Old 01-25-2011, 09:51 PM
dmusoke's Avatar
Quoted: 255 Post(s)
Liked: 133
Thanks again
The AVM50/D2 and AVM50v/D2v use the same video processor, the Gennum VXP. So whatever resolutions were supported in the AVM50 / D2 will be supported in the D2v/50v as well.
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is online now
post #32170 of 44730 Old 01-26-2011, 03:40 AM
CharlieU's Avatar
Liked: 26
Windows 7 comes with something better than Print Screen. It's called Snipping Tool and it can be found in your All Programs menu under Accessories.
CharlieU is offline
post #32171 of 44730 Old 01-26-2011, 03:47 AM
buddy4711's Avatar
Originally Posted by buddy4711 View Post
an old story...still not yet fully solved! After more than a year and many firmware upgrades on the Xtramer the issue with the missing maximal video resolution is still unsolved.
But it looks to be more a problem from the D2 side than from the Media player's side, because if Media Player and TV are connected directly, then everything works properly. Just when the D2 is in between, then the only 480p, 720p and 1080i are selectable, all other res and especially 1080p are visible but "greyed out" and not selectable.
I understand, as Bob explained in a former thread to this device, that the job of a "repeater processing" of EDID is more complex than when player and TV are directly connected. But interestingly some other cheaper AV receivers do obviously this job.... So I am quite disappointed in this respect.
Maybe interesting for someone else. I have solved the problem of the video resolutions between D2 and Xtreamer by connecting in between a Gefen HDMI Detective device, which gives a preselected EDID to the Media Box (Xtreamer) and thus let me choose 540p, 720p, 1080i50Hz, 1080p50Hz.
buddy4711 is offline
post #32172 of 44730 Old 01-26-2011, 05:53 AM
p.las's Avatar
thanks.
i' will try to upload my graphs.
if i' can handle it
Peter
Denmark
p.las is offline
post #32173 of 44730 Old 01-26-2011, 10:46 AM
p.las's Avatar
i finale made it.
i'am not sure that the room gain is correct, becurse i also use a SVS a1 EQ, so ACR can't see the peaks, and this will cheat the mesured roomgain
but i must say that the bass is very presice, witt a lot of texture.
any comment will be nice.
regards Peter Denmark
edit: i'ts a mistake in the mowie setup......the front is set to 90hz by ACR, and it works great.
Peter
Denmark
p.las is offline
post #32174 of 44730 Old 01-26-2011, 12:14 PM
jayray's Avatar
Liked: 25
i finale made it.
Try setting the sub high pass in the advanced menu in ARC to Flat and recalculate. You might get a flatter response to 20Hz and below. Post the new sub chart if you try this.
John
Jayray
Read the FAQs
jayray is offline
post #32175 of 44730 Old 01-26-2011, 01:46 PM
p.las's Avatar
John
I'will try that latter.
My bigest concern is the very low room gain , proberly becurse of the svs A1 had made the correction ón the subs before Arc had made the messurement
Peter
Denmark
p.las is offline
post #32176 of 44730 Old 01-26-2011, 02:20 PM
Shrike645's Avatar
Quoted: 45 Post(s)
Liked: 38
As Nick said a couple pages back ARC won't boost it if doesn't think it's available. You have a dip in your fronts right about where the crossovers start and I think this may have some affect in the small room gain number also.
Have you tried ARC without the A1 on the premise that less processing might be better?
A well treated room may also show a very low room gain.
post #32177 of 44730 Old 01-26-2011, 02:29 PM
ninja12's Avatar
i finale made it.
Charts look good. I would say check your sub to make sure you disable any crossover in your sub. If you have a frequency knob, turn it all the way up. If you do this, you will have to remeasure.
ninja12 is offline
post #32178 of 44730 Old 01-26-2011, 02:31 PM
Quoted: 100 Post(s)
Liked: 42
i finale made it.
Looks like someone is giving Jayray a run for his money to have the best looking sub graph in this forum. If I am reading it correctly.
post #32179 of 44730 Old 01-26-2011, 02:42 PM
dmusoke's Avatar
Quoted: 255 Post(s)
Liked: 133
My thinking exactly ...
post #32180 of 44730 Old 01-26-2011, 03:04 PM
jayray's Avatar
Liked: 25
Well here is a reminder of what mine looks like
John
Jayray
Read the FAQs
jayray is offline
post #32181 of 44730 Old 01-26-2011, 03:22 PM
Texas steve's Avatar
Yep "John Boy" that about as good as it gets!!
John
Texas Steve
Texas steve is offline
post #32182 of 44730 Old 01-26-2011, 03:22 PM
dmusoke's Avatar
Quoted: 255 Post(s)
Liked: 133
i finale made it.
Peter ...congrats on getting to post your graphs
- Now, I really don't understand why your sub high frequency response is set too low by ARC since its capable of much higher response. Assuming no crossover setting is set (doubt it as it would have shown in the measured curves), you might ttry to boost your room gain to 1.5 - 2.0, recalculate, upload and give it a listen. This should lower your mains freq response to mesh in well with the subs high frequency cutoff.
- Might try raising your high freq response from 5K to 10K. Your front mains can handle up to 15k but your rears can't. Give it a listen as well.
- Set sub highpass filter setting to flat as has been already mentioned.
post #32183 of 44730 Old 01-26-2011, 03:23 PM
dmusoke's Avatar
Quoted: 255 Post(s)
Liked: 133
John
Heck...that is downright insane!!! Do you use the AS-EQ1 as well?
post #32184 of 44730 Old 01-26-2011, 04:05 PM
jayray's Avatar
Liked: 25
I did use PBK and ARC. Below are the two diff curves, ARC alone and with PBK for people to compare. The difference wasn't very noticeable using PBK and ARC but I left it using both. What you do notice is the change in the measured curve after PBK.
John
Jayray
Read the FAQs
jayray is offline
post #32185 of 44730 Old 01-26-2011, 04:46 PM
Quoted: 100 Post(s)
Liked: 42
I am still trying to get the best placement and sound from my subs, I just read up on the Velodyne SMS-1, would anyone recommend this baby or maybe something else that can help?
post #32186 of 44730 Old 01-26-2011, 04:55 PM
TKO1's Avatar
Liked: 65
Hi,
to be honest you don't need it with ARC and Quick Measure. I had one, and it worked fantastic for finding the best location for the sub and for equalizing nasty peaks. But ARC does the same thing and is one less thing to have in the signal processing.
Hope this helps.
Cheers.
Tony
TKO1 is offline
post #32187 of 44730 Old 01-26-2011, 06:58 PM
obie_fl's Avatar
Liked: 33
I'm still not sure how the Oppo with two HDMI outputs is related to the DirecTV 3D receiver. Reading back through the thread are you trying to say you are going to run the DirecTV receiver through the Oppo? If so I think you are mistaken in the Oppo's capability.
obie_fl is offline
post #32188 of 44730 Old 01-27-2011, 12:49 AM
p.las's Avatar
i have run the svs a1 first. my room is not treaded.
here is a old picture of my living room. the closest corner from the subs are about 4 meters. i had tryet to raise the room gain to 1.0xxxx and i feel the sound to be more warm, but still very open.
maby i shout try to run ACR whitout SVS a1, to see what room gain it come up with.
edit:
there is no filter on the subs. the processor do all of the stuff
Peter
Denmark
p.las is offline
post #32189 of 44730 Old 01-27-2011, 07:57 AM
Nick @ Anthem's Avatar
Quoted: 298 Post(s)
Liked: 215
If a sub measures fine anechoically and drastically differently in-room even after correction, a better sub position ought to be the first consideration. This is the closest thing to a miracle cure.
The most important noise floor is in your head. Always remember to protect your hearing.
Nick @ Anthem is offline
post #32190 of 44730 Old 01-27-2011, 08:04 AM
Quoted: 298 Post(s)
Liked: 215
i finale made it.
If you haven't, try ARC without the sub's eq.
All: If something doesn't appear to make sense, sent your .arc file to tech support (not screenshots). We can view each position independently - this removes much guesswork.
Receivers Amplifiers
