Onkyo TX-SR804? - Page 22 - AVS Forum | Home Theater Discussions And Reviews
Old 02-20-2007, 12:52 PM
ndskyz's Avatar
Originally Posted by radu View Post
Hello,
Does the 804 have 5.1 analog inputs to use with the analog outs of the Toshiba HD-A1 for hd audio?
Radu
Yes it does...it actually has 7.1 Analog inputs
ndskyz is offline
Old 02-20-2007, 07:42 PM
biggestmuff's Avatar
Originally Posted by Bill3508 View Post
The 804 remote is very easy to program. Don't use the codes just using the direct program feature.
Bill3508
Bill, have you had any problems with the 804's remote? I have had to reprogram buttons a few times because the remote loses them.
biggestmuff is offline
Old 02-20-2007, 08:01 PM
ccarzoo's Avatar
I got two questions for you guys. I have had the 804 for 2 weeks now. I just hooked up all my equipment to it:
Scientific Atlanta 8300 HD HDMI
Toshiba upconvert dvd, HDMI
360 component
i have one hdmi running into the tv
my questions are these:
When the 360 turns on, there is a 2 or 3 seconds of static on the tv, before the picture comes on. Has anyone heard of this?
Second, I can no longer watch tv on non hd channels. My cable box is set to output 480p 720p anad 1080i, but the option for 480i cannot be selected. The screen is just black, and there is no picture. Does anyone know what this is about?
"Go Blue"
ccarzoo is offline
Old 02-20-2007, 09:19 PM
Bill3508's Avatar
Negative, never had any problems with the 804's remote loosing my programming. I had my Onkyo 777 forever and the programming worked the same way and perfect for years. Running every component I have on it with no problem.
Bill3508
A wise man once said if it sounds like a broken record there is a motive behind the message.
Bill3508 is offline
Old 02-21-2007, 11:23 AM
ccarzoo's Avatar
360 component
please give any assistance, if you know what is going on.
"Go Blue"
ccarzoo is offline
Old 02-21-2007, 12:01 PM
49Merc's Avatar
Quoted: 338 Post(s)
Liked: 73
I suspect the primary problem is a possible compatablity problem between the with the SA HDMI and the 804. Many, many satellite and cable HD DVR's and HD boxes have this problem. Cable and satellite providers are slowing solving this problem.
Test my theory by converting your SA to component. Next, verify that you have the latest software verison in your XBox. If none of this works then remove your DVD HDMI.
Once you discover the culprit(s) I might suggest you run the offending device directly to your television with audio only going to the 804.
Let me know if I can provide additional assistance.
Louisp
LG OLED 55EG9100 HDTV, DirecTV HD DVR Genie HR44, DirecTV AM21 OTA Receiver, Sony BDPS6500 Blu-Ray, Bose Soundtouch 130 HTC (Sound Bar), Panamax MR5100 Power Manager, Harmony Ultimate One Remote, Monoprice AV Cables
LG OLED 55EG9100 Calibrated by Best Buy Geek Squad
49Merc is offline
Old 02-21-2007, 12:04 PM
thyname's Avatar
Quoted: 223 Post(s)
Liked: 75
Originally Posted by steve68 View Post
The 804 will take a component or composite input and output the signal over HDMI. It will not upconvert the signal from say 480p to 720p though.
Really? Below is from Onkyo website:
Video Features
Time Base Correction (TBC)
Comb Filter for Composite to S
HDMI Video Upconversion
HDMI Switching Input/Output 2/1 (repeater)
HDMI Bandwith up to 1080p
HDMI Version 1.1
Deinterlacing for HDMI Output (480i to 480p)
Composite and S-Video to Component Video Upconversion
Composite to S-Video Conversion
On-Screen Display
It looks like it does video upscaling, not simply video switching.
thyname is offline
Old 02-21-2007, 12:06 PM
jameswei's Avatar
I run a Comcast cable box connected to the 804 via component and DirecTV H20-100 connected to the 804 via HDMI with a single HDMI to my Samsung 1080p DLP and can view any channel SD or HD with no problem. If you connect your cable box straight to the TV, as configured, does it work?
jameswei is offline
Old 02-21-2007, 05:05 PM
ccarzoo's Avatar
yes it has in the past for the few months that I have had the tv. Only now, when run through the receiver, can't I watch sd television. It is annoying, because I really needed this feature to help the wife watch tv. Harmony remotes didn't even work for her.
"Go Blue"
ccarzoo is offline
Old 02-22-2007, 07:42 AM
fatsooner's Avatar
Video Features
HDMI Version 1.1
On-Screen Display
It does not upconvert signals, to the best of my knowledge. My 480i channels always came through as such when I owned this unit.
I think there is upscaling and upconverting - for some reason in receivers they call upconverting taking an analog signal like component and converting it to run out the HDMI. In dvd players, however, upconverting actually "improves" the signal.
Pls blast me if I'm wrong, I'm a noob, but I think this is correct.
If at all in doubt, call Onkyo.
fatsooner is offline
Old 02-22-2007, 07:43 AM
fatsooner's Avatar
I feel your pain, but don't blame Onkyo. It's the cable box. Prob wouldn't work with any HDMI reciever.
Old 02-22-2007, 07:54 AM
ndskyz's Avatar
Two terms
UpConverTing- Resloution based. From lower to higher 480p to 720p..etc.
UpConverSion- Signal based Takes Analog in, and puts it on a Digital output. Component to HDMI
The 804 does Upconversion not Upconverting.
ndskyz is offline
Old 02-22-2007, 08:49 AM
ccarzoo's Avatar
so what do I do? Is it worth taking the unit back? It is dollar for dollar the best receiver that I have ever demoed. I would hate to have to run all those cables to the tv...
"Go Blue"
ccarzoo is offline
Old 02-22-2007, 09:20 AM
ndskyz's Avatar
Try hookin your cable box up using component and optical. A lot of these cable/Sat boxes have HDMi ports on them, but they havent been using the true HDMI standard. Run component from your cable box to the 804 use the upconverSion feature to have that video go to your tv via HDMI. See if that will fix your problem. I know it's not as neat as HDMI (2 cables vs 1) But this is what Im doing with my Directv box because of the HDMI issues that thing has....
ndskyz is offline
Old 02-22-2007, 10:12 AM
thyname's Avatar
Quoted: 223 Post(s)
Liked: 75
Originally Posted by ndskyz View Post
Two terms
Wow, great explanation, where did you get this from? Yet, are the specs on receivers reflecting this distinction? Thanks!
thyname is offline
Old 02-22-2007, 11:04 AM
jameswei's Avatar
It probably is a compatibility problem with the cable box HDMI and the Onkyo HDMI. You say you have a problem with your DirecTV box? I have the DirecTV H20-100 and there is a problem with that box and Samsung TVs and others where the signal blinks off and on every three seconds when output is 720p or 1080i. So I had to use component to the TV to get the HD signal. But after getting the Onkyo 804 I tried the HDMI from the H20-100 to the Onyko and output HDMI to the Samsung and all works fine. In my case, the H20-100 HDMI is compatible with the Onkyo 804 and the Samsung is compatible with the Onyko so the compatibility problem from the H20-100 to the Samsung TV is masked. I agree, if he uses component from the cable box with an optical for audio it should work.
jameswei is offline
Old 02-22-2007, 11:12 AM
steve68's Avatar
ccarzoo,
I have the exact same setup except I have an Oppo DVD player connected to the Onkyo via HDMI. I have never noticed the 2 or 3 seconds of static when I turn my xbox360 on.
Is your cable box the DVR or just the HD cable box? I have the HD DVR Scientific Atlanta box. When you did your setup of your cable box did you use the advanced setup or basic? If you did chose the advanced you should have been able to test all resolutions.
I see SD channels just fine. My setup is this:
SA HD DVR cable box connected to Onkyo 804 via HDMI
Oppo971 connected to Onkyo via DVI to HDMI cable
Xbox360 (with HD add on drive) connected to Onkyo via component video and toslink optical audio
Onkyo connected to Mitsubishi HC3000U projector via HDMI 30 foot cable (Blue Jeans brand)
Everything works great
steve68 is offline
Old 02-22-2007, 01:21 PM
Macroblocker's Avatar
Quoted: 78 Post(s)
Liked: 35
Ok dumb question, I am just not sure will uncompressed PCM pass over HDMI or only through the 5.1 anolog outputs? I am thinking of adding Blu-ray in the near future to my home theater(have HD DVD right now)
Macroblocker is offline
Old 02-22-2007, 01:40 PM
lagsun's Avatar
Hi,
I have 8 ohm speakers, but when I try to setup speaker-impedance I only see 4-ohm or 6-ohm. Is this normal?
John
lagsun is offline
Old 02-22-2007, 01:41 PM
ndskyz's Avatar
Thanks..I made it all up Actually these are industry names that people just confuse because they sound very simliar. It's right the on every AVR. Onkyo calls it HDMI Upconversion on the 804. But the do offer video UpconverTing on the 674. It's usally spelled out in the specs.
Macroblocker HDMI can carry LPCM uncompressed/lossless audio. The PS3 does this with no problem into my 804.
ndskyz is offline
Old 02-22-2007, 01:44 PM
ndskyz's Avatar
Originally Posted by lagsun View Post
Hi,
John
Yes the default is 8. You only need to tell it to go to 4 or 6 if you DONT have 8 ohm speakers
ndskyz is offline
Old 02-22-2007, 01:45 PM
lagsun's Avatar
Hi,
John
Oops! I just found the answer on page 46 in the manual. Those are the only two selections and 6-ohms is for speakers from 6 to 16 ohms.
lagsun is offline
Old 02-22-2007, 01:56 PM
thyname's Avatar
Quoted: 223 Post(s)
Liked: 75
I understand it better now, and will try to pay more attention on the specs for the receivers. I am glad I learned something. Thanks. Really, I appreciate it.
Now another question for you: I have a PS3 just like you and looking hard on a silver Onkyo 804. How is the quality of standard DVD played with PS3 via HDMI to 804? Do you personally think would be better to buy a non-upconverTing AVR like 804 and an upconverTing DVD player (like Oppo 981HD) or just an upconverTing AVR like 674 and use it with PS3? Thanks again.
thyname is offline
Old 02-22-2007, 02:10 PM
Randybw1's Avatar
I had posted before that I couldn't get my 803 to display 1080p with the PS3, and someone said it the 803 wouldn't do 1080p. Well I just found my problem, I had audio/video dropouts on 1080i and decided to change out the HDMI cables to see if they were the problem and they were. I've got 1080p with no other issues. Thanks
Randybw1 is offline
Old 02-22-2007, 02:19 PM
ndskyz's Avatar
You are welcome. Glad to be of help. Now for the DVD.. I have stuck a dvd in my PS3. Just to see..I'd say it does just as good of a job as my other DVD player, both running HDMI through the 804 at that time. Having said that my other DVD is an upconverting dvd, that I have connected to the 804 via component (now). It's an el-cheapo Samsung, The PS3 is an awfully expensive DVD player. I only play games and BD movie on it now. I use my Sammy upconverting DVD for DVD duties. This keeps my wife and kids hands off of the PS3. and allows them to push 1 button on the Harmony 880 to watch a DVD. Ease of use...you know...for them..LOL
EDIT to answer your question (got off on a tangent there) I leave the video converting to the things that are supposed to do video. AVR's should pass video..not Process video..IMHO...I bought the 804 because I didnt want it to do any video converTing.
ndskyz is offline
Old 02-22-2007, 02:27 PM
ccarzoo's Avatar
ccarzoo,
how do I do the advanced setup? I have done some tweaking, but how do I know what I am outputting?
"Go Blue"
ccarzoo is offline
Old 02-22-2007, 03:07 PM
thyname's Avatar
Quoted: 223 Post(s)
Liked: 75
It makes a lot of sense. PS3 does not do any video converTing, same with 804. Does that mean that a new UpconverTing DVD player is necessary for me to be able to watch standard DVDs in close to HD quality? (I do understant that upconverTing doesn't quite compare with Blu-ray or HDDVD). Or should I just leave that duty to my Samsung DLP 720p?
thyname is offline
Old 02-22-2007, 04:02 PM
ndskyz's Avatar
Yes if you wanna watch DVD at near HD quality an upconvert DVD is in order. The Oppo does an excellent job from what I hear. My cheapo sammy does a good job for what i paid for it.
ndskyz is offline
Old 02-22-2007, 04:25 PM
49Merc's Avatar
Quoted: 338 Post(s)
Liked: 73
PLEASE NOTE: The following information is not, nor is it intended to be an official statement from Onkyo Corporation or Onkyo USA. Readers should consider the following as hearsay. If your unit is in need of service, I suggest you call Onkyo USA at 1-201-785-2600 between 9 a.m. and 5 p.m. EST, Monday through Friday.
This afternoon I received a call from Onkyo USA regarding a solution to the 804's audio interference, problem.
Engineers with Onkyo Corporation, Japan have solved the "HUM" problem by adding a new resistor and capacitor to the 804. Sorry, but additional technical information was not available at this time.
So, what is going to happen next?
In accordance with my verbal agreement with Onkyo USA, my 804 will be shipped to Onkyo USA tomorrow via Fedex. Upon its arrival in New Jersey, Onkyo USA Technicians will add the new resistor and capacitor then bench test my unit to determine if the newly found solution is a 100% effective. After successfully passing all QC inspections my 804 will be returned to me ready to get back to work.
Next, this repair process will be repeated on an unspecified number of additional faulty 804 AVR's. Once Onkyo USA has approved both the repair and the overall repair process, it is my belief that owners of faulty 804's will be able to individually arrange for their units to be modified.
Time will tell.
Best regards,
Louisp
49Merc is offline
Old 02-22-2007, 04:51 PM
etafan's Avatar
Did Onkyo happen to mention if they will make these changes to all 804's coming off their line and brand these newer versions to indicate this? I would feel better on a future purchase if I knew the system already had the fix. - Thanks.
etafan is offline
