The new VSX-1016TXV - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 489 Old 08-27-2006, 09:55 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Originally Posted by SEGMA98 View Post
I'm still confused.... i'm debating between yamaha HTR-5960 and this one... i think yamaha has Time Based Correction for the component upconversion (TBC) to eliminate any audio delay... does pio has this feature? thanks
TBC is primarily for use with VCR's, it helps correct video problems caused by transcoding/upconverting the video from mostly only VCR's. It's not for correcting or eliminating audio delay.
Johnla is offline
post #272 of 489 Old 08-27-2006, 10:24 PM
SEGMA98's Avatar
Thanx for the info... just one last question: any problems with audio delay? what about lip sync problems? i know some said no, but i read elsewhere that some had this problem... i have Sony sxrd 50 in..... anyone knows? anyone knows anything about this seller: beachcamera? Rating not bad. and cheapest (around 400 shipped...not authorized i think). plz let me know as i'm new to this field
SEGMA98 is offline
post #273 of 489 Old 08-28-2006, 08:41 AM
bhyde's Avatar
Originally Posted by DrPainMD View Post
What speakers are all of you using with the 1016?
I'm running JBL Northridge series: E90's fronts, EC35 Center, and E50's surround. My .1 is a H100 sub and all sounds good to me. Caveat, I have only calibrated using MCACC as I do not have a spl meter yet.
bhyde is offline
post #274 of 489 Old 08-28-2006, 08:48 AM
eightninesuited's Avatar
Quoted: 20 Post(s)
Liked: 25
My friend just bought the 1016 yesterday from Best Buy.
We're going to construct a folding door with plexiglass this afternoon. No idea how it's going to "fold" yet, but we plan on using 2 mini "puck" magnets to hold the top of the door to the receiver. The space created by the magnets will clear the buttons on the face. One major drawback is that the receiver's front is not metal like the 1015 but plastic, so we'll have to add small, thin plates for the magnet to attract. The back of the plexiglass will be painted black so it won't be see through and match the receiver's paint.
I'm going to take pics of the building process as well as the end result.
My Dad once said to me: "Son, quality over quantity - always"
Of course he was referring to girlfriends after high school, but the same applies to subs - which, if you are in this forum is the girlfriend we have an affair with for a running time of 2 hours in one session.
eightninesuited is online now
post #275 of 489 Old 08-29-2006, 06:04 PM
ncguy's Avatar
I just got my 1016 and did the auto setup using MCACC. When I checked the settings, it had put my studio monitors (LRC) to LARGE. I set them back to small.
The sound is good right now (more later)...but my question is this: since I set the front and center speakers to SMALL, should I re-run the auto setup? Or will it just re-set them to LARGE?
ncguy is offline
post #276 of 489 Old 08-29-2006, 06:13 PM
EJRothman's Avatar
It will reset them to large.
Go to Radio Shack and get and SPL meter so that you can set the speaker levels yourself. There is no receiver on the market that has a properly functioning auto-setup. If you PM me I will give you detailed instructions on how to use the SPL meter. I assure you it takes less than 5 minutes to learn.
-Eric
EJRothman is offline
post #277 of 489 Old 08-29-2006, 06:29 PM
ncguy's Avatar
-Eric
Eric --
Thanks for the feedback....I usually do use an SPL meter and do my own setup. But it was my understanding that the pink noise sweeps done by the MCACC are better able to correct for room anomolies than the simple tone level balancing. Is that not the case? I know that some programs have received bad marks for incorrect setup, but I have seen some good stuff on MCACC.
Anyhoo, I will PM you anyway and get your procedure....I am always looking for experienced input!
BJ
ncguy is offline
post #278 of 489 Old 08-29-2006, 06:50 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
I have upgraded mine to 82TXS elite, and my 1016 VSX up for sale!! I loved the reciever!
zoro is offline
post #279 of 489 Old 08-29-2006, 07:32 PM
JayMan007's Avatar
Did you get a good price? Where did you get it from?
I think I've narrowed it down to an 81 or 82... unless I decide to pick up an open-box 1015 that has a great price...
JayMan
JayMan007 is offline
post #280 of 489 Old 08-29-2006, 10:18 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
I think, I did!! I was debating between 81 and 82, went for 82!
PM me if you become interested! You wont repent! Or you can take over my 1016! Just an idea!
zoro is offline
post #281 of 489 Old 08-30-2006, 08:31 AM
JayMan007's Avatar
PM sent....
JayMan
post #282 of 489 Old 08-30-2006, 10:07 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Thanks! just replied!
zoro is offline
post #283 of 489 Old 08-31-2006, 01:44 PM
jaymzh's Avatar
Originally Posted by JayMan007 View Post
I don't know where that is set-up in the XA1...
From the FAQ on the A1:
Where is this FAQ? Can you provide a link?
- Phil
jaymzh is offline
post #284 of 489 Old 08-31-2006, 04:24 PM
FremontRich's Avatar
It does work as a true switch! It will do everything that this "truel" switcher will do http://www.gefen.com/kvm/product.jsp?prod_id=3055
But the real problem is, is that you seem to think a HDMI switch should include a LOT more functions than just switching.
As far as I can see the VSX-1016TXV works with a projector with HDMI input. I don't need any audio going to my projector.
FremontRich is offline
post #285 of 489 Old 09-01-2006, 06:31 AM
vome's Avatar
I have a Pioneer 1014. I'm thinking about upgrading my receiver. Is it worth the money to buy the 1016? Can someone that used both comment? Thanks.
vome is offline
post #286 of 489 Old 09-01-2006, 06:36 AM
DrPainMD's Avatar
Why are you thinking about upgrading?
super dirty , super clean , pow
DrPainMD is offline
post #287 of 489 Old 09-01-2006, 01:16 PM
atagert's Avatar
I actually have both. since they arn't connected to the same speakers, it is hard to hear if there is a difference in sound between the two. I think the 1016 sound a bit better, but it may be the room. I have the same center speaker connected to both.
Obviously the 1016 has the hdmi switching, and thus that is the one that is connected to the projector. The 1016 has 7.1 analogue inputs and it can do a 10db boost to the LFE. It also remembers which input had the analogue in so when you switch to the DVD it remembers that you had it set to the mutli in and thus you don't have to press the button on the front of the receiver like you must on the 1014.
The remote is basically the same.
Would I upgrade? Probably not, I don't think the sound is all that different for $400. You could spend that on something that would give you something really different, maybe a buttkicker or HD-A1, etc.
Adam
Adam
Descartes walks into a bar. The bartender says, "Wine?" Descartes says, "I think not," and disappears.
atagert is offline
post #288 of 489 Old 09-01-2006, 02:35 PM
vome's Avatar
I'm thinking of upgrading because my 1014 has been acting weird lately. If I turn up the volume too loud, it turns off by itself. Then I have to turn it back on and lower the volume. It's annoying. I don't even turn it that loud either, just to -30.
vome is offline
post #289 of 489 Old 09-01-2006, 07:42 PM
SEGMA98's Avatar
There is something confusing me alot..
1) Since HDMI is only pass through (vedio only), does this mean I'll have to use audio cables from each input to the tv?? (do i have to use audio cable for dvd, sat, xbox360...etc? or do i use just one audio output from the reciever to the tv for all of these)... can u plz explaine to me...
2) does this HDMI convert analoge to HDMI or not? i know it has no upsacaling
3) Which one is better this model or the vsx-80txv..i know the 80 has multizone which is not here, but this one has THX?
4) if i chose another reciever that has analog to HDMI conversion (like the VSX-81TXV) will there be a significant change in output regarding audio/vedio quality?
as u all see, i'm newbie.. i've been reading alot in the past 2 weeks but the more i read, the more i get confused
thanks alot guys
SEGMA98 is offline
post #290 of 489 Old 09-01-2006, 09:45 PM
atagert's Avatar
In that case, yeah, I would think it would be worth the upgrade. -30 isn't that loud and I too would find that to be a bit of a pain.
Adam
atagert is offline
post #291 of 489 Old 09-01-2006, 09:51 PM
atagert's Avatar
thanks alot guys
Lets me try to answer the questions that I do know.
1. I'm going to assume that you will use the 1016 to power the speakers. In that case, you will run audio cables from the DVD player, sat, etc. to the 1016. You should think of the HDMI cable as just a video cable like a component cable.
2. A analogue signal stays analogue. If you want to have analogue too, you'll have to run an analogue cable between the receiver and the TV.
3. The best I can answer this is that the receiver are different. It really depends, are you going to use multizone? I run mine in a 7.1 setup and thus I wouldn't be able to use the multiple zones anyway. The THX certification is just that, a certification. Both receivers will give you excellent sound.
4. I don't think there wil be much difference, but I haven't tested it out, so I can't give you a definate answer.
Adam
atagert is offline
post #292 of 489 Old 09-03-2006, 10:48 AM
Anyone out there with a VSX-1016TXV have problems with the HDMI pass through? I have a Mitsubishi HC3000 and I want to switch between my RCA HDV-5000 and my Comcast cable.
post #293 of 489 Old 09-03-2006, 02:38 PM
atagert's Avatar
I haven't had an issues switching between Toshiba A1 and the comcast box. Both HDMI. I have a sanyo z4.
Adam
atagert is offline
post #294 of 489 Old 09-03-2006, 04:05 PM
Adam
post #295 of 489 Old 09-04-2006, 06:43 PM
SEGMA98's Avatar
Quick question guys... I've been readin about sony STR-DG800 which has HDMI pass through... here is the deal: If u connect ur device HDMI to this sony reciever, u will not hear sound through the reciever (only from TV speakers)...u'll have to connect ur HDMI device directly to the TV and use audio cables from ur device to the reciever in order to use ur custom speakers... is it the same situation here ? or will i be able to hear sound from my custom speakers if i connect my HDMI device to the reciever (and using audio cables as well)... Since they have both HDMI passthruogh, i was just getting confused...Thanks
SEGMA98 is offline
post #296 of 489 Old 09-07-2006, 05:52 AM
atagert's Avatar
Think of HDMI pass through as simply a video cable. And the receiver is a big switch. You'll need another cable to run audio.
With these receivers, you'll still connect the hdmi from device to receiver and receiver to TV via HDMI. And you'll make an audio connection.
You will not run any cables from the source to the TV without first connecting to the receiver.
Adam
atagert is offline
post #297 of 489 Old 09-08-2006, 09:16 PM
PShow's Avatar
Any plans to offer the 1016 in Silver?
PShow is offline
post #298 of 489 Old 09-08-2006, 11:15 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 623
If there were plans for silver, it would be out already. So no.
Smarty-pants is offline
post #299 of 489 Old 09-09-2006, 06:28 PM - Thread Starter
fanofmusic's Avatar
Probably in Europe or Canada. We here in the US don't seem to get the silver option.
fanofmusic is offline
post #300 of 489 Old 09-11-2006, 02:51 PM
hammondc's Avatar
Jumped on board with this unit yesterday to replace my Kenwood HTIB. 349 from 1call. Price is back up to 399 now. Yay!
XBL Gamertag : iChip
hammondc is offline
