Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1492 - AVS Forum | Home Theater Discussions And Reviews
 147Likes
post #44731 of 44753 Old 01-30-2017, 05:20 PM
Nicoff's Avatar
Quoted: 52 Post(s)
I used to own a D2 unit and decided to move away when there seem to be no D3 in sight.
I have not visited this thread in a while but stopped by to check on the newest information on the D2/D2V units and sucessors. I am surprised to read that the D2V is now considered a dead end and no direct replacement in sight. Maybe the price level/demand is not worth the effort to Anthem? I loved my D2 and kept lurking for a D3 version. Sounds like it was not to be.
Nicoff is online now
post #44732 of 44753 Old 01-31-2017, 05:41 PM
Thxtheater's Avatar
Quoted: 108 Post(s)
Liked: 99
The AVM60 is a better sounding unit than the D2 from people who have owned both. Probably not a bad time to jump to an AVM 60. If there is a D3 on the horizon then the AVM 60 will still be a prime unit for resale.
Thxtheater is offline
post #44733 of 44753 Old 01-31-2017, 11:54 PM
AVfile's Avatar
Quoted: 244 Post(s)
Liked: 126
Originally Posted by Doright View Post
Hi all,
Long time member who's finally doing some upgrades after many years.
Here's my setup: New Oppo 203 running directly to a new JVC RS400. I still have my old Anthem D2 and I'm trying to use the secondary HDMI audio from the Oppo to the D2 for sound, with no luck. I've tried every possible setting in the Oppo and the Anthem with no luck. The weird thing is, when I turn on my regular TV and go into settings on the Anthem, I start hearing the sound from the Oppo but when I back out of the settings, the sound goes off. Any ideas ? Thanks for your help!
Any luck?
I have a slightly different problem with the UDP-203. No audio on the main output but I do get audio on the "audio only" output.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is online now
post #44734 of 44753 Old 02-06-2017, 10:40 AM
wse
wse's Avatar
Quoted: 2040 Post(s)
Liked: 748
Wink
And three times less expensive
wse is offline
post #44735 of 44753 Old 02-06-2017, 12:18 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2367 Post(s)
Liked: 2973
Originally Posted by AVfile View Post
Any luck?
If you have both HDMI outputs of the OPPO 203 connected, there is no audio on Main HDMI. Only on Audio HDMI.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #44736 of 44753 Old 02-06-2017, 11:08 PM
AVfile's Avatar
Quoted: 244 Post(s)
Liked: 126
The problem is when only the Main output is connected to the AVM50v3D (i.e. normal configuration) with the Anthem video processor in Passthrough mode. If I use Main and Audio outputs in a split configuration it works as expected.
Have you tried the 203 on your D2v3D in normal configuration?
Also like the other fellow stated, audio starts working when entering the Anthem Setup menu and stops upon exit. The other way it "works" is with the Anthem video processing enabled (not Passthrough) which means no 3D.
I have sent logs to Oppo.
post #44737 of 44753 Old 02-07-2017, 05:55 AM
Read the FAQ!
Liked: 2973
^ With the LG E6, I've found I have to disable the E6's HDMI Ultra HD Deep Color for the HDMI input in the E6 being fed by the Anthem. This works for normal Blu-ray and 3D/Blu-ray without losing anything, and of course the Anthem can't pass 4K so no problem.
I don't know if that's related to what you are seeing with your Display.
Since the Anthem can't pass 4K, I normally use dual HDMI cabling, of course.
--Bob
post #44738 of 44753 Old 02-07-2017, 01:25 PM
dlynch34's Avatar
Quoted: 269 Post(s)
Liked: 104
Did someone do a side by side comparison of this? I am surprised if that is true. I am not saying the avm 60 is a bad unit I just know how great sounding the d2v has been.
Don
Marantz AV8802a,Parasound Halo A21, Emotiva XPA-1l x4,Emotiva MPS-2. Rhythmik DIY 15inch x2, Plus, Magnapan 3.7i, Magnepan CC5,Magnepan MC1,JVC RS400, DIY 125" 2:35 Elite Screen cinegray 3d .
dlynch34 is offline
post #44739 of 44753 Old 02-07-2017, 04:50 PM
Read the FAQ!
Liked: 2973
The post cited AVM 60 vs D2, not D2v. It's been a long time since I played with a D2. Based on my experience it is NOT the case that the AVM 60 sounds better then a D2v or D2v/3D when both are set up correctly.
--Bob
post #44740 of 44753 Old 02-08-2017, 01:40 PM
gjwAudio's Avatar
--Bob
Hi Bob
Can you please point to the post(s) - or give the simplified explanation - of why D2v/3D units have improved audio compared with D2's ? I'm curious to learn what I might be missing out on (sonically)... and is an AVM 60 the smart way to get there.
BTW, no interest here in going beyond 5.1 speaker compliment.
gjwAudio is offline
post #44741 of 44753 Old 02-08-2017, 09:15 PM
AVfile's Avatar
Quoted: 244 Post(s)
Liked: 126
So the 203 works on your D2v3D in Passthrough mode! Any other 203 owners care to chime in?
It seems I have always had odd HDMI issues ever since the 3D upgrade was installed by anthem. I wonder if the board is defective or not properly installed.
post #44742 of 44753 Old 02-10-2017, 06:45 AM
buddy4711's Avatar
Bi-amping my D2 A5 combo
Hello,
haven't been here for a while but returning now. I still have an old D2 and an A5 main amp and it is still running w/o issues!
I want to start a new project which is bi-amping my speakers FR and FL. I am running a 5.1 system but use only 3 channels on the main (FL, FR and Center) since SR and SL are active LS and divert directly from the D2. This way 2 channels on the mains are unused.
I searched a bit about this technology and found a solution by using a 2 Y links from the preamp's FR and FL channels to the corresponding channels input on the main (3 as before) and to the additional 2 channels (which are usually used for SR and SL) and hence from here with 2 LS cables to each LS.
Is this a proper set-up for a bi-amping strategy regarding my specific setup? For any hints I am very thankful.
Or is there another (smart) way to achieve the same? E.g. using the empty channels for Zone 2 / 2nd center or 2nd sub on the D2 and connect these directly to the main amp using the additional XLR cables (I noticed in the manual there is a setting in Audio Output which let one choose between Zone 2 for L/R output or use a 2nd center or subwoover. But with these I think I am running into volume issues; I have not found a setting that let me combined adjust the volume for both main zone and zone 2.
Any suggestions regarding crossover settings? I plan to feed the bass speakers with one amp and trebble+high with the second.
Any other suggestions which I might not be aware off?
Thank you!
Juerg
buddy4711 is offline
post #44743 of 44753 Old 02-10-2017, 01:22 PM
gerard1meehan's Avatar
Quoted: 32 Post(s)
I am running a bi amp configuration with my D2v. I utilize Y'd XLR cable from the right and left channel into the amps.
gerard1meehan is online now
post #44744 of 44753 Old 02-16-2017, 08:28 AM
Liked: 0
D2V 3D HDMI not compliant with 4k
I was thinking about getting a 4K telly, so I checked with Anthem directly to see if the D2V. Anthem's tech support reply is that the HDMI technology is from 2012. 4k HDMI technology was introduced in 2015, so due to HDCP the Anthem cannot pass a 4K signal thru. Seems like a $9000 cluster to me. Here is their exact quote "FEB 16, 2017 | 09:45AM EST
Andrew B replied:
Good Morning Tim,
Typically for runs longer than 6 ft, it is recommended to use active cables as they will allow you to go further distances without degrading the signal. As for the D2V and 4K, due to the HDMI spec on the D2V being from 2012 and the 4K standard being from 2015, it will not allow the video to pass due to HDCP. Have a nice day!"
bohaiboy is offline
post #44745 of 44753 Old 02-16-2017, 08:46 AM
cvinfig's Avatar
Quoted: 149 Post(s)
Liked: 102
Andrew B replied:
Good Morning Tim,
No *****, you'd think they'd be able to utilize their time machine to address this egregious error! Or, you know, you could just run your 4K source directly to your 4K display - thus far all UHD players have dual HDMI outputs so audio could still run through the D2V.
Sorry, couldn't resist.
AVfile likes this.
cvinfig is online now
post #44746 of 44753 Old 02-16-2017, 09:05 AM
Liked: 0
Andrew B replied:
Good Morning Tim,
bohaiboy is offline
post #44747 of 44753 Old 02-16-2017, 05:47 PM
Liked: 0
Would the lip syncing be off with running audio thru the D2V and video directly to source?
bohaiboy is offline
post #44748 of 44753 Old 02-16-2017, 05:53 PM
Liked: 0
Some of the streaming devices, like Amazons FireTV, already have 4K streaming if content is available and have only one outlet.
bohaiboy is offline
post #44749 of 44753 Old 02-16-2017, 07:13 PM
AVfile's Avatar
Quoted: 244 Post(s)
Liked: 126
Oppo UDP-203 has an HDMI input for that.
post #44750 of 44753 Old 02-16-2017, 07:37 PM
arftech's Avatar
Quoted: 162 Post(s)
Liked: 128
I have not experienced lip syncing issues ruuning a 25' HDMI (video only) cable from the 203 to my TV. I run a separate HDMI (for audio) cable from the 203 to my Anthem.
Oppo UDP-203, Anthem AVM50V 3D Pre-Pro, Krell KAV-500 3 Channel Amp, Adcom GFA-535 2 Channel Amp, Cary Audio 306/200 CD Player, Emotiva Stealth DC-1 DAC, Oppo HA-2 DAC/Amp, Hifiman HE-500 Headphones, Audeze EL-8 Headphones, Westone UM 50 Pro in ear monitors, Apple PowerBeats 3, MacBook Pro-Tidal HiFi/Roon, Apple iPad Pro/Roon, Sony XBR65X930C, Sonus faber Luito Towers, Sonus faber Luito Monitors, Sonus faber Smart Center Channel, REL T2 sub, Sony SWF-BR100W Wireless Subwoofer for 930C
arftech is offline
post #44751 of 44753 Old 02-20-2017, 01:39 PM
AVfile's Avatar
Quoted: 244 Post(s)
Liked: 126
Does anyone know the latest revision of the HDMI mezzanine board for the 3D upgrade?
Are there any known issues driving an active HDMI cable from it?
post #44752 of 44753 Old 02-21-2017, 04:33 AM
buddy4711's Avatar
Settings for USB to serial adapter
Hello, I am looking for help!
I was running ARC on a D2 with a direct RS-232 connection directly to my old PC and this was running fine. Now, I do not have that PC anymore but another one only with USB ports. I searched the web and also this thread and probably the Keyspan Adapter would fix my connection problem. Unfortunately the Tripp Lite Keyspan is not available over here. I tried with 2 other brands on Windows 10 PC but no luck, just frustration.
I was wondering if anybody can give me some hints which property values on the adapter must be chosen (the defaults are listed underneath):
Bits per second: 9600
Databits: 8
Parity: None
Stoppbits: 2
Flow Control: none
In the extended setup page there is a checkbox set to yes for FIFO-Puffer usage (requires 16550 compatible UART). Thereafter comes also a slider to change Input-Puffer and Transmission-Puffer. Different lower values than the max default settings I tried already, but that did not make a success as well.
The adapter is shown as COM6.
I tried many different settings, no luck but lots of frustration. The message I get from ARC software is: error - could not find any D1/D2 devices (or similar)
Thanks for any help!
Juerg
post #44753 of 44753 Old Today, 07:52 AM
Quoted: 32 Post(s)
Databits: 8
Parity: None
Stoppbits: 2
Flow Control: none
Juerg
I will not be of any help on the "settings". However where is "over here"? I ask as Amazon/us/UK & Germany all have the adaptor and between the three they tend to ship worldwide
Hope that helps
Receivers Amplifiers
