Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1493 - AVS Forum | Home Theater Discussions And Reviews
 148Likes
post #44761 of 44772 Old 02-26-2017, 06:20 AM
jeff442's Avatar
Originally Posted by AVfile View Post
Hi jeff, we went over this recently.
The D2v and Avm50v do sound a bit better than the D2 / Avm50, even via HDMI. Search this thread for "comparison chart" to find why. There is also the "nice to have" decoding of DTS HDMA and Dolby TrueHD in the v models. Yes your Oppo can do this too, and all models will accept PCM 5.1 via HDMI, but it's good to have the option of doing it both ways for compatibility reasons.
Also regarding the faceplate ears, the 50v does not have them and might be more in your budget.
So far I'm about 100 pages into this mega-thread. Any idea around what page or what date the comparison chart was posted on?
jeff442 is online now
post #44762 of 44772 Old 02-26-2017, 09:32 AM
AVfile's Avatar
Quoted: 250 Post(s)
Liked: 129
Enter "comparison chart" or any keywords you are interested in to the Search field at the top of this thread. Most recent results will appear first.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #44763 of 44772 Old 02-26-2017, 11:34 AM
arftech's Avatar
Quoted: 165 Post(s)
Liked: 131
Is this what you're looking for?
https://www.anthemav.com/downloads/a...risonChart.pdf
Oppo UDP-203, Anthem AVM50V 3D Pre-Pro, Krell KAV-500 3 Channel Amp, Adcom GFA-535 2 Channel Amp, Cary Audio 306/200 CD Player, Emotiva Stealth DC-1 DAC, Oppo HA-2 DAC/Amp, Hifiman HE-500 Headphones, Audeze EL-8 Headphones, Westone UM 50 Pro in ear monitors, Apple PowerBeats 3, MacBook Pro-Tidal HiFi/Roon, Apple iPad Pro/Roon, Sony XBR65X930C, Sonus faber Luito Towers, Sonus faber Luito Monitors, Sonus faber Smart Center Channel, REL T2 sub, Sony SWF-BR100W Wireless Subwoofer for 930C
arftech is offline
post #44764 of 44772 Old 02-26-2017, 03:54 PM
jeff442's Avatar
Originally Posted by arftech View Post
Thanks. I'm not sure if that is the chart that AVfile is referring too as lists the 50, 50V and D2V. It doesn't seem to list the D2, which I am trying to compare to the D2V for audio purposes only.
post #44765 of 44772 Old 02-26-2017, 04:11 PM
Shrike645's Avatar
Quoted: 46 Post(s)
Liked: 40
I don't remember any comparison chart for them but do remember Bob Pariseau, who had both, saying that while he did not expect it, the D2v did sound slightly better then the D2.
Shrike645 is online now
post #44766 of 44772 Old 02-26-2017, 04:39 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2402 Post(s)
Liked: 3041
^ More than slightly. I was quite surprised at the time.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #44767 of 44772 Old Yesterday, 07:02 AM
jeff442's Avatar
Originally Posted by jo5507 View Post
Yes, your assumptions are all correct. The ears can be removed, but you need to remove the top cover and IIRC, the front panel to get at the screws. I removed mine on a D2V and it's not difficult to do.
As with so many elements in the audio chain, sound quality differences between models is subjective and influenced by many factors, so I wouldn't stress about this. They will all give you very good quality sound.
Thank you very much! This is very helpful. Considering that the going used price for a D2 and a 50V are both $1200-1500, and the fact that I don't need video processing or switching, would you agree that the D2 would provide the best sound quality for the price?
post #44768 of 44772 Old Yesterday, 07:43 AM
stanger89's Avatar
Quoted: 2765 Post(s)
Liked: 1425
Since this is the greatest knowledgebase of Anthem/ARC setup/tweak knowledge...
I'm looking at getting a new screen, and I'm pondering microperf instead of woven. However I know microperfs generally require a bit of EQ up high to compensate for the screen. Is there any way to do that with an Anthem? I've actually got an MRX1120 now. ARC doesn't correct over 5kHz on the MRXs, and even on the AVMs it didn't allow you to boost treble IIRC.
Has anyone done this? Can you just boost the treble control? Or is that not accurate enough?
stanger89 is online now
post #44769 of 44772 Old Yesterday, 11:00 AM
Read the FAQ!
Liked: 3041
Do an ARC Measurement pass and see what you've actually got up there. Depending on your speakers, you may not even need any compensation.
The Statement pre-pros (including the AVM 50v) let you raise the upper limit for ARC correction above 5kHz. You need to do that judiciously because treble measurements are directional and so you may not get good enough readings up there to want to "correct" them.
You can also adjust the Treble control to your taste.
--Bob
post #44770 of 44772 Old Yesterday, 11:20 AM
jo5507's Avatar
Personally, I would choose the 50V to take advantage of the additional connection flexibility offered. The D2 might have a superior analogue section....at least in technical terms. I haven't read anything that compares the older D2 with the newer 50V. Whether you would hear a significant difference in a blind , side by side test is all that really matters and my subjective opinion is...probably not. And different doesn't mean "better" in any case. Only you can decide if any differences heard are going to increase your enjoyment of the listening experience. If it's primarily for listening to music and you have young golden ears, an excellent room, and outstanding speakers, amps, etc, then I would look more closely at potential differences. Otherwise I believe either choice will provide excellent results.
jo5507 is offline
post #44771 of 44772 Old Yesterday, 06:02 PM
AVfile's Avatar
Quoted: 250 Post(s)
Liked: 129
That is the chart. You need to weigh the benefits of the better analog parts quality in the Statement series versus the better HDMI handling of the v-series. Are you using mainly HDMI or SPDIF digital sources? Any analog sources?
Print it out and highlight the differences between the 50 and 50v. The D2 will not have the additional features that the 50v has over the 50. Then highlight the differences between the 50v and D2v in a different color. That should give you the other delta.
arftech likes this.
AVfile is offline
post #44772 of 44772 Old Today, 06:17 AM
jeff442's Avatar
Thanks - that helps. For 2 channel listening, I use the analog outs in the Oppo as it has the upgraded Nuforce ouput board. I have no need for HDMI switching as I have enough inputs on my TV to accommodate my Oppo Bluray, Xfinity cable box, Logitech Squeezebox, and Apple TV. The cable, squeezebox, and Apple TV are feeding 5.1 audio to my current processor via SPDIF.
As I will not be using any of the video processing/switching capabilities of the processor, I want to limit my comparison to audio performance only. Based on the chart, here is what is making the D2 look more attractive than the 50V, at least for my application:
-Premium ADC's and DAC's
-Premium parts in analog audio section
What appears to be lacking in the D2 vs the 50V would be:
-DTS Master and Dolby TrueHD decoding in processor (Since my Oppo can decode and pass LPCM to the D2, this should be a non factor)
-ARC-1 standard (90% of the used models I have looked at include the ARC-1 kit, so again non factor)
-Larger lip synch range (hard to say if there would be much benefit here)
I am unsure if I am missing out on anything with these remaining options that I noted as missing in the D2 vs the 50V:
-Multi channel PCM input limited to 5.1 24bit/96khz vs 7.1 24bit/192khz. Not sure how this might come into play based on my application
-Dual core, dual processor audio DSP on the 50V. Again, not sure if this is pertinent, based on how I plan on connecting my components
Receivers Amplifiers
