Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1469 - AVS Forum | Home Theater Discussions And Reviews
 79Likes
post #44041 of 44049 Unread 07-03-2015, 04:10 PM
Emosewa09's Avatar
That should work unless there is an issue between ARC and XP. XP is very old Windows OS and no longer supported by anyone. The main point is to use bootcamp and not an emulation program.
Emosewa09 is offline
post #44042 of 44049 Unread 07-03-2015, 05:17 PM
AVfile's Avatar
Quoted: 116 Post(s)
Liked: 76
Originally Posted by benleeys View Post
Tom, I wonder what we both have in common. Like you, both my D2 and D2v/D2v3D exhibit the same symptoms. Both of them were purchased new, and from day 1, the problem was there.
Ben
You mentioned you are using the video processor (i.e. not set to Pass Through like me) in the Anthem. What is your Video Output Config?
I wonder if there is something unique about the HDMI format you guys are using. Have you tried different configs (resolution, interlaced, frame rate, RGB/YCbCr, or bit depth) to see if one works better with the Setup menu?
The SETUP menu is supposed to adopt the video output Config of the current source but I have seen it act up (only when using Passthrough though, in which case it is undefined!)
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is offline
post #44043 of 44049 Unread 07-03-2015, 05:57 PM
AVfile's Avatar
Quoted: 116 Post(s)
Liked: 76
Nothing wrong with XP and lack of so-called support just means less annoying Windows updates
Section 3.15 (p.47) of the Anthem user manual states XP or later (remember ARC is also "old") and a PC with a 9-pin serial port (also old) is ideal.
- AVStefan
AVfile is offline
post #44044 of 44049 Unread 07-04-2015, 04:06 PM
jo5507's Avatar
As I noted, I use it. It works fine with XP. I need to use a portable occasionally for a few programs including ARC, and I use my old Macbook/XP for that purpose. If one happens to have access to XP or prefers it over the newer OS's, it works perfectly well and I have no problems with updates to those programs so far. XP of course, no longer gets updates.
jo5507 is offline
post #44045 of 44049 Unread Yesterday, 07:54 AM
benleeys's Avatar
My Video Configs are set with 1080p/60 (DVD), 1080p/24 (BR), YCbCr 444, 12 bit. Since the problem doesn't occur within and hour or so of switching on, I don't believe the problem is caused by any of these settings.
benleeys is online now
post #44046 of 44049 Unread Yesterday, 08:20 AM
thestewman's Avatar
Quoted: 177 Post(s)
Liked: 72
Ben
My own interpretation of what is occurring. Consider that the same situation happened with two different units.
One which I believe was the later design D2v.
This has to be a positional problem.
In other words where you have the unit located must be causing a localized heating of the board or components.
Can you move or reposition the unit at least enough so that you create a different flow of air ? Or another idea if it is shelf mounted raise it up on some small blocks off the shelf ?
Stew
thestewman is offline
post #44047 of 44049 Unread Yesterday, 09:37 PM
AVfile's Avatar
Quoted: 116 Post(s)
Liked: 76
You're right it shouldn't matter but we could be dealing with a very strange bug that only manifests due to several compounding factors. I think most people use 8-bit data. There is no reason to complicate things by using 12-bit. Also try 4:2:2.
- AVStefan
AVfile is offline
post #44048 of 44049 Unread Today, 07:40 AM
benleeys's Avatar
Originally Posted by thestewman View Post
Ben
Stew
Stew,
I did think of this possibility before so I shifted it to the current position. But it made no difference. Let's wait for the result of Tom's experiment.
Ben
post #44049 of 44049 Unread Today, 07:44 AM
benleeys's Avatar
Tried them all, but it made no difference. After so many years, I've given up fiddling and have learnt to live with this anomaly and enjoy what I have.
Ben
Receivers Amplifiers
