Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1460 - AVS | Home Theater Discussions And Reviews
 57Likes
post #43771 of 43782 Old 02-27-2015, 11:59 AM
AVfile's Avatar
Quoted: 83 Post(s)
Liked: 71
^ have you tried eliminating the sub temporarily and set the main speakers to full range to see if you like the bass better on music?
You could also try without the Center speaker if you are using that for music.
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is offline
post #43772 of 43782 Old 02-27-2015, 12:15 PM
dmusoke's Avatar
Quoted: 112 Post(s)
Liked: 100
^ Good test indeed!
Great theatre BTW
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #43773 of 43782 Old 02-27-2015, 02:36 PM
thestewman's Avatar
Quoted: 99 Post(s)
Liked: 44
Originally Posted by AVfile View Post
^ have you tried eliminating the sub altogether for music listening to make sure it is not the speakers that you simply don't like?
Originally Posted by dmusoke View Post
^ Good test indeed!
Great theatre BTW
Should probably make little difference since music contains very little if any LFE.
thestewman is online now
post #43774 of 43782 Old 02-27-2015, 02:43 PM
dmusoke's Avatar
Quoted: 112 Post(s)
Liked: 100
True but his speakers can play down to 30Hz which many bass notes from Jazz, drums and Organ notes reside. The mains will not have the same heft as the subwoofer in the bass notes however...
dmusoke is offline
post #43775 of 43782 Old 02-28-2015, 08:21 AM
tngiloy's Avatar
Quoted: 22 Post(s)
Liked: 24
gerard1meehan,
How do you listen to your music?? I'm not concerned about how many glasses of wine you have while listening, just how many speakers are you using when listening to music?
I have a 6.1 setupand use all speakers and subs for movies and sports. I prefer my music in stereo. Since my fronts are bookshelf's I include my subs and use 2.1 for music. I do separate movie and music runs during my ARC readings. ARC consistently sets my room gain and sub level for music 1-2 dB less and it sounds excellent. Plenty of punch for lfe in movies and smooth, tight bass for music.
With your fronts (look like S8's?) setting them to full range and doing a music run with just those 2 speakers (no sub) would be my suggestion. It takes a little longer to do the ARC run when you do both movie and music sweeps. In your case it would take 1/3 to 1/4 the time to do music compared to movie. I can't tell if you run 5.1 or 7.1 for movie. Well worth the little time it takes. 'N'-ing out speakers in a 'same as' run does not work as well as doing separate movie and music runs. In my experience it leaves the room gain the same and makes music bass boomy.
If you do listen to your music in stereo (or even in Anthem Logic Music) do a separate ARC music run for just the speakers you're using. It will take a little extra time, but it looks like you are willing to spend the time (and bucks) to get it right. I second dmusoke's Great theatre BTW.
Tom
AVfile likes this.
"You can have my remote when you pry it from my cold dead fingers" tngiloy
Anthem D2v;Anthem A5;Golden Ear Aon3,SuperCenter XL,SuperSat3/50;SVS SB13 Plus x 2;DSPeaker Anti-mode 2.0;Oppo BDP-103D;Ayre C-5exMP;Panasonic plasma; Dish Hopper;PS Audio Power Plant 5- Subject to change without prior notification.
tngiloy is offline
post #43776 of 43782 Old Yesterday, 08:07 AM
gerard1meehan's Avatar
Quoted: 17 Post(s)
Unfortunately I did not have the opportunity to work on my left speaker placement or any of the other items I was going to try this weekend to resolve my “Boomy or Base heavy issues” . Other responsibilities cropped up.
But late Friday while watching a movie it dawned on me that I had changed the distance setting of my sub after I ran and uploaded ARC. I had changed the position of my sub and my front right speaker and neglected to change the distances in the processor prior to running. When I reviewed the settings after uploading arc I changed the distance from 13.5 to 11.5.
So I just put it back to the 13.5 and the base issue was gone. I do have to re-measure the distances and I will re-measure ARC.. But with any luck this is it. As of right now it sounds the best it ever has
Will advise
As for How do I listen to music. Best way to state it would be as the media I’m listing to was intended to be heard. I do not eliminate any of my speakers for my Music Arc calculations. If the track I am listing to was mastered in Stereo I listen to it in Stereo. If it’s 5.1 or 3.1, or even 4.1 I do the same
On analog inputs as in my Turntable our Reel to reel I swap between Analogue direct and DSP
gerard1meehan is online now
post #43777 of 43782 Old Yesterday, 09:20 AM
stanger89's Avatar
Quoted: 380 Post(s)
Liked: 221
Technically since the "room" changed (you moved speakers, so it will sound different) then you should have to re-measure with ARC. If you had just goofed up the distance then you wouldn't have to remeasure.
That said, boomy base that depends on distance settings sounds like a phase matching issue, you might want to try making sure you've got your sub/mains in phase and then re-run ARC. I think there are instructions in this thread on how to set phase.
See what an anamorphoscopic lens can do, see movies the way they were meant to be seen
stanger89 is online now
post #43778 of 43782 Old Yesterday, 09:25 AM
tngiloy's Avatar
Quoted: 22 Post(s)
Liked: 24
Will advise
Is the position of the speakers now the same as they were when you ran ARC?? It was not clear to me.
If they are, you do NOT need to re-run ARC. Speaker distance can be put in before or after the ARC run. They just need to be put in correctly. A tape measure and a friend are all that are needed.
As far as sub distance you may want to read the link in dmusoke's signature on how to best set sub distance.
If you use his technique you will need an SPL meter.
If the speaker placement has changed and you do need to re-run ARC then you may want to consider doing a separate movie/music runs IF you listen to the majority of your music in stereo. I have a few SACD's and DVD-A's that are encoded in 5.1 that I play on my oppo 103D in surround using my ARC movie configuration. DSOTM for instance. But I listen to 99.5% of my music in stereo, so I set up a separate music configuration for 2.1 in ARC. I think it works better than playing stereo thru a 5.1/7.1 ARC configuration, since it is specific to the speakers being used. Not drastically better, but noticeably better. My 2 cents.
Tom
tngiloy is offline
post #43779 of 43782 Old Yesterday, 09:56 AM
Quoted: 17 Post(s)
The speakers were moved prior to ARC measurements. I changed the distance in the processors menu after I ran and uploaded ARC.
But I want to tweak my Left front so I'll measure the distances again and re-run the full ARC process.
Appreciate everyone taking time to help out
thanks
post #43780 of 43782 Old Today, 10:32 AM
mothaselin's Avatar
I have a problem. This has just happened. My D2v is stuck in pcm and 2 channel. On all devices that I try to play. Any suggestions or is the processor fried?
mothaselin is online now
post #43781 of 43782 Old Today, 11:18 AM
Quoted: 17 Post(s)
have you tried loading factory defaults?
post #43782 of 43782 Unread Today, 01:36 PM
mothaselin's Avatar
I guess I am going to try that when I get back from work.
Receivers Amplifiers
