Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 361 - AVS Forum | Home Theater Discussions And Reviews
 146Likes
post #10801 of 44743 Old 01-23-2008, 09:33 AM
dschamis's Avatar
Originally Posted by mlbrand View Post
Does the D2 decode the AAC audio file format? I can't seem to find this info anywhere else.
mlbrand,
AAC is Apple's format. Do you mean can you link an Airport Express to the D2 via an optical digital cable and stream music? If so, then the answer is yes.
David
dschamis is offline
post #10802 of 44743 Old 01-23-2008, 09:43 AM
cosmos5861's Avatar
My AVM 50 is hook up to directv H20 via HDMI. I have a panasonic TH50pf9uk. Lately when I change to a HD channel like 720 or 1080i, AVM 50 will not change?? it remains at 480? If I go up and down channel it clears up??
Any idea?
cosmos5861 is offline
post #10803 of 44743 Old 01-23-2008, 01:16 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
Hi Anthem Owners
I have seen many posts on here about Apple TV.
I know 1080i over HDMI does not work. But I understand
720p is suppose to work.
Do I need some newer D2 software to even get 720p
to work? I'm running old fashion 1.11.
Both 1080i and 720p over Component works just fine.
However, I'm running out of Component Ports.
drhankz is online now
post #10804 of 44743 Old 01-23-2008, 02:54 PM
dschamis's Avatar
Originally Posted by drhankz View Post
Hi Anthem Owners
I could be wrong but I didn't think that anything over HDMI worked - I hope that I'm wrong.
dschamis is offline
post #10805 of 44743 Old 01-23-2008, 02:56 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
That is how my Apple TV is working.
Nothing over HDMI and ONLY Component.
I thought I remember reading that 720p over HDMI worked.
But then maybe those souls are running newer D2 FW.
post #10806 of 44743 Old 01-23-2008, 03:01 PM
dschamis's Avatar
I'm pretty sure that 720p doesn't work on mine and I'm running the latest firmware. Again, I haven't explicitly checked this lately so I will check again tonight.
dschamis is offline
post #10807 of 44743 Old 01-24-2008, 07:53 AM
gblack's Avatar
Apple TV doesn't work with HDMI and D2 period. which is unfortunate. Hopefully the upcoming software upgrade on the ATV corrects the problem (an HDCP handshake problem)
gblack is offline
post #10808 of 44743 Old 01-24-2008, 08:00 AM
Ian_Currie's Avatar
Quoted: 13 Post(s)
Strange, I have two ATV's, but the only one hooked up via HDMI (which does work) is not the one in the system with the Anthem (I had run out of HDMI inputs on the Anthem and had to use component for the ATV).
Why would it just not work on the D2?
Ian_Currie is online now
post #10809 of 44743 Old 01-24-2008, 08:20 AM
ManWithAPlan's Avatar
Agreed...component and optical are the only way to go right now thru the D2...tried it again recently just to make sure...hopefully the new upgrade to the AppleTV fixes it...but component is fine with me if it doesn't.
Brian
ManWithAPlan is offline
post #10810 of 44743 Old 01-24-2008, 08:58 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
I assume there is some ATV HDMI issue between the Anthem
and the ATV. I talked with Apple Tech Support yesterday and
they did say 720p over HDMI is suppose to work but they
acknowledged 1080i does not. They would not say that 1080i
would be fixed in future software update.
post #10811 of 44743 Old 01-24-2008, 09:36 AM
zzzzdoc's Avatar
Quick question, guys.
Is the D2 HDMI 1.0, 1.1, or 1.2?
He who laughs last...Thinks slowest.
zzzzdoc is offline
post #10812 of 44743 Old 01-24-2008, 09:58 AM
benleeys's Avatar
Hi guys,
I haven't seen anybody mentioned that the latest D2 software available for download is now ver 1.29j. The manual has been updated to ver 1.3x. It says the software now allows configuration for 4 video output and mentions that the ARC-1 Anthem Room Correction Kit is included in the packing.
Ben
benleeys is offline
post #10813 of 44743 Old 01-24-2008, 10:17 AM
dschamis's Avatar
Originally Posted by benleeys View Post
Hi guys,
I haven't seen anybody mentioned that the latest D2 software available for download is now ver 1.29j. The manual has been updated to ver 1.3x. It includes instructions about the ARC-1 Anthem Room Correction Kit.
Ben
Where is 1.29j available? I just checked the website and its still 1.11.
dschamis is offline
post #10814 of 44743 Old 01-24-2008, 10:26 AM
zzzzdoc's Avatar
Originally Posted by Bob Pariseau View Post
Testing that way (RS-232 command set) is certainly a start, but I suspect the problems in the past have been with burst mode reading and writing of streams of data -- and the flow control that keeps one side from getting ahead of the other side when doing that. And I'm not sure sending the short strings that make up the RS-232 commands would test that.
Keep in mind that the firmware update has to both read and write streams, since it verifies after writing. The writing side is crucial since bad firmware sent over will screw things up, but the reading side is also a problem since if one programmable piece doesn't verify I think they stop and don't send the rest of the stuff, which can lead to mismatched programming between the various separately programmable pieces. They may have improved this in the current firmware loader, but the reports that people have been running into problems with V1.21d installs using the same PC hardware that worked fine for previous installs is not encouraging.
--Bob
Good points, Bob. My method would just determine proper connectivity, COM port assignment, etc. Certainly a starting point, but no guarantee of the successful transfer of much, much larger amounts of data at higher data rates.
zzzzdoc is offline
post #10815 of 44743 Old 01-24-2008, 10:31 AM
Tim Winders's Avatar
You have to go through tech support and get the URL, username and password to download the beta software.
Tim Winders is offline
post #10816 of 44743 Old 01-24-2008, 10:32 AM
benleeys's Avatar
http://tech.anthemav.com.
By the way, instructions on setting up the ARC-1 is also available there.
Ben
benleeys is offline
post #10817 of 44743 Old 01-24-2008, 10:34 AM
From the Read Me First document:
CHANGE LIST
v1.29j:
1. Number of video-out configurations is increased to four.
2. More HDMI, HDCP, and Macrovision related changes to make largest possible number of sources compatible.
3. (Statement D2 only) Added room correction - enabling this feature requires ARC-1 microphone kit.
post #10818 of 44743 Old 01-24-2008, 11:10 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2259 Post(s)
Liked: 2824
The D2 is HDMI V1.1 in and out. The output is further limited to stereo audio (typical for TV connections).
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #10819 of 44743 Old 01-24-2008, 11:11 AM
Read the FAQ!
Liked: 2824
CHANGE LIST
v1.29j:
Does the install kit include a Setup Editor compatible with this version?
--Bob
post #10820 of 44743 Old 01-24-2008, 11:16 AM
EL
EL's Avatar
it's coming with this file
Setup Editor v1.29e.exe
EL is offline
post #10821 of 44743 Old 01-24-2008, 11:41 AM
--Bob
In the archive is LiveVideoSettingsEditor v1.20.exe (appears to be the same as in previous 1.21 releases) and Setup Editor v1.29e.exe.
post #10822 of 44743 Old 01-24-2008, 12:28 PM
Read the FAQ!
Liked: 2824
This is good. Looks like they are just about ready to make everything official -- probably as V1.30.
So has anyone been able to place an order for the ARC-1 Room EQ stuff yet?
--Bob
post #10823 of 44743 Old 01-24-2008, 12:33 PM
Milt99's Avatar
Quoted: 232 Post(s)
Liked: 245
Ben
That URL is password protected.
It ain't ignorance causes so much trouble; it's folks knowing so much that ain't so
Milt99 is online now
post #10824 of 44743 Old 01-24-2008, 12:37 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
AS ADVERTISED - You have to get it from Anthem Tech Support.
post #10825 of 44743 Old 01-24-2008, 12:39 PM
dschamis's Avatar
--Bob
I'm ready to - haven't seen anyone offer it yet.
dschamis is offline
post #10826 of 44743 Old 01-24-2008, 12:46 PM
--Bob
As soon as someone will sell it to me, I'll order it.
post #10827 of 44743 Old 01-24-2008, 03:20 PM
I decided to take the plunge and installed 1.29j. Everything seems to be OK. I wasn't having any troubles with 1.21d, so there won't be much for me to test. Will post if I notice any problems.
post #10828 of 44743 Old 01-24-2008, 04:36 PM
abc999's Avatar
Tim,
Can you send me the 1.29j firmware file? I presume its after office hours in North America, here were just getting up. email address is: ac3dtsthx88@yahoo.com.
Alvin
Philippines
abc999 is offline
post #10829 of 44743 Old 01-24-2008, 05:03 PM
Read the FAQ!
Liked: 2824
A reminder to folks, the D2 and AVM-50 firmware install files are different since the hardware is different. Be sure you specify which you are trying to get in requests like this.
--Bob
post #10830 of 44743 Old 01-24-2008, 05:18 PM
Originally Posted by abc999 View Post
Tim,
Alvin
Philippines
Sent.
--Bob
No problem, Bob. The download file from Anthem includes clearly labelled installers for both the D2 and AVM50.
=== Tim
Receivers Amplifiers
