Reliability of Harman Kardon DPR2005 ? - AVS Forum | Home Theater Discussions And Reviews
Old 08-29-2006, 09:20 PM - Thread Starter
eya
eya's Avatar
Hi,
I know that HK DPR2005s have a high service return rate. Once factory remanufactured, how do they behave ? I mean, are they more/even/less prone to break stop working than a new model ?
[my assumption is that if HK used a faulty component lot for its DPR, it sould be able to solve that back to factory ; however, if it's a design issue, it won't really help...]
eya is offline
Old 08-30-2006, 08:45 AM
dsmith901's Avatar
A refurbished H/K receiver will have a 2 year warranty if you buy it direct from harmanaudio.com. I see no reason why the DPR models would be less reliable than the AVR models, at least after whatever the generic problem was is fixed.
"The truth is out there!"
dsmith901 is offline
Old 08-30-2006, 09:50 PM - Thread Starter
eya
eya's Avatar
Well I did buy it through HK. I haven't received it yet, and I don't regret my choice, just want to know if I have to plan some trip to the service centers...
And that really depends on weither the issues encountered can be solved once for all, or if it is a recurring pb. Only a resseller or service center could tell.
I read of a guy who was receiving is 4th DPR, the other turned wrong. But he got a got a new one each time...
eya is offline
