Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1451 - AVS Forum
 29Likes
post #43501 of 43527 Old 12-24-2014, 03:18 PM
JDCaduceus's Avatar
Quoted: 12 Post(s)
This is the rear of my sub. Any thoughts?
thanks
Conrad
JDCaduceus is offline
post #43502 of 43527 Old 12-24-2014, 03:36 PM
thestewman's Avatar
Quoted: 79 Post(s)
Liked: 39
Originally Posted by JDCaduceus View Post
fixed the microphone issue - ran ARC without sub since I can not get the Subs to get a signal (even when entering listening calibration in the setup menu. I have the setup for 1 sub right now - though I have two subs (B&W) both should be getting signals from the processor via RCA on Sub 1 and Sub 2 Output. However, I get nothing. Don't know why. Will post a pic of the sub rear to see if you guys might know what is going on.
Any help is much appreciated.
thanks
Conrad
You should have the output of Anthem Sub1 to line in on the first sub and output of Anthem Sub 2 connected to line in of the second sub
Ensure you have your 12v triggers set up correctly.
The B&W Sub should have a Green Led On if operating correctly.
thestewman is offline
post #43503 of 43527 Old 12-24-2014, 03:56 PM
JDCaduceus's Avatar
Quoted: 12 Post(s)
thestewman that is correct. However, I do not have any 12v triggers in this setup. Never needed them before. Do I need 12v triggers to run my subs from the anthem d2v3d?
post #43504 of 43527 Old 12-24-2014, 04:07 PM
thestewman's Avatar
Quoted: 79 Post(s)
Liked: 39
Not entirely familiar with the B&W setup.
You do have to make some sort of decision how to turn it on.
Your options are ON, Auto, Standby
If you set it on it will remain on 24/7 until you turn it off
Auto means you need a 12v trigger from the Anthem
Standby it is not On only energized
If it is on you will get a Green Led
post #43505 of 43527 Old 12-24-2014, 04:14 PM
JDCaduceus's Avatar
Quoted: 12 Post(s)
I left it at on and it has a green light so we should be good
post #43506 of 43527 Old 12-24-2014, 06:39 PM
JDCaduceus's Avatar
Quoted: 12 Post(s)
But again. Even thought the sub is on (green light) and connections are correct. What am I doing wrong? Is there something I need to do in the setup menu that I am not doing correctly? I currently have the setup for 1 sub in my speaker config. Should I have two subs now that I ran ARC and my speakers are calibrated? Thanks again Conrad.
post #43507 of 43527 Old 12-24-2014, 07:33 PM
thestewman's Avatar
Quoted: 79 Post(s)
Liked: 39
One sub is the correct setting.
First I would take the line going to Sub 1 and plug it into the Anthem output for one of your front speakers then test to ensure the sub is working.
And then the opposite to ensure sound is going to the sub
Open ARC and check the target and make sure you do not have none selected for the sub in the target window
Open Speaker configuration and check your speaker config for Bass Management Music and Movie
to ensure you have 1 sub selected
post #43508 of 43527 Old 12-24-2014, 10:49 PM
tngiloy's Avatar
Quoted: 13 Post(s)
So just to be clear--- are you not getting sound to your subs when you choose 'sub' in the 'level calibration' section of the setup, or during the sub sweeps during the ARC run?
When you run ARC you need to choose your speaker configuration in ARC. As you open ARC in either the 'manual' or 'automatic' choice the first page that will appear (after it recognizes your processor and you choose your mic) will be a speaker setup page for movie and music. You should choose your speaker setup there. Be sure that you have checked 'subwoofer' in ARC. Once ARC is run it will override anything you have setup previously in the 'speaker configuration' area of the setup menu and will set subs to 1 sub even if you had previously chosen 2 subs in the 'speaker configuration' of setup.
If you post your ARC graphs and targets we may be able to help you more.
Looking at the picture of the back of your sub it appears to be turned on and connected correctly. You do not need to worry about the 12v triggers even if your sub is set to 'auto'. In the 'auto' mode your sub remains in standby until it senses a signal, then will turn on. But since you have yours 'on' , they will be on all the time.
"You can have my remote when you pry it from my cold dead fingers" tngiloy
Anthem D2v;Anthem A5;Golden Ear Aon3,SuperCenter XL,SuperSat3;SVS SB13 Plus x 2;Oppo BDP-103D;Ayre CX-7eMP;Panasonic plasma; Dish Hopper;PS Audio Power Plant 5- Subject to change without prior notification.
tngiloy is offline
post #43509 of 43527 Old 12-25-2014, 12:06 AM
JDCaduceus's Avatar
Quoted: 12 Post(s)
That is correct during the level calibration I'm getting no sound to my sub. Even when it's selected. In addition, doing the ARC set up I originally had the sub selected however when the test began and it got to the part where it was measuring the sub woofer it gave me an error code advising me that it was unable to proceed. So you are correct I'm not getting sound either on level calibration for arc when I have probably selected the sub.
At this point, I really believe that I might have a bad processor. I have only had my processor for approximately five months.
To make matters worse, I check my processor tonight and now I'm having a handshake issue with my HDMI out.
It seems now my HDMI out of the processor will not project any kind of picture or sound at all. Even when I switch The source to resolve any kind of handshake issues, which normally correction itself by showing a picture, this time my screen simply flickers telling me I have an HDMI out issue
So I am really at a loss. It looks like it's a bad processor but I can't be sure I think I'm pretty competent but I learn something new every day. I really don't know what's going on in my situation either with the sub or now my picture.
Do you guys have any advice on where I should take this? Or any advice on how to fix these issues?
post #43510 of 43527 Old 12-25-2014, 08:20 AM
thestewman's Avatar
Quoted: 79 Post(s)
Liked: 39
Hard to believe after 5 months it is going bad they are very reliable.
Usually it is something that the user forgot, a connection problem or a temporary firmware glitch. Hopefully we can correct it.
It is a good policy to start from the basics and check each item, not skipping any steps.
If you still have the HDMI problem.
Do a hard reset of the Anthem and your display disconnecting power from each for 2 or 3 minutes.
Restart both. Still no picture or sound ?
Check you have a HDMI source selected in the Anthem and the correct input source selected in your display.
Unplug the output HDMI cable at both ends and reinsert making sure it goes straight into the socket
Attempt to bring up the setup menu on your display using the remote control
Nothing ?
With the HDMI source you want selected scroll through the front Led displays using the status button and write each down and let us know what each says
post #43511 of 43527 Old 12-25-2014, 09:42 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 633 Post(s)
Liked: 1038
Odds are you have a cabling problem.
Check that you are REALLY connected to the Sub output of the Anthem and that you are connected to Line Level input at the Sub. Your Sub may have high level input and line level output jacks, neither of which will work.
If no easy answer there, temporarily change LF/RF to Full Range in the Anthem, then move the plug from the Sub output to the LF output and unplug the RF output. Play a CD with good bass and confirm you are getting sound from the Sub. If not there is a problem in the cable or the Sub.
It wouldn't surprise me if your HDMI problem is just that you jiggled an HDMI plug while futzing with the Sub or the RS-232 serial connection. Reseat your HDMI plugs.
--Bob
Bob Pariseau is online now
post #43512 of 43527 Old 12-25-2014, 05:23 PM
thestewman's Avatar
Quoted: 79 Post(s)
Liked: 39
thanks
Conrad
Conrad
Unless my eyesight is going bad it looks like your input cable is severely frayed
And you still have the lowpass crosover for the sub engaged which it should not be for ARC
post #43513 of 43527 Old 12-25-2014, 06:05 PM
tngiloy's Avatar
Quoted: 13 Post(s)
Originally Posted by thestewman View Post
Conrad
Good eye Stew.
Also please check your connections in the back of the D2v. Make sure the cables are plugged all the way in. Some cables have tighter connections and you may think you are all the way in when you are not.
From what you posted it sounds like you are using the correct connections, but please refer to the attachment to make sure you are using the correct outputs. You should be using the 'main audio out' rca analog sub1 and sub2 outs.
It is usually something simple. But the hard reset (unplugging your d2v for a few minutes) may help. If all else fails you may want to re-upload your firmware.
BTW what firmware are you running?? Is your D2v a 3d model ??
We want to get you up and running ASAP. There may still be time to watch Polar Express with your family.
Tom
tngiloy is offline
post #43514 of 43527 Old 12-25-2014, 07:42 PM
JDCaduceus's Avatar
Quoted: 12 Post(s)
Thanks Bob - everything seems to be ok now with HDMI - don't know what happened but on power up of Processor - getting picture from my two sources (HTPC and TV). However, my sub will sill not produce any sound. One issue i thought could be the problem: all my of speakers are using XLR cables from the processor to the AMP, except the subs. I was using RCA from processor to Sub line in. Could it be that using XLR's to speakers shuts down RCA Main outs for the processor? Just a thought.
Thanks Tom, and Stew -
Stew I disabled the lowpass Xover on the sub (turned it to "out") and still no sound. I appreciate all the help. I am going to try Bob's suggestion on the full range next. I also have the frequency on the sub turned to the max and the volume midrange. My thought was the processor (D2v3d) should be handling the xover for the sub.
Update: FYI Bob I flashed the Processor with the latest firmware for D2v3D - 3.10 - still no sound from sub. I tried two different RCA cables. My only conclusion is that since I am using XLR cables for my 5 channel system that the sub must also be on a XLR cable. I never heard of that but that is the only thing I can think of. Problem is I would need to get a XLR (female) to RCA for the sub to try it out. Thoughts?
Isn't this right setup?
post #43515 of 43527 Old Yesterday, 05:58 AM
thestewman's Avatar
Quoted: 79 Post(s)
Liked: 39
Conrad
Save yourself a lot of trouble and time and do these easy tests
The RCA and XLR outputs are all turned on and can be intermixed.
Open Speaker configuration in the Setup menu for Bass Management Music and Movie.
Check your speaker config you have 1 sub selected
Open ARC and check the target window and make sure you do not have none selected for the sub in the target window
Now, take the cable going to Sub 1 and plug it into the Anthem RCA output for the Right Front speaker. The sub has a built in amp so you do not need the speaker amp
Play anything even the test tones to test sound is going to the sub on that cable
Now we can test the sub output is working.
We will do the opposite to ensure sound is going to the sub.
Take the XLR cable going to the Right Front speaker and plug it into the Sub 1 Output XLR
connector on the D2v.
Use the test tones and see if you get sound to the right front speaker.
post #43516 of 43527 Old Yesterday, 06:27 AM
AVfile's Avatar
Quoted: 63 Post(s)
Liked: 63
No problem using both XLR and RCA outputs, many people do that.
Have you tested these subs with another preamp or source device? (Caution if you connect a CD player turn the volume down on the subs first! Setting 1/4 or less should produce plenty of sound.)
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is offline
post #43517 of 43527 Old Yesterday, 08:02 AM
JDCaduceus's Avatar
Quoted: 12 Post(s)
Thanks stew - that sounds like a good test. Will give it a try today and report back the results.
post #43518 of 43527 Old Yesterday, 09:16 AM
ManWithAPlan's Avatar
Audio Problem
Folks,
I have had a several month long audio output problem that
I'm finally taking the time to try and isolate and troubleshoot, after
years of having no problems with my D2V-3D. It goes like this - anytime
I input Dolby Digital bitstream to the D2V, no matter which source it
is from (Satellite, Oppo, AppleTV3, etc.), the audio output is severely
lacking, ie, almost silent...if I really crank the volume, I can hear
the soundtrack and dialogue, but I mean it has to be at -20 or -15 or so to do
so. If I switch the source to outputing something else, like straight
PCM, then there is no problem at all, the audio is at the normal proper
level, and I can hear the movie perfectly. This is after years of
perfect performance, and no changes have been made to my setup, nor do I
typically change Mode Presets for the individual sources at all...in
fact, for Dolby Digital 5, I have 'None' selected as the audio
processing for all input sources. But just for fun, to try and isolate the problem, I tried
moving the Mode Preset to other things, like THX Cinema, or ProLogic II
and I still have the problem. It is unusable in this state, can't hear
anything properly, so I end up going into things like the AppleTV3 and
changing to PCM output instead of Dolby Digital, and then all is well
immediately.
The problem sometimes goes away, this is the
weirdest part. I can't tell when it's going to recur or not. Do I have
possibly a failed Dolby decoding chip or something in my D2V? Thoughts
are welcome, as I am really tired of this issue, as you can imagine.
Thanks for your thoughts.
-Brian
ManWithAPlan is online now
post #43519 of 43527 Old Yesterday, 09:40 AM
JDCaduceus's Avatar
Quoted: 12 Post(s)
stew - Results are in
RCA test from Line in (Sub) to RCA LFront on Processor = no sound
XLR test - Moved XLR from Left Front to Sub 1 on Processor = sound
Looks like bad RCA cables or something wrong with sub - will replace RCA cables and see what happens there.
post #43520 of 43527 Old Yesterday, 09:57 AM
Read the FAQ!
Quoted: 633 Post(s)
Liked: 1038
It may be as simple as a switch setting on the Sub for whether the XLR or RCA jacks are active for input.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
post #43521 of 43527 Old Yesterday, 10:00 AM
JDCaduceus's Avatar
Quoted: 12 Post(s)
Thanks Bob - but the B&W subs have no XLR input - only RCA. See attached pic of rear of my subs (both subs are the same model) - thoughts?
fyi the low pass filter is set to out now and the low pass freq is set to max - despite pic
post #43522 of 43527 Old Yesterday, 10:04 AM
Read the FAQ!
Quoted: 633 Post(s)
Liked: 1038
Originally Posted by ManWithAPlan View Post
Folks,
immediately.
-Brian
Try this:
In Setup: Save User Settings, Load Factory Defaults, Load Saved User Settings.
This resets all of the "temporary" trim settings -- which are remembered per type of audio input format but aren't included when you Save settings.
If that doesn't do it, and with your settings still Saved in the User memory, Reload Factory Defaults again. Now manually make the minimum number of Settings changes necessary to to Source Setup and Speakers to test whether this problem still exists. If it goes away with defaults, you may need to re-enter the rest of your settings manually, as your saved settings may have been corrupted.
If the problem still exists with the factory defaults, then Reload Factory Defaults again and re-install the v3.10 firmware. Test again (minimum manual changes). If even that doesn't fix it, then your Anthem may need service.
--Bob
post #43523 of 43527 Old Yesterday, 11:47 AM
thestewman's Avatar
Quoted: 79 Post(s)
Liked: 39
Conrad
Conrad
You never commented on this
Stew
post #43524 of 43527 Old Yesterday, 02:24 PM
Nicoff's Avatar
Quoted: 36 Post(s)
Just had a puzzling experience with my D2. After moving my speakers around I did a quick measure check to find location. I did not run ARC afterwards (as recommended). Instead I went on to try and listen in two channel only to find that the left speaker volume as much lower than the right speaker. I was afraid of a problem with the amp and changed cables etc. nothing worked. Then decided to check the speaker volume in the Anthem set up and voila! The right speaker was higher by about 7 DB. I know that I did not make that change, so somehow the higher setting got there. Problem fixed now, but even with the 2-ch input with no ARC, volume setting has an effect.
Nicoff is offline
post #43525 of 43527 Old Yesterday, 05:08 PM
JDCaduceus's Avatar
Quoted: 12 Post(s)
I am sorry I thought I did - I switched the low pass filter to "out" and adjusted the low pass frequency to the max setting- so technically the Processor should process all frequencies to the sub for the Xover (It is set at 80) but still no sound - Did your test and No sound from RCA to Front L RCA input - However I did get sound in my front left speaker when I switched my XLR Front L to the XLR sub 1 - so I figure it is a bad RCA, or something with my sub (a switch or something) I don't know. Still don't know why this is difficult. It should not be
Conrad
Conrad
Stew
post #43526 of 43527 Old Today, 07:25 PM
thestewman's Avatar
Quoted: 79 Post(s)
Liked: 39
After switching cables it sounds like the sub is bad
since you get sound when connecting the Anthem sub out to your left front speaker and no sound from the sub when connecting the Left front out to the sub
What model B&W sub is it ?
post #43527 of 43527 Old Today, 09:08 PM
RobDec's Avatar
Quoted: 50 Post(s)
Hi
I have encountered 2 problems on my AVM50v 3d:
1) I made the mistake of turning on and off my AVM50v 4 times in a ten minute period. What happened was the resolution on the front panel changed from 720p to 720i. This struck me odd because there is no 720i. I exited that input and went back and it went back to 720p.
2) I was watching a Bluray dolbyHD 7.1. I paused and rewound when I hit play the front panel changed from Dolby HD 7.1 to Dolby HD 2.0. I exited Bluray and went back and it returned to 7.1.
Can someone pleases help. Thank you
Rob
RobDec is offline
Receivers Amplifiers
