Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 179 - AVS Forum | Home Theater Discussions And Reviews
 146Likes
post #5341 of 44743 Old 03-29-2007, 02:58 PM
3Dfx's Avatar
Ah, ok. It's been mentioned the Anthem has a default 2.35:1 setting and I wondered why I had not seen it in the scaler.
3Dfx is offline
post #5342 of 44743 Old 03-29-2007, 03:18 PM
3no
3no's Avatar
I too have set up overlays for those inputs which might have 2.35 material.
From the math, the vertical size (Crop Input/Custom Setting/Vertical Size) should be 1920/2.35=817. Empirically, I've found that I'm happier with about 805 to ensure vertical stretch all the way to the screen frame, even though that is probably distorting the image vertically by 1.5%, given that my anamorphic lens does the horizontal stretch to 2.35 (times the screen height) and 805 is a vertical stretch for 2.385.
3no is offline
post #5343 of 44743 Old 03-29-2007, 07:25 PM
3no
3no's Avatar
Well, the HVAC tech came today and fixed my A/C. Plus the temp in Atlanta dropped this afternoon into the 60s. Didn't get very far into a BD on the PS3 this evening when occasional blue screens started appearing. After a few that input (HDMI1) locked up totally. Came back after a while, but I'm not sure whether it was my reload of factory defaults, multiple power cycles, or just waiting.
In any case, the air temp at the D2 inlet at the time all of this happened was 78F. Maybe not as cool as it could be, but well below the point where it was rock solid previously. Could my thermal problems have damaged the VP or some other component so that it is now even more sensitive to heat? I'll ask Nick tomorrow.
This is a real PITA. Out of desperation I'll see if I can exchange the PS3 for another one. Maybe they aren't all created equal and that's why not everyone is seeing the same problems...
3no is offline
post #5344 of 44743 Old 03-29-2007, 08:11 PM
Hyenna's Avatar
Anyone else having problems with 480i output from the Toshiba A2 HD-DVD player?
Since I installed 1.11g (and now 1.11e) all my colors are screwep up when I select 480i output from the Tosh, works fine with 480p, 720p and 1080i though.
Tried every color settings and that did nothing. Colors are fine if I connect directly to my TV.
Wish I had stayed with 1.06 now - it was working back then.
Hyenna is offline
post #5345 of 44743 Old 03-29-2007, 09:15 PM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 284 Post(s)
Liked: 3943
If heat has damaged a part, it's a "out of margin" piece. The heat tolerance of all parts is taken in consideriation in designing these things and the thermal shut off of the unit should kick in before any of the parts fry. Also, I would hope the D2s are tested at or slightly above thermal shutoff for long periods of time to make sure everything is ok. I don't mean each unit, but during the first production unit(s) phase. I still think it can be the PS3 (maybe here and there just to throw you off), those puppies run very warm. I don't recall if you took it out of the cab and ran it where it would be unlikely to over heat.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #5346 of 44743 Old 03-29-2007, 09:19 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2256 Post(s)
Liked: 2822
Can you describe the color screwup more precisely? Are you using HDMI or Component?
Double check the settings in the Video Source Adjust menu to be sure nothing odd got introduced there in the course of the software changes.
Insure that Video Source Adjust / Output / Frame Lock = OFF.
If using HDMI, insure that Setup / Source Select / HDMI Repeater = NO.
If using HDMI, insure that Setup / Video Output / Preferred = HDMI.
Double check that any overlayed inputs (DVD1 vs. DVD2, etc.) that you are not using are "disabled" so that you can't select one of them by accident. Do this in Setup / Source Select for each input in turn.
EDITED TO ADD: If the above doesn't lead to a fix for your problem, switch your A2 to 480i (so that you have the problem) and see if you can bring up the Video Source Adjust menu. If you can, go to the Info panel and report what it is showing for both the input and output values.
Back out of the Video Source Adjust Menu and, presuming you are still seeing the problem, press the Select button on the remote repeatedly and report what it is showing for each set of status (except we won't need your unit serial number). This status info can also be read on the Anthem's front panel display if your TV imaging is so screwed up that you can't read it there.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #5347 of 44743 Old 03-29-2007, 10:34 PM
lumikola's Avatar
My A/C is being repaired as I type this. But why do you need A/C in Finland? Just bring in outside air
Summers can be very warm, but nothing compared to your conditions, of course I got mail from Nick and he asked me to position a small fan to draw air away from the top of the D2. I try this during weekend. Let's see what happens.
lumikola is offline
post #5348 of 44743 Old 03-30-2007, 05:41 AM
3no
3no's Avatar
I thought this time of year you would still have piles of lumi everywhere.
The small fan worked for me, until last night anyway. I placed a PC case fan directly on top of the D2, resting on the slots in the center of the case, oriented so that it was blowing directly up, drawing hot air out of the case.
3no is offline
post #5349 of 44743 Old 03-30-2007, 05:46 AM
3no
3no's Avatar
Nick had me take the PS3 out of the rack (easy to do, it's just sitting on a shelf) and repeat the test. No change in behavior.
I'm swapping out the PS3 later today, just in case...
3no is offline
post #5350 of 44743 Old 03-30-2007, 10:57 AM
lumikola's Avatar
Lumi (how do you know that word ) has gone, this spring's been extremely warm near Helsinki.
Nick strongly believes that the reason is heat in my case. After this weekend I can be sure if that's true. First air conditioning on Saturday and if it doesn't help, on Sunday I will install a huge fan. I'll keep you informed.
lumikola is offline
post #5351 of 44743 Old 03-30-2007, 11:16 AM
ssbn04's Avatar
Originally Posted by Bob Pariseau View Post
As DRHANKZ notes, setting the S3 to always output 1080i, regardless of what channel you are watching, will keep it from having to do as many HDMI re-handshakes. [Every time it changes output resolution it has to re-establish the HDMI connection anew.] You will still have re-handshakes going in and out of its menus however.
The scaler in the S3 is better than most set top boxes, but still not as good as what's in the Anthem. So if you can live with the problem, or when you get a fix from Anthem, it is best to return to "native" output so that SDTV is sent to the Anthem as HDMI 480i and HDTV is sent as HDMI 720p or 1080i and the Anthem takes it from there.
Again, this problem appears to be in the S3 itself. So what Anthem is trying to do is find a way to workaround the S3's limitations without damaging how HDMI input works from other devices.
--Bob
Thanks Bob - I've set the S3 to native 1080i and improved the dBi several points.
ssbn04 is offline
post #5352 of 44743 Old 03-30-2007, 01:04 PM
rudolpht's Avatar
Native or 1080i?
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
post #5353 of 44743 Old 03-30-2007, 01:19 PM
ssbn04's Avatar
Originally Posted by rudolpht View Post
Native or 1080i?
Sorry - yep, 1080i always
ssbn04 is offline
post #5354 of 44743 Old 03-30-2007, 03:06 PM
Read the FAQ!
Liked: 2822
For folks having issues with Apple TV HDMI connections, there's not really any new news. But it has become a common enough complaint that it's now an item on the MacFixIt site:
http://www.macfixit.com/article.php?...70330090814465
You might want to keep an eye out there for any updates.
--Bob
post #5355 of 44743 Old 03-30-2007, 05:58 PM
ManWithAPlan's Avatar
FWIW guys, I continue to "suffer" through in Native mode as always since the day the S3 came out. Though as I've said before there are occasional losses of signal when switching between HD and SD channels, this is fairly rare, rare enough for me and the better half to have no issues leaving it on this setting. The high quality of the D2 scaling/deinterlacing is a joy to behold, so I leave it in Native mode. It just doesn't seem as bad in my setup as you guys are reporting.
I am running 1.10 still, stable as can be, and I feel no need to jump off of it.
-Brian
ManWithAPlan is offline
post #5356 of 44743 Old 03-30-2007, 06:11 PM
Oh, guys, with AppleTV, use Component, it works flawlessly and looks gorgeous when the AppleTV is set to 720p, its native output. Let the D2 scale that and enjoy!
All this worry about HDMI is making me nutty with regards to this device. The output is 720p, there is no need for HDMI from this thing, you'll never see a difference...use Optical and Component, and be done with it....
Great device by the way, I love it! Pictures and HD video's look amazing on the thing through the D2.
My 2 cents,
Brian
post #5357 of 44743 Old 03-30-2007, 07:34 PM
AnthemAVM's Avatar
Got my XA2, plugged it in and it works perfect with the D2.
AnthemAVM is offline
post #5358 of 44743 Old 03-30-2007, 10:12 PM
lumikola's Avatar
Before doing anything else, I moved PS3 two meters away from D2. And now, after two hours playing etc., there haven't been any blue screens. I didn't notice and believe before that PS3 creates a huge (!) amount of heat, but I'll keep it far away from other equipment now.
It's evident that there's nothing wrong with 1.11g and PS3. D2 just seems to be slightly heat sensitive with PS3, which must be taken into account. If this problem doesn't appear anymore, everything works perfectly in my D2 system. I can only thank Nick for fast and clear support
lumikola is offline
post #5359 of 44743 Old 03-30-2007, 10:16 PM
Read the FAQ!
Liked: 2822
Hmmm. I wonder whether it's really heat or if the PS3 is perhaps putting out RF interference -- maybe only when it has an HDMI cable connected to it -- that is giving the D2 grief.
--Bob
post #5360 of 44743 Old 03-30-2007, 10:19 PM
Read the FAQ!
Liked: 2822
Gee, I don't know what to say. Given it's the weekend and all -- I realize this may not be what you want to hear -- but you may just need to wait until Monday to contact Anthem tech support.
(grin!)
--Bob
post #5361 of 44743 Old 03-30-2007, 11:08 PM
rudolpht's Avatar
-Brian
Brian,
I've gone native, I mean stayed native too. But it works much better via component (like the advice you cave on Apple TV ))
I have to admit I listened to Hank and it was the right thing to do going component and leaving the source change startup issues behind.
Tim
rudolpht is offline
post #5362 of 44743 Old 03-30-2007, 11:17 PM
lumikola's Avatar
--Bob
This is from Nick's email:
"...It ('problem') is not a result of the PS3, which gets hot itself, creating enough heat to cause problem because the problem exists (in the last system) when PS3 is used outside of the rack, away from the D2. Furthermore, many people are using a PS3 with a D2 without a problem.
We reproduced the problem here after putting the D2 in a box and connecting a PS3, which we had since not long after they came out. This is not the normal way to use a D2 of course."
According to Nick, all reported three PS3 blue screen cases before me were heat related. After four hours of enjoying PS3 this morning, there are still no problems in my system. Temperature close to D2 is appr. 3 degrees lower than before moving PS3.
lumikola is offline
post #5363 of 44743 Old 03-31-2007, 01:10 PM
Rob Tomlin's Avatar
What FW version are you using?
Rob Tomlin is offline
post #5364 of 44743 Old 03-31-2007, 09:20 PM
lumikola's Avatar
Air conditioning was installed yesterday. I moved PS3 to it's original place appr. one meter below D2. After couple of hours, there are no blue screens and temperature in the back of D2 is couple of degrees lower than in original situation (no A/C). Everything's working well.
lumikola is offline
post #5365 of 44743 Old 04-01-2007, 08:10 AM
Read the FAQ!
Liked: 2822
http://www.cnw.ca/fr/releases/archiv.../30/c8798.html
What does this mean for Anthem? Will we see a Wave D2?
--Bob
edit: april fool!
post #5366 of 44743 Old 04-01-2007, 08:15 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
--Bob
I think your link is broken.
drhankz is online now
post #5367 of 44743 Old 04-01-2007, 08:29 AM
obie_fl's Avatar
Liked: 33
--Bob
Boy I hope they get that noise cancellation going on the D2 too...maybe that is the fancy EQ solution Lev keeps talking about.
obie_fl is offline
post #5368 of 44743 Old 04-01-2007, 08:29 AM
PaulT_BC's Avatar
--Bob
AF to you too
"One of the problems of taking things apart and seeing how they work--supposing you're trying to find out how a cat works--you take that cat apart to see how it works, what you've got in your hands is a non-working cat."
-- Douglas Adams
PaulT_BC is offline
post #5369 of 44743 Old 04-01-2007, 08:35 AM
Read the FAQ!
Liked: 2822
I can't understand it. Try searching using today's date.
--Bob
post #5370 of 44743 Old 04-01-2007, 10:22 AM
lalarsons's Avatar
I am not finding any news articles referenced to Anthem, Paradign or Bose....
Reject Passivity, Accept Responsibility,
Lead Courageously, Live for the Greater Reward
Rick
lalarsons is offline
Receivers Amplifiers
