Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 491 - AVS Forum | Home Theater Discussions And Reviews
 153Likes
post #14701 of 44799 Old 07-03-2008, 06:15 AM
xtrips's Avatar
Quoted: 17 Post(s)
Originally Posted by AnthemAVM View Post
Seems like Anthem is closing the GAP on the AVM-50 and the D2, seems like one of two things will happen.
1. The D2 will get an upgrade also, to keep it special or
2. The D2 will go out of production soon, as maybe a new product is on the way.
#1 is the winner!
xtrips is offline
post #14702 of 44799 Old 07-03-2008, 06:27 AM
darkvisionsinc's Avatar
Originally Posted by Bob Pariseau View Post
More news on ARC for the AVM units from "a usually reliable source":
It will soon (a couple weeks) be possible to order a new AVM-40 or AVM-50 with ARC bundled. The bundle will include the ARC kit (as used with the D2) plus an additional DSP hardware upgrade in the AVM. The bundle pricing is not yet available, but the word I have is that it will attractively priced. It will ALSO still be possible to order a new AVM-40 or AVM-50 without ARC or the 2nd DSP if you prefer.
About 2 weeks or so after AVM-40 and AVM-50 bundles can be ordered, current AVM-40 and AVM-50 owners will be able to order ARC upgrade kits that bundle the normal ARC kit with an AVM DSP upgrade.
THE DSP UPGRADE WILL BE FIELD (DEALER) INSTALLABLE!
Pricing will be right around $800. I.e., $400 for the ARC kit as sold to D2 customers plus $400 for the DSP upgrade.
I believe this info to be accurate, but the dates may still slip a bit.
--Bob
Any chance of the AVM-30 being in the ARC chain. I just bought mine and I would definitely spend the $800.00 for room correction. I hook my HD-DVD and Blu-Ray players directly to the tv. I like the option of not having to turn on the AVM-30 and PVA-5 every time I want to watch a movie and I am not really interested in video processing at this time but the ARC would be great. My living room where my set up is, is kind of funky with a bay window, stairway in the back, entrance into kitchen and I am sure the ARC would make my AVM-30 sound even better than it does...
darkvisionsinc is offline
post #14703 of 44799 Old 07-03-2008, 06:41 AM
Kal Rubinson's Avatar
Quoted: 696 Post(s)
Liked: 476
Originally Posted by Rob Tomlin View Post
Hey Kal, have you done your review on the Anthem yet?
Part 1 is done.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #14704 of 44799 Old 07-03-2008, 07:27 AM
ASW
ASW's Avatar
I am not sure that I would draw that conclusion - the D2 and the AVM50 have always been pretty close in terms of ability with the D2 being a "statement" product (no pun intended). Even after an AVM50 ARC upgrade, the D2 still is differentiated by:
- 24/192 upsampling on all inputs
- DTS 24/96
- lip sync 0-170 ms (0-85 on AVM)
I doubt many new purchasers for whom ARC is critical would opt for the AVM-50 and an $800-$1,000 upgrade that requires sending your new unit to the factory over buying the D2 with ARC included. Just my $.02.
ASW is offline
post #14705 of 44799 Old 07-03-2008, 08:01 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2646 Post(s)
Liked: 3374
Originally Posted by barhoram View Post
I'm having an issue with a digital audio input on my D2 that's in the theater.
We have Extron matrix switcher that feeds the rest of the house component HD and digital audio audio (coax). I've finally gotten around to adding a feed from the whole house system to the theater system. The component video works fine, but the D2 is not picking up the digital audio stream if processed through the Extron matrix switcher. If I bypass the switcher, it picks it up fine...but that won't be a long term fix.
Here is the odd thing...I drug an old HK receiver to the theater and it picks up the audio stream processed by the matrix switch just fine! Works exactly as it should. In fact, if I connect the "digital out" from the receiver to the D2, it will finally pick it up the audio.
Any thoughts?? It seems the anthem doesn't like the digital signal when sent through a matrix switch.
In Setup / Source Setup for that D2 input, confirm that Auto Dig = OFF. This simplifies the process by which the D2 syncs up to the digital audio input.
Also, temporarily try a different digital audio input on the D2.
The problem could be as simple as a faulty cable between the D2 and the switcher. If you are using optical digital cable, for example, you may have fingerprint oil on the optical tip at either end of the cable or some dust in the optical socket at either end of the cable. Try a different cable. Also, get a can of clean compressed air (of the type sold in camera stores for blowing dust off lenses for example) and try a brief squire in the optical socket at each end. Optical cable can also be damaged if it has been stepped on or bent too sharply around a corner. Coax digital audio cable can have a break inside the insulation. Again, try a different cable.
If none of those suggestions does the trick, you will need to contact Anthem tech support.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #14706 of 44799 Old 07-03-2008, 08:02 AM
Read the FAQ!
Liked: 3374
Originally Posted by bcljones View Post
Since I had the AVM 20 upgraded to the AVM 20-HD, I thought it was equivalent to an AVM 50. I'm hoping this is the case. I'm also glad to hear that this sounds like a field upgrade. I really don't want to send my AVM 20-HD across the border again!
Buddy
My guess is you'll be fine, but I'm not certain.
--Bob
post #14707 of 44799 Old 07-03-2008, 08:06 AM
Read the FAQ!
Liked: 3374
I don't know why the AVM-30 would not be included (since the D1 supports ARC and the AVM30 to the AVM50 is the same as the D1 to the D2). But mention of the original AVM-30 (i.e., a unit that has not yet been upgraded to an AVM-50) has been CONSPICUOUSLY ABSENT in everything I've seen so far regarding this upcoming ARC for AVM offering.
We'll just have to wait for the official word to come out.
--Bob
post #14708 of 44799 Old 07-03-2008, 08:08 AM
Read the FAQ!
Liked: 3374
Originally Posted by ditcin View Post
Bob,
As you might remember I had a problem getting the ARC-1 to finished uploading to my D2 after calibration. I was getting an error message stating the sub needed to be lowered to -21 or -17.
After posting several people here tried to offer suggestions but none helped. That was during a weekend so I tried everything until I was able to contact Anthem on Monday morn.
After several calls and speaking with Peiro the tech team finally came up with a new variation on the ARC-1 program for me to download from their password site. A quick download later, another go through the calibration and WHAM - it worked.
It seems they were contacted by someone else who also was going through the same problem but with a different sub so this problem helped us both.
After watching 4 Dirty Harry movies from the new box set , and checking out tried and true clips from various fav films I can say the difference is amazing.
It took almost a week and half but Anthem did come through. Thankfully.
I want to also thank you, and those here to reached out with suggestions to try to sort this out. The concern is much appreciated.
With thanks,
Scott
That's great! By the way, did you ever find a fix for your sub that makes it respond as would normally be expected when turning down its internal volume?
Or does the new ARC simply let you send a deeper volume trim cut to the D2 (i.e., -19.5 dB was I believe what you needed to send)?
--Bob
post #14709 of 44799 Old 07-03-2008, 08:13 AM
Read the FAQ!
Liked: 3374
Except that you will soon be able to order a new AVM-50 with ARC pre-bundled at the factory. No need to send it back.
And for current AVM-50 owners, the word is that the upgrade to ARC is field (dealer) installable.
In addition to the other items you mentioned, the D2 also has a better power supply.
There have been a number of posts here over the past 2 years reporting that the audio from the D2 is superior to the audio from the AVM-50. With ARC on both units I would expect that to still be true.
The inability, in the past, to get ARC for the AVM-50 was, indeed, a significant factor pushing people towards the D2. So in that regard the gap has been narrowed. But the D2 is still a better sounding unit.
--Bob
post #14710 of 44799 Old 07-03-2008, 08:56 AM
ASW
ASW's Avatar
--Bob
Interesting. It would then come down, then, to whether you thought the D2 sounded enough better than the AVM50 to justify the $1k or so (which is probably what it comes down to with many people in any case). In the high-end audio world it seems to me this cost/benefit analysis goes on all the time, with increasingly big dollars buying increasingly small benefits.
In my case, I bought the D2 after having a DOA AVM50 and the dealer having only a single D2 in stock as a replacement (and willing to give me a great deal on the D2). An AVM 50 with ARC would be a good deal relative to the D2, but no better to me than the AVM 50 v. D2 deal when I bought the D2 - and my original AVM50 (I did not know anything about ARC at that time, but it did help me to rationalize the extra $$ for the D2 after the fact).
ASW is offline
post #14711 of 44799 Old 07-03-2008, 09:50 AM
benleeys's Avatar
......ARC only checks to see if the attached microphone identifies itself over the USB cable as an "ARC-1" microphone -- *ANY* ARC-1 microphone. If so, the ARC application will blithely use that microphone in conjunction with the licensing and calibration files that match (by serial #) to the D2 currently connected on the serial cable EVEN IF YOU HAPPEN TO HAVE THE WRONG ARC MIC CONNECTED!
--Bob
Now I am beginning to worry whether Anthem has packed the correct mic with my disc when they shipped the packaged over to me! I would be blithely listening to a less than accurate correction.
-Ben
benleeys is offline
post #14712 of 44799 Old 07-03-2008, 10:47 AM
Read the FAQ!
Liked: 3374
-Ben
The microphone serial # is currently included as a sticky label on the small, protective box in which the microphone is shipped.
Compare that serial # to the one that is included as part of the file name of your 2 licensing and calibration files (from the ARC install CD). The other part of the filename for those 2 files will be the serial # of your D2.
If the mic serial # portion of the file names matches the sticky label on the protective microphone box, and if you haven't received more than 1 ARC mic (where you might have mixed them up yourself), then you are good to go.
Worrying that Anthem might have mixed up the naming of the calibration files at their end, or put the wrong mic in your sticky labeled box, or the wrong label on the box, is at the same order of probability as that they screwed up the measurement process by which those calibration files are produced. I.e., it could happen, of course, but don't lose sleep over it.
This is primarily a problem for INSTALLERS who are handling different ARC mics for multiple customers.
--Bob
post #14713 of 44799 Old 07-03-2008, 11:25 AM
Tolstoi's Avatar
Buddy
I would think so but this would need to be confirmed.
Tolstoi is offline
post #14714 of 44799 Old 07-03-2008, 11:28 AM
Tolstoi's Avatar
The DAC and audio improvement (better power supply, better analogue stage) alone are wothed the extract cost.
Tolstoi is offline
post #14715 of 44799 Old 07-03-2008, 11:33 AM
Tolstoi's Avatar
When we spend ?000$ for small benefits the last thing you want to do is cost benefits analysis.
Tolstoi is offline
post #14716 of 44799 Old 07-03-2008, 11:37 AM
jayray's Avatar
Liked: 25
Do the DACs do upsampling on the pcm from BD players?
John
Jayray
Read the FAQs
jayray is offline
post #14717 of 44799 Old 07-03-2008, 11:49 AM
Read the FAQ!
Liked: 3374
The D2 accepts up to 96KHz LPCM input. It then upsamples that to 192KHz. The rest of its processing is done at 192KHz. The DACs convert from that 192KHz digital signal to analog audio for output.
The AVM-50 accepts up to 96KHz and upsamples anything less than that to 96KHz. Its DACs convert from 96KHz to analog audio for output.
--Bob
post #14718 of 44799 Old 07-03-2008, 11:56 AM
jayray's Avatar
Liked: 25
I have read the literature on upsampling in the D2. I have a big room, with very good speakers and an A2, A5 amp combo. I am a stickler for sound so I will ask the $64,000 question or maybe $3-4k for upgrade question, how easy is it to tell the difference b/t DAC in the AVM50 vs. the D2. This could be the deal breaker
John
Jayray
Read the FAQs
jayray is offline
post #14719 of 44799 Old 07-03-2008, 12:00 PM
Read the FAQ!
Liked: 3374
John
Only you can answer that. Get your dealer to loan you a D2 and try it.
The AVM-50 is no slouch in the audio department, but every post I can recall in this thread where there was a comparison, even the folks who decided to go with the AVM-50 said they thought the D2 sounded better.
However it is always hard to know how much of that is just "listener expectations".
--Bob
post #14720 of 44799 Old 07-03-2008, 12:53 PM
sbwright's Avatar
perhaps a better question would be, of the many contributors to this thread, those who have gone from the AVM50 to D2 could you let me know what your impressions were. I realize our perceptions can be different but your feedback would help.
John
I just upgraded to the D2 from a AVM50 so I could get the ARC. Do I believe there is a difference in sound quality...Absolutely.
What I don't know or can't say for sure is, did the improvement come from the addition of ARC, the D2 or the combination of the D2+ARC. Unfortunately I didn't do any listening with just the D2 I was way to impatient to get at the ARC.
I believe adding the ARC to the AVM50 will make selecting the D2 vs the AVM50 a lot harder for some purchasers, thats approx. 4k$ that could go toward other equipment, better speakers or even a 2nd AVM50. But then I may feel this way simply because I originally purchased an AVM50.
Brian
sbwright is offline
post #14721 of 44799 Old 07-03-2008, 12:53 PM
jayray's Avatar
Liked: 25
Bob,
I will try to listen to some familiar music at my dealer. He has the same speakers as I have at home but he uses the p2 and p5 amps. Don't think they will make a diff over my A2 and A5. Will take some movies as well. I know it is diff to articulate some of the differences so you're probably right to sample at the dealer. Don't think he has run ARC yet
John
Jayray
Read the FAQs
jayray is offline
post #14722 of 44799 Old 07-03-2008, 12:56 PM
jayray's Avatar
Liked: 25
It won't cost me to audition it at my dealer and could be alot of fun. I know that impatience thing too
John
ps. I removed my second question while you and Bob were responding. Thought it might be irritating for some.
Jayray
Read the FAQs
jayray is offline
post #14723 of 44799 Old 07-03-2008, 01:03 PM
sbwright's Avatar
John
I wondered if I had been ARC'd into another dimension there for a moment....
Brian
sbwright is offline
post #14724 of 44799 Old 07-03-2008, 01:06 PM
yacht422's Avatar
walt here: question! i have 4 way towers, with a pair of 8" woofers in each.
do i want to use the factory settings for the speakers to be set at (small ) or (large) prior to running arc.
today, at last i am ready.
thx
walt
yacht422 is offline
post #14725 of 44799 Old 07-03-2008, 01:32 PM
jayray's Avatar
Liked: 25
Good one Noticed your speaker setup, same fronts and sub, slightly diff centre. How do things sound on your system since it is identical for stereo, which I prefer for music.
John
Jayray
Read the FAQs
jayray is offline
post #14726 of 44799 Old 07-03-2008, 01:39 PM
kal
kal's Avatar
Quoted: 17 Post(s)
Liked: 76
Is it not possible to simply toggle the ARC EQ off/on as you're listening so that you can easily see the before/after difference?
I'm new to room EQ in receivers/pre-pro's but I would have figured they all had a quick/simple way to toggle it on/off as that's the sort of thing that the sales guys can show off in the showroom to "prove" to people (true or not) that they "need" EQ.
Kal
kal is offline
post #14727 of 44799 Old 07-03-2008, 01:46 PM
Quoted: 696 Post(s)
Liked: 476
Kal
Well, it is pretty easy if you go to the Source SetUp while playing the input. There you can toggle ARC on/off and/or toggle Music/MovieEQ and A/B as you want to.
The other Kal.
Kal Rubinson
post #14728 of 44799 Old 07-03-2008, 02:42 PM
Read the FAQ!
Liked: 3374
You can easily A/B whether the ROOM CORRECTION part of the processing is engaged but you can not easily A/B the changes ARC made in cross overs and speaker levels as part of its setup, nor the fact that using ARC disengages other parts of the D2's audio processing that you might have used in a manual setup -- such as the Room Resonance Filter.
As has been noted here, ARC tends to overlap cross overs, which presumably makes it easier for them to implement room correction in the range of the cross over frequencies as cuts in volume -- which are easier on the system than trying to boost dips. I.e., the overlap produces hotter audio in the vicinity of the cross over so more of the things that need to be corrected are peaks instead of dips.
And THAT means that if you simply turn Room EQ = OFF you will be getting results that are biased by the overlapped cross over settings and the particular speaker levels that ARC used -- i.e., without the benefit of the compensating cuts the room correction processing would have applied. This may very well make the audio sound worse than it could with Room EQ = OFF and a properly detailed manual setup.
You could do the following:
1) Do a manual audio calibration to get the best you can get by other means as regards speaker levels, speaker cross overs, Room Resonance Filter, Center EQ, speaker distances and subwoofer Polarity and Phase and whether or not it is THX Ultra2 with Boundary Gain Compensation needed. You will need the speaker distances and subwoofer Polarity and Phase for use with ARC anyway so that part is not additional work. WRITE DOWN YOUR SETTINGS.
2) Run ARC and tell it you want your Movie and Music configuration to be the same. Upload those ARC results.
3) Set up a Source to use the Movie configuration and to have Room EQ = ON. That will make it use the cross overs, levels, and room correction parameters ARC calculates, plus the speaker distances and subwoofer Polarity and Phase that you set up manually. The Room Resonance Filter, Center EQ, and subwoofer THX Ultra 2 and Boundary Gain Compensation settings will be ignored.
4) Go into Setup / Speaker Configuration and change the Music Configuration to be different from the Movie Configuration, but using all the same speakers. Manually enter the cross over values that you wrote down from step 1 into your Music Configuration. [LEAVE THE MOVIE CONFIGURATION UNCHANGED!] Also enter your Room Resonance Filter, Center EQ, and subwoofer Polarity/Phase/THXUltra2/BoundaryGainCompensation settings as necessary, i.e., if they are not already in your Music Configuration. Your speaker distance settings are shared with the Movie Configuration so there's no change needed there.
5) Set up another Source to use the Music configuration and to have Room EQ = OFF. That will disengage the ARC room correction processing and will re-engage the Room Resonance Filter, Center EQ, and subwoofer THX Ultra 2 and Boundary Gain Compensation. In addition, the cross overs will be the ones you just set manually.
6) Now go into Setup / Speaker Calibration. The levels in there are the ones set by the Upload of ARC results. There is no mechanism to provide distinct levels for Movie and Music configurations. Compare the levels that ARC set to the ones you wrote down from your manual setup in step (1) above. If they are different, measure the levels ARC set up with your SPL meter to see how well they will work with your Music configuration. If they appear out of whack, your only choice for a true comparison will be to change them manually when doing the A/B. You MIGHT be able to avoid this by using the "temporary" speaker level adjustments (via the remote control) which are remembered separately for each Source, but this may not produce precisely the same results as changing the settings in Setup / Speaker Calibration.
7) Make sure both of these Sources are set to use the same audio processing mode for the test content you will be playing (i.e., PLIIx or THX or whatever). Now you can A/B by switching between the Source you have set up to use Movie configuration with Room EQ = ON and the Source you have set up to use Music configuration with Room EQ = OFF. (And as stated in step (6), you may also need to adjust speaker levels between them.)
There is, of course, a much easier approach presuming you are willing to forego instant gratification:
A) Do *NOT* run ARC yet. Set up your D2 to produce the best audio you can by whatever means you have available other than ARC.
B) Listen to your system for, oh several months. Constantly refining your audio setup as necessary to get the best you can out of the system. Be serious here. Try to set it up right.
C) After you are well familiar with how that sounds, *NOW* run ARC. If your first 15 minutes of listening after running ARC doesn't convince you ARC is the cat's pajamas then there is something wrong in the way you did your ARC measurements or upload, or you forgot to turn Room EQ = ON for your Sources.
I mean really. For the folks here who haven't had problems getting ARC to run correctly -- which is by far the majority of the posters here -- the wildly positive comments are far and away the norm.
--Bob
post #14729 of 44799 Old 07-03-2008, 09:04 PM
im the man's Avatar
Just received my arc today. I'll have to say is wow, I am really impressed with this device it really has made a big difference in my system. Although, I must admit I don't think I had my D2 properly set up in the first place, but this takes all the guess work out of it. This is by far the best DOLLAR for DOLLAR upgrade I have ever made in my system!
im the man is offline
post #14730 of 44799 Old 07-03-2008, 09:24 PM
Read the FAQ!
Liked: 3374
We're going to have to start another assembly line for these:
--Bob
Receivers Amplifiers
