Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1497 - AVS Forum | Home Theater Discussions And Reviews
 164Likes
post #44881 of 44885 Unread 06-18-2017, 07:24 AM
BigCoolJesus's Avatar
Quoted: 1037 Post(s)
Liked: 600
Nvm
BigCoolJesus is online now
post #44882 of 44885 Unread Today, 08:00 AM
muad'dib's Avatar
Quoted: 193 Post(s)
Liked: 57
Have an interesting situation I need advice on..
I have 2 sub15's and an anthem avm60..
For now, I don't want to run ARC on anthem as I find without ARC in my room seems better..
So question..
Would I do a PBK reading from each sub separate, then, set levels and average distance for both subs together.?.
I know it's best to eq subs together, but since I want bass eq, with no ARC.. Or if down the road had to get a different preamp with no eq, what is recommended..
If yes to eq each sub seperate, then question on mic locations..
One sub is doing bass for center seat to extreme right seats... It does not really add do any good bass from center to left most seats...
So second sub, does the bass from center seat to extreme left seats.
Together both subs give even bass across the entire seating area...
What locations for each sub would be best for readings..
Sent from my LG-H831 using Tapatalk
muad'dib is online now
post #44883 of 44885 Unread Today, 10:53 AM
dmusoke's Avatar
Quoted: 362 Post(s)
Liked: 184
So question..
I'm a firm believer in placing at least one sub close to you (or behind you) and the other up front. Not that you want to hear most from the closest sub but the bass sounds best to me, as I've had 2 SVS SB16 subs up front and 1 sub front and 2nd sub five feet to the left of me.
The trick to getting the best from dual subs is phase matching the subs. In my case, I left the phase of the first sub to its default 0 degrees. I then adjusted the phase of the 2nd sub, the one closest to me, until the combined frequency response was as even and maximal as possible.
Of course, each sub had been gain calibrated to produce 75dB at my MLP (Others use 72-73dB but I like mine a little hot). ARC's Live Measure tool will help you determine the best and optimal phase angle of the 2nd sub as you see how the shape of the combined frequency response varies with phase angle. Once this angle has been determined, you lock it in the sub and make sure you never change it, unless you relocate that sub.
Probably, the reason why you felt the subwoofer sound was better w/o ARC than with ARC was that the subs were not been optimized to play as 1 virtual sub. That's the key...to have them appear acoustically as one wide sub. Also, I use a D2v prepro and the Subwoofer Target Settings has an option setting to the set the HPF order to 'Flat' and not Auto or something else. "Flat" ensures ARC follows the frequency response of your virtual sub and not try to contour it like the "Auto" setting does...
The last thing to do is to time-align this 1 virtual sub to your mains by determining the optimal subwoofer distance to enter into your AVM60 within the xover region. The Anthem manual gives a few ways of doing it. I use a more advanced method which might or might not appeal to you (see my signature for details).
These two things are responsible for the best tactile, 3-dimensional bass I've ever had in my living room. Best of luck!
- David
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is online now
post #44884 of 44885 Unread Today, 11:27 AM
muad'dib's Avatar
Quoted: 193 Post(s)
Liked: 57
- David
Thanks for awesome reply...
Actually, I loved what ARC did for subs, but not so much for rest of speakers.
Hence , why I don't want to use ARC but, still want the results of ARC for my subs..
Since my subs have PBK built in, I was looking for an alternative to using ARC In anthem..keeping rest of my speakers unaltered
I ages with your sub setup, thst is how I did find in the end thr locations..
One ended up in front and other in rear.
The one in rear does center seat to extreme left seats...
And front seems to work best for center seat to extreme right seats...
They each do half thr seating area... Just way my unfinished room is...
post #44885 of 44885 Unread Today, 12:29 PM
dmusoke's Avatar
Quoted: 362 Post(s)
Liked: 184
1. You can limit ARC's operation to 200Hz or whatever the lower limit is for the AVM60. The so-called 'Schroeder frequency' is the range of frequencies where the room resonance has the most effect on sound waves. It's about 200Hz meaning at frequencies from up to 200Hz, the bass response is going to be determined by your room dimensions. You can tell ARC to work its magic up to 200Hz. It's ok to extend it to 300Hz, depending on what your ARC plots look like. In that way, it leaves all other frequencies untouched.
Without in play, you are missing out on the other bass management stuff that it does, such as speaker trims, optimized xover settings, and speaker phase distortion corrections which help integrate the sound into a better whole sound field.
2. With the rear sub, you need to adjust its phase until its perfectly blended with the front sub to eliminate room peaks and nulls. You are guaranteed that by placing it in the rear, the front and rear subs are out-of-phase with the front sub. This produces weak and inconsistent bass. You do not want that to happen.
Follow the procedure I mentioned above to phase match the subs after they've each been gain matched to 75dB at the MLP using your trust analog or digital sound pressure meter. I use a radioshack one, but others exist as well.
Good luck!
Receivers Amplifiers
