How do I hookup up an EQ to a Pioneer VSX-84TXSi - AVS Forum | Home Theater Discussions And Reviews
Old 10-03-2006, 10:31 PM - Thread Starter
vidmon's Avatar
I am in the video production business and I occasionally need to adjust audio EQ on the fly. In the past I have been able to use a "Tape Monitor" loop to hook up my EQ. Well my under appreciated HK is about to bite the dust and I am looking strongly at the Pioneer VSX-84TXSi. Pioneer says that there is no way to hook up an external EQ. What I hate about the new receivers is even simple bass and treble tweaking is now done with menus. But to provide serious tweaking of a signal it seems like mfgs. don't want us to do that anymore. Am I missing the boat somewhere? Does this units 9 band internal EQ work easily enough and is it accurate. I know I could spend a lot more and buy separate components to tweak the audio but my budget is $1,500 and it seems like the VSX-84TXSi has everything I need except the ability to further tweak my audio.
Thanks for your help!
vidmon is offline
Old 10-03-2006, 11:09 PM
Stereodude's Avatar
Quoted: 3118 Post(s)
Liked: 2256
You don't use an external EQ.
Tape loops disappeared quite a few years ago.
Stereodude is online now
Old 10-05-2006, 02:47 PM - Thread Starter
vidmon's Avatar
Yea I know. Just when you think you will never need it again. Actually I figured out how to do it. Since I don't need the EQ for anything other than Stereo I used the CD/CD-R loop. It works like a tape monitor. Thankfully my new amp sounds really great and I may not end up using it at all. This thing rocks compared to my old HK.
vidmon is offline
