Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1433 - AVS Forum | Home Theater Discussions And Reviews
 170Likes
post #42961 of 44913 Old 07-24-2014, 11:44 AM
stanger89's Avatar
Quoted: 3308 Post(s)
Liked: 1769
stanger89 is offline
post #42962 of 44913 Old 07-24-2014, 12:45 PM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Originally Posted by barasn View Post
got it today.. how can i check the current software?
Or, push the select button on the remote to scroll thru the displays or push the status button on the unit.
thestewman is offline
post #42963 of 44913 Old 07-25-2014, 01:13 PM
acebreathe's Avatar
Quoted: 175 Post(s)
Liked: 99
My Anthem Statement D2 will not power on. When I attempt to power it up it just displays Anthem Statement D2 and nothing works. I've tried disconnecting the power cable and letting it sit for a few minutes and then plugging it back in no success. Any suggestions before I disconnect everything and look for an authorized repair shop?
acebreathe is offline
post #42964 of 44913 Old 07-25-2014, 01:49 PM
acebreathe's Avatar
Quoted: 175 Post(s)
Liked: 99
Should add that there was a power failure lat night due to bad thunderstorms with severe lightning. Everything else in my setup powered up fine.
post #42965 of 44913 Old 07-25-2014, 04:30 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3529 Post(s)
Liked: 4534
There is a known, but fortunately rare, problem which can cause the firmware of an original D2 (not the newer D2v) to be corrupted in a power failure. What happens is that some other part of your system (usually the power amp) dumps power back down the cables into the D2 and the D2 does not handle that gracefully.
The symptom is that the D2 appears to do all operations (including power up) in extreme slow motion, or some operations may not appear to work at all.
The CURE is to re-install the firmware. There is no permanent damage done -- just the nuisance factor of having to do the re-install and getting your settings back in place if up to date values are not saved in User or Installer Settings memory.
If the D2 refuses to accept a firmware install, then you need to get the Flash Eraser utility from Anthem Tech Support and run that first. This is a PC program which resets the programmable parts of the D2 so that they WILL accept new firmware.
Once the D2 has accepted the firmware install, restore your Settings and for good measure also re-Upload your latest ARC solution.
--Bob
tngiloy likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #42966 of 44913 Old 07-25-2014, 05:23 PM
Thxtheater's Avatar
Quoted: 152 Post(s)
Liked: 114
Peanut gallery comment here... Bob that just proves how institutional memory is worth it's weight in gold. What a great nugget to file away.
Thxtheater is offline
post #42967 of 44913 Old 07-25-2014, 10:03 PM
acebreathe's Avatar
Quoted: 175 Post(s)
Liked: 99
--Bob
Thanks Bob appreciate the help.
post #42968 of 44913 Old 07-27-2014, 12:14 PM
Nicoff's Avatar
Quoted: 54 Post(s)
Any replacement for the D2/D2V processors in the works?
About six months ago I asked this same question and at that time the only answers that I got were along the lines that the D2/D2v were still considered state-of-the-art even years after their release.
I am just wondering where things stand today. Is there a replacement planned or in the works? Thanks!!
Nicoff is offline
post #42969 of 44913 Old 07-27-2014, 01:25 PM
Tim Winders's Avatar
I'm sad to report I must sell my D2. My amplifier recently gave up the ghost and I'm not in a position to replace it, so can't use the D2. I am the original owner, it's an original D2 and I added the ARC1 as soon as it was available.
I've checked Audiogon and it seems $2200-$2500 is a fair price. Does that seem right?
Is anyone here interested before I post it elsewhere?
Tim Winders is offline
post #42970 of 44913 Old 07-27-2014, 01:33 PM
Read the FAQ!
Liked: 4534
No official hints yet. Let me check my unofficial sources:
* shake shake shake *
ASK.AGAIN.LATER THE.FUTURE.IS.HAZY
--Bob
post #42971 of 44913 Old 07-28-2014, 07:31 AM
Nicoff's Avatar
Quoted: 54 Post(s)
--Bob
Thank you Bob! As hazy as the future looks, just a little bit of haziness gives me hope that I am not driving on a dead-end road.
My hope is that by next CES, Anthem will have news for us.
Nicoff is offline
post #42972 of 44913 Old 07-29-2014, 08:10 AM
AVfile's Avatar
Quoted: 282 Post(s)
Liked: 138
How about a firmware fix for the 3D models uninitialized video processor when using pass through mode?
AVfile is offline
post #42973 of 44913 Old 07-29-2014, 08:12 AM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Explain further what you mean by "uninitialized processor " somehow i missed learning about that problem.
Stew
post #42974 of 44913 Old 07-29-2014, 10:24 AM
AVfile's Avatar
Quoted: 282 Post(s)
Liked: 138
Stew
I thought that would get some attention When I explain it fully nobody seems to care.
Say you power-on to your usual BD input with video output mode set to THROUGH (because you want to use 3D or an external VP). It works fine until you try to bring up the Anthem SETUP menu. The processor doesn't know what video output to use for the internal menu system since it was never initialized properly. It tries to handshake with the display and fails, resulting in either blank or corrupted display (until you select another video output configuration).
There is another side effect of using THROUGH that I get: No audio unless the display is on! So if you just want to listen to an SACD or DVDA the TV must be turned on temporarily, or setup another input with video output NOT THROUGH for the handshake to complete.
Anthem clearly did not cover all the bases in testing the 3D pass-through mod. Nick acknowledged that a fix might be possible in the mainboard software and to check with tech support, but that was a long time ago and they are not confirming any fix when I contact them.
AVfile is offline
post #42975 of 44913 Old 07-29-2014, 12:02 PM
Thxtheater's Avatar
Quoted: 152 Post(s)
Liked: 114
This has been a bit of an annoyance and my work around has been to set a virtual input when I do audio only.
post #42976 of 44913 Old 07-29-2014, 07:25 PM
AVfile's Avatar
Quoted: 282 Post(s)
Liked: 138
Good to know I'm not the only one.
AVfile is offline
post #42977 of 44913 Old 07-30-2014, 12:18 PM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Anthem clearly stated that using Through would cause the user to NOT be able see the on screen menus or displays as they use S-video for the on screen display.
I listen to audio everyday and never have to turn on a video display.
Possibly one of your source settings is incorrect or needs changing.
What is the source of your audio ? HDMI ?
List all the audio source setup settings for us.
Anthem clearly at times has avoided addressing some issues for some reason.
They have done it to me several times. They said they would have an answer and never responded after multiple telephone calls.
So I gave up asking.
Stew
post #42978 of 44913 Old 07-30-2014, 12:33 PM
marky301067's Avatar
Quoted: 60 Post(s)
Liked: 55
Stew
That doesn't sound like very good customer service to me
Dali: Epicon / Paradigm: Sub 1 / Plinius: Tautoro / SB301 / Toko / Anthem: MRX1120 / Oppo: 103D / JVC Dila: 950 / Apple: IpadProd 12.9 V2
marky301067 is offline
post #42979 of 44913 Old 07-30-2014, 01:14 PM
nucky's Avatar
Quoted: 115 Post(s)
Liked: 69
I've had the Anthem D2v 3D for a few months now and never had any problems with it. And it is the best pre amp that I have heard in my house so far.
AV Lexicon GX 7, Anthem MRX-720, Oppo 203, PS4 pro, TV LG C6 OLED, HD projector 106 Jvc X5000 X550, Sub Paradigm signature sub1, Speakers monitor audio platinum PL100 PLC150, Dali phantom ikon in wall & 4 phantom kompas 6m in ceiling speakers, 5.1.4 Atmos
nucky is offline
post #42980 of 44913 Old 07-30-2014, 01:40 PM
barasn's Avatar
Quoted: 33 Post(s)
i bought anthem 50 v 3d second hand but the owner lost cd so i cant upgrade software and cant use arc what i need to do ? need rs 232 driver and arc software how can i get it
barasn is offline
post #42981 of 44913 Old 07-30-2014, 01:54 PM
nucky's Avatar
Quoted: 115 Post(s)
Liked: 69
Go here and download it to your laptop or pc
http://www.anthemav.com/support/latest-software.php
nucky is offline
post #42982 of 44913 Old 07-30-2014, 02:57 PM
Read the FAQ!
Liked: 4534
You don't need any special driver for the serial (RS232) connection. If you use a USB to serial adapter, such as the commonly used Keyspan USA-19HS that Anthem ships with the unit, you can get its driver from the Tripplite.com web site (Tripplite owns Keyspan). Download and install the driver for your particular flavor of Windows. If you need the actual USB to serial adapter itself you can purchase it from Amazon or even from Anthem. You will also need a "straight through" serial cable -- pins 1-9 connect directly to pins 1-9 -- available from places like Radio Shack, or from Anthem.
As mentioned above, the ARC install kit can be downloaded from the Anthem web site. As can the latest firmware installer.
So the one thing that's really missing from all this is that you don't have the ARC license and the ARC mic calibration file that came on that original install CD.
For those, email Anthem tech support with the Serial Number of your AVM 50v/3D and with the Serial Number of your ARC microphone, and they can email those two files to you. The two files they send you will have names made up of numbers -- those two Serial Numbers.
When you download the ARC install kit, UnZip it (if your Windows computer hasn't done that automatically) so that you have a folder. Look in that folder until you find the Setup.Exe program which is the installer itself for the ARC Windows application program. Copy the two files you got from Anthem Tech Support into the same place where you found that Setup.Exe program, then double click on that program to run the Installer. It will install the ARC Windows application on your Windows PC, and also copy those two files to where they need to be when you run the ARC setup.
--Bob
post #42983 of 44913 Old 07-30-2014, 04:33 PM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Hopefully he had the serial numbered ARC microphone ?
post #42984 of 44913 Old 07-30-2014, 11:14 PM
tranle's Avatar
Quoted: 68 Post(s)
Question for old timers: when did Anthem start including the Keyspan USB-serial adapter with their D2V ?
Did they do that when started including ARC with it ?
tranle is offline
post #42985 of 44913 Old 07-31-2014, 08:08 AM
Read the FAQ!
Liked: 4534
No, it came quite a bit after bundled ARC first shipped. After they negotiated a distribution deal with Tripplite.
--Bob
post #42986 of 44913 Old 08-01-2014, 02:59 PM
barasn's Avatar
Quoted: 33 Post(s)
thank for help bob i got mic driver but now i have 0x03 code problem how can i solve it ?
barasn is offline
post #42987 of 44913 Old 08-01-2014, 04:31 PM
Read the FAQ!
Liked: 4534
^ Reboot the Windows PC after any driver install or uninstall. Make sure the USB plugs are fully inserted. If using the Keyspan driver, check its USB plugs as well.
Check whether you have the latest (v3.10) firmware installed.
When you run an ARC Measurement pass, it will ask you to specify which speakers you want it to Measure. Be sure you don't tell it to Measure speakers you don't actually have connected or it will fail when it gets to that speaker.
--Bob
post #42988 of 44913 Old 08-01-2014, 07:06 PM
tranle's Avatar
Quoted: 68 Post(s)
Not Bob, but I had a similar problem a few month ago with a Lenovo laptop and it seems that the Anthem mic driver does not like to be in a USB3 mode.
Check if you have an option in your bios be in a USB2 mode (compatibility or forced).
Without it my notebook would see the mic in the device manager app but ARC could not see it.
tranle is offline
post #42989 of 44913 Old 08-02-2014, 12:46 AM
barasn's Avatar
Quoted: 33 Post(s)
its ok now ty guys
barasn is offline
post #42990 of 44913 Old 08-02-2014, 10:12 AM
AVfile's Avatar
Quoted: 282 Post(s)
Liked: 138
Not the OSD. The internal SETUP menu can still be brought up, but it has to switch from pass-through and engage the video processor temporarily. The problem is it doesn't remember video output settings across power cycles, so it doesn't know what resolution/format to output unless explicitly set via source setup. If you power-up to THROUGH mode this is undefined! It might default to 720p and some undetermined data format resulting in bad colors (in my case). The workaround is to select another source with video output explicitly configured before bringing up the menu.
I am just using HDMI from BD players. I tried it again and this time it worked (after a few brief dropouts) without turning on the display. It may be more complicated for me because I output to an external video processor (which was off this time) before the display. However it is more reliable when video output mode is not THROUGH. The workaround is to setup a virtual source for music only, with video output configured, as Thxtheater said.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
Receivers Amplifiers
